Old March 27th, 2011, 20:27   #1
Ghastly
Ghastly's Avatar
Question should I replace subframe bushings?
Car is 2004 Jetta sedan with 160,000km. I'm doing a refresh of all suspension bushings except the subframe bushings. Are the subframe bushings likely to be toast? Should I order the parts and do it all at the same time? I really want make the front-end as tight as possible. Please advise!
Ghastly Gus
2004 Jetta Sedan 5sp | DG Short Shifter | BFI Stage1 all round, TT rear control arm bushings, Cupra R rear axle bushings | unauthorized EGR cooler delete | Bilstein HD w/Shine 6cyl springs | VNT-17 | 2.5" IDparts DP |tacotaco SMIC w/1.8T PP w/IDparts upper IC pipe | SFS TIP via Kerma | Sachs VR6 Clutch | 14 lb flywheel | Malone tune
Ghastly is offline   Reply With Quote
Old March 27th, 2011, 21:35   #2
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
I still haven't figured out why they even have rubber bushings on the rear half of the subframe.. The front half is bolted solid, so they kinda seem useless..
Either way, I do a lot of bushings on mk4's and rarely ever see bad subframe bushings.. I'm putting an engine in an 02 Golf that has 300k and it has good subframe bushings.. I wouldn't worry about them if I were you..
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old March 27th, 2011, 22:00   #3
FlashT
Post
Don't worry about them unless you plan on upgrading to the Audi TT subframe bushings.
FlashT is offline   Reply With Quote
Old March 28th, 2011, 08:48   #4
Ghastly
Ghastly's Avatar
Thanks guys, that's what I needed to hear. The TT bushings sound great, but at $207 per set it's a little expensive.
Ghastly Gus
Old July 9th, 2011, 09:57   #5
Evil-Diesel
Evil-Diesel's Avatar
TDI(s): '05 TDI PD-R
Thats on a stock motor and parts. When you start upgrading other parts such as nozzles, turbo, dogbone, etc, and adding more power, you will see that all bushings, including subframe, will deteriorate quicker..Im at 170,000kms and my subframe bushings need replacing. Its just my opinion that if you are upgrading all mounts and replacing busheings, might as well not half arce it and just replace the subframe bushings too.
KERMA HYRBID VNT20 + HIFLOW CAST MANIFOLD, HYBRID PD100 INJECTORS, PRECAT EXHAUST DUMP + 0 LAMBDA, SRI, OMI, FMIC, BHW OIL COOLER, OIL CATCH, EGR DELETE, JOM's, WAVETRAC LSD, VR6/G60, BFI MOUNTS, TT LCA'S, TT SUBFRAME BUSHINGS, TT SHORT SHIFTER, VR6 AXLES, VR6 SWAY BAR, VF ENDLINKS, POWERFLEX SWAY BAR + STEERING RACK + REAR AXLE BUSHINGS, ZIMMERMAN XDRILLED, KERMA WIDGET, 1200RPM...
Evil-Diesel is offline   Reply With Quote
Old July 9th, 2011, 20:15   #6
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
I didn't do my subframe yet but will with the clutch I am thinking as my brother said it makes it easier to just drop that down. I haven't had a reason to drop the sub frame down yet. That and mine look great yet. Brothers look like crap though.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car-4 door, 1.9 TD aaz, 5 spd
1981 Caddy VW truck-Topper with it
2004 Golf-2 inch lift, Q-loader stage 1 tune
Vag-Com owner
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old July 25th, 2013, 00:17   #7
Ghastly
Ghastly's Avatar
The correct answer is yes, you should replace the subframe bushings - with Audi TT parts.
Ghastly Gus
Old July 31st, 2013, 17:30   #8
dremd
dremd's Avatar
I'm running 034motorsports billet bushings in my second car, works great, no NVH change detected, mild steering improvement. That's on current car.
No last car I had one that was screwed, HUGE improvement (car would clunk).
2013 Nissan LEAF what are these emissions you speak of?
03 Silver Premium Jetta Wagon lots of OEM goodness. 1.8T Triptronic eliminated, ALH + 6 speed manual installed in place. Emissions? Yes, a lot
2006 Sprinter long range hauler, 300+ cubic feet loaded 25 mpg.
2014 JSW (Went back to VW) Emissions? Well, about that . . .
dremd is offline   Reply With Quote
subframe bushings syrjohn VW MKIV-A4 TDIs (VE and PD) 0 November 13th, 2010 17:03
When replacing subframe bushings, do I need to install new bolts? O0_Ia VW MKIV-A4 TDIs (VE and PD) 4 December 12th, 2009 15:18
Is there a write-up on replacing subframe bushings? O0_Ia Upgrades (non TDI Engine related) 1 December 10th, 2009 08:07
Subframe bushings: TT vs stock Doc_Oc Upgrades (non TDI Engine related) 23 August 8th, 2007 13:24
TT Subframe bushings NewTdi Upgrades (non TDI Engine related) 1 July 11th, 2007 18:18
Page generated in 0.11841 seconds with 10 queries
[Output: 89.13 Kb. compressed to 76.77 Kb. by saving 12.35 Kb. (13.86%)]
