Old March 29th, 2011, 12:13   #1
christoj879
TDI(s): N/A
Default How to prime fuel filter without taking a diesel shower
I replaced the fuel filter, and stupidly didn't put fuel in the new filter. I did a few key cycles, as well as cranking until the car beeped and the the display said STOP to no avail.
Each time after doing this, the T junction would pop off under pressure when I tried to remove it to see if there was fuel in the filter. The last time it did a lot of fuel came out with it. I tried the other lines and each one shot fuel out. Once this is done I now need to wash the engine bay and car
The car still isn't starting - what should I be doing?
christoj879 is offline   Reply With Quote
Old March 29th, 2011, 13:01   #2
CharlieT
If you didn't fill the new filter prior to install, then you now have a large air bubble circulating through the tandem pump. This air bubble gets compressed, hence the spray of diesel and air each time you remove a line.
From where you are now, best option is to :
1. Remove T and fill filter with diesel. Reconnect T
2. Make sure all lines are connected to new filter, no leaks
3. Remove the hose from the rear of the Tee, this is the hose that RETURNS diesel from the tandem pump (trace it back to check)
4. Cap the open port on the Tee (else you will suck air back into the filter)
5. Connect a mityvac to the hose you just disconnected (from the tandem pump), and pump. You will need to pump quite hard (20"+), you are pulling fuel all the way through the filter and tandem pump from the tank.
6. Once you get a clear stream of diesel, no bubbles, reconnect everything.
7. Should start right up, cycle key a few times if needed (without starting) so the lift pump pushes fuel through.
To prevent this in the future, fill the new filter with diesel prior to installing, then just cycle the key a few times and it will start fine.
Another option is to fill the filter with diesel purge and hence clean your injectors at the same time.
good luck.
2012 NMS TDI SEL, 39k
CharlieT is offline   Reply With Quote
Old March 29th, 2011, 14:51   #3
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
I've not had problems in cycling the key a few times to operate the lift pump to prime the empty filter. I've cranked for perhaps 10 seconds total after that until the engine ran.
Yes pre-filling the filter would reduce the 10 seconds of starter operation, but I don't think it worth the effort when a lift pump can fill the filter equally well.
Svante Arrhenius 1896
Old March 29th, 2011, 15:41   #4
christoj879
TDI(s): N/A
It's working. I didn't have a Mityvac but I have this http://www.harborfreight.com/brake-f...der-92924.html and tried it but without much luck.
Unfortunately my starter took the brunt of priming the car. But now my wife won't kill me, I'm very glad she went to a ball game today while I did this.
I had just done a gasser before this one today and was in gas mode (small filter, starts right up) and forgot to fill it. Made the day that much more interesting
Old March 29th, 2011, 15:45   #5
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
I just cycle the key about 10 times, start the engine, then shut it back off right away... cycle 10 more times, start the engine. It may stumble, but it generally picks up and stays running. If it stumbles and dies, cycle the key 10 more times, then crank with the accelerator pedal about 50% until it sputters and starts, then allow to idle for about 30 seconds.
Keep in mind, I also only have the lines disconnected from the filter for about 30 seconds at most, and plug the first two I remove so nothing dribbles out.
oilhammer
www.cardocautomotive.com
Old March 29th, 2011, 17:05   #6
christoj879
TDI(s): N/A
Now for an interesting conundrum. Following the change I took it for a test drive and floored it and then checked for leaks and everything was well. However there's now a whine that tracks with RPM's (louder when higher) and when I take my foot off the pedal the engine stumbles once when it returns to idle.
Thoughts?
Cant get fuel filter to prime and other issues etendick TDI 101 4 November 6th, 2010 13:11
Fuel pump to prime filter? mechanicalbrew TDI 101 4 January 21st, 2009 16:55
Prime the fuel filter Hexar Fuels & Lubricants 4 November 18th, 2007 13:51
Where to get vacum to prime fuel filter? BioDieselJoe TDI 101 21 July 27th, 2006 01:27
easiest way to prime fuel filter? grimlock VW MKIII-A3/B4 TDIs 26 November 28th, 2004 17:44
Page generated in 0.13684 seconds with 10 queries
[Output: 74.60 Kb. compressed to 65.45 Kb. by saving 9.15 Kb. (12.27%)]
