Old March 22nd, 2011, 19:42   #1
Pcar993
Default Has anyone used radiator leak stop to stop a heater core leak???
good idea? bad idea? Has anyone used radiator leak stop to stop a heater core leak??? Looks like a pain in the ass to replace it.
My Golf 2000 TDI 180whp 328wtrq (With VNT17) I'm now running vnt17/22, no dyno on that yet.
Jetta 2001 TDI, Was converted to burn WVO, but not anymore. 47mpg with an auto!
AKA "Diesel Power" on VWvortex
Pcar993 is offline   Reply With Quote
Old March 22nd, 2011, 19:45   #2
Seatman
Seatman's Avatar
Fuel Economy: No idea
Wynns stop leak's pretty amazing at stopping leaks but you'll have to check it's compatibility with the vag coolant.
Seatman is offline   Reply With Quote
Old March 22nd, 2011, 19:58   #3
johnboy00
Do you just have a pinhole leak causing window fogging or is it actually leaking fluid?
I was about to get my heater core replaced on my Passat last November but then it self sealed. I never acutaully had a liquid leak though just some fogging/film on the windows. I spoke to MrChill about this and he said it fairly common and his Jetta did the same thing.
John
2005 Passat Wagon
1999.5 Golf
johnboy00 is offline   Reply With Quote
Old March 22nd, 2011, 20:32   #4
Pcar993
I havent found any signs of leak yet. This just started happening last week. All it does right now is windows fogging and i can smell it when i turn the heater on.
Old October 29th, 2012, 18:57   #5
LearDriver
TDI(s): 06 Jetta
Fuel Economy: down to just over 41 with four drivers (two teens)
Mine is doing the same thing no sign of a leak but fogging with the heater on. I will try the stop leak.
LearDriver is offline   Reply With Quote
Old October 29th, 2012, 19:30   #6
moterhead
TDI(s): 05 jetta
Fuel Economy: 46 mpg
Do not use stop leak in a engine u care about replace or repare the part
moterhead is offline   Reply With Quote
Old October 29th, 2012, 19:33   #7
johnboy00
I'm at almost 2 years on my self sealed leak.
John
2005 Passat Wagon
1999.5 Golf
Old October 29th, 2012, 19:34   #8
PeterV
HO5G Doyen & Zen Master
PeterV's Avatar
smell = core... It took me 2 days to do out 99 Golf.
Read and re read the how tos. Go slow you ca do it.
PeterV 'BUG*pwr award 2005'
'00 Jetta TDI, RC, Shine, DG RPipe, 520PP, DG/SS LED Boost ASR. Home of HO5G ('96 Cummins CTD 3/4 ton now at 274 HP 670 ft Lbs TQ riprust) Ram 1500 hemi
Trusted TDI Mechanics Map || VCDS Locator ||
PeterV is offline   Reply With Quote
Old October 29th, 2012, 21:11   #9
Got Bearings?
Got Bearings?'s Avatar
Fuel Economy: 36 / 50
Bypass the heater core. It's still warm out!
The New Commuter Car: 2009 Cadillac CTS-V 556 HP, 6.2L Supercharged V-8, 6 speed manual
The Old Commuter Car: 01 Golf GLS TDI WRECKED AND GONE!
The Slow Car: 95 Impala SS 383, 6 speed, 391HP , 440TQ
Looking for Battery Cables, better & cheaper than OEM? Click here for info
Got Bearings? is offline   Reply With Quote
Old October 29th, 2012, 21:15   #10
Crankous
Crankous's Avatar
X2 on this... or loop it out of the system till you can get enough ganas to have it done right.
Crankous is offline   Reply With Quote
Old October 29th, 2012, 21:24   #11
aja8888
aja8888's Avatar
Fuel Economy: About as good as it gets!
Mine is bypassed, but it was 40 F here this morning. I am still packing enough pounds to handle south Texas winter. But I do have a new core sitting in the garage.....maybe when I retire or my kids quit bugging me with their problems will I tackle this nasty job.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
Bring the 1971 Beetle back to life thread:
http://forums.tdiclub.com/showthread.php?t=472400
aja8888 is online now   Reply With Quote
Old October 30th, 2012, 19:12   #12
geostar
Fuel Economy: 45 MPG
I bypassed mine for a while until the frost hit. Couldn't stomach the use of leak stop so I bit the bullet and dug into the replacement. The photo below is about half way through the core extraction. I ended up removing the crossmember unnecessarily. For my HVAC box design, it is much more efficient to disconnect the AC lines and tilt up the crossmember, without fully removing it. Removing the crossmember, makes the job ridiculously complicated, as the main harness in weaved into it.
Have fun, it is not that bad. Read up and you will get it.
Where ever you go, you are always there.
geostar is offline   Reply With Quote
Old October 30th, 2012, 20:04   #13
aja8888
aja8888's Avatar
Is the Bentley manual necessary to do this job, or can you just wing it?
Radiator stop-leak that is G-12 compatible? porterman TDI 101 11 April 6th, 2014 14:34
Can't stop the top injection pump leak..HELP Spohntaneous TDI 101 0 March 13th, 2011 13:27
Ideas to slow or stop a leak in a gearbox?? tdidieselbobny General Automotive 10 June 14th, 2009 20:21
Heater Core / "Stop Leak" CTDieselHead TDI 101 11 April 13th, 2009 22:01
engine oil stop leak businmotion Fuels & Lubricants 16 August 29th, 2008 04:46
Page generated in 0.14400 seconds with 10 queries
[Output: 115.65 Kb. compressed to 97.02 Kb. by saving 18.63 Kb. (16.11%)]
