Dash removal
Lots of work to get the dash out! I'll try to remember.
Start by prying up the cover around the gear shift.....screws under there! (Leave the gear shift knob on the stick, the cover need not come all the way off the stick)
I'm thinking the little accessory tray (if that's what it's called) at the back of the console must be pulled up and out.......screws under there!
Then, take out the panel with the glove box....screws under the bottom, open passenger door and see where there are screws at end of dash, look along the bottom edges of the console for round plastic plugs (screw behind them), then you need to remove the radio (special tools), the black center section of the dash....notice, it is two piece and reaches all the way to the windshield. Push the piece toward the window and it should pop up and out. Now, go outside and look in thru the windshield....see there are more screws there on the main center piece.
Now, back to the radio, behind it are screws......also, I'm thinking there is one screw at the edge of the console near where the accelerator pedal is located..
As you try to work out the console, all those "hidden screws" will began to show!
The heater/ac controls will come into play as well!
Others can chime in as you work across toward the cluster!
I did a rather detailed write-up back in mid-2009 on this topic!
Hope this helps!
