Old April 23rd, 2012, 22:15   #496
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
What is WCF, especially the W?
Old April 23rd, 2012, 23:11   #497
Digital Corpus
Digital Corpus's Avatar
well of course
internet shorthand
Original Build Thread | Continuation | Photo Thread | Lighting Upgrades
195 whp, 325 trq as of 12-01-12 on base tune | 4-Bar sensor | GTB1756VK | Race 520's |
PD130 intake manifold | DC Stg IV Clutch | 14 lb flywheel | Hot-swappable 2.5" down pipe | 10 mm pump (stock)
Digital Corpus is offline   Reply With Quote
Old April 24th, 2012, 04:56   #498
08jetvette
Weather Correction Factor!
08jetvette is offline   Reply With Quote
Old April 24th, 2012, 20:34   #499
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
I know what a weather or atmospheric correction factor is, that's why I asked. The SAE J1349 standard will usually be in the order of less than 5%, and only be that high only with some pretty extreme ambient test conditions from the benchmark 25°C and 99 kPa. An example is testing on a 100°F (38°C) day. in this case, the CF would still only be 2.5%.
http://www.land-and-sea.com/dyno-tec...horsepower.htm
I don't have a pdf of the original J1349 on-hand so I can't verify the statement, but the above states that the SAE spec has an upper limit of +/- 7% anyway.
Old April 24th, 2012, 22:15   #500
Rub87
wheel correction factor? (just guessing)
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old April 26th, 2012, 05:05   #502
temporaptor
temporaptor's Avatar
TDI(s): 00 Jetta TDI
Fuel Economy: 44 MPG
wheelie capability factor?
TDTuning stage 3+,Scott Tweaked, boost valve, Titan 520's, 11mm, RyanP 02M EFF, DG Sigma 6 short shifter, TT bushings, VDO Boost, and NewSouth EGT, Mufflerectomy. 135.86 WHP 269.74 ft. lbs. on a DynoJet.
temporaptor is offline   Reply With Quote
Old April 26th, 2012, 06:06   #503
TonyJetta
Fuel Economy: A5: 35mpg Avg / B4: 41mpg Avg
That's funny!
On a FWD car...SCARY!
Tony
Diesel fleet: 2006 Jetta, TDI, DSG, 35MPG avg; 2006 DC Cummins, CC/LB/DRW, Jake, 15.5MPG avg, 47kmiles; 1996 Passat TDI, 5sp, Project car! 204k miles, Avg 42mpg / best 48.9mpg, Troubleshooting Links: Whitedog's No Start Trusted TDI Mechanics A4 Limp Mode IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
TonyJetta is offline   Reply With Quote
Old April 26th, 2012, 22:22   #504
Digital Corpus
Leave it to Jeremy to make that happen
Old May 9th, 2012, 11:48   #505
kooyajerms
grocery getter
kooyajerms's Avatar
Fuel Economy: 39 MPG mixed @75MPH
Been messing with it some lately. Just a bit. I'll update again soon.
Till then, here's some smoke video just for the sake of using that Expensive GoPro. Wife's Civic couldn't really tail me very well, so sorry about the walking away.
http://www.youtube.com/watch?v=PNML4...1&feature=plcp
kooyajerms is offline   Reply With Quote
Old May 9th, 2012, 12:00   #506
Rub87
Now you know what to do her for her brithday, instead of useless jewellery, buy her a nice wet shot nitrous kit =)
Old May 9th, 2012, 13:30   #507
struikie
struikie's Avatar
what smoke ?
JW
| 2005 Audi A4 B7 | Pro-line | 2.0TDI BLB | 238.000 km | FMIC | GTB2260VK | 63mm dual VVT exhaust | VVT tuned | 300bhp 565Nm |
struikie is offline   Reply With Quote
Old May 9th, 2012, 13:59   #508
leon10tagg
leon10tagg's Avatar
Nice bit of acceleration, nice sound and no smoke!
01 Golf Tdi, FMIC, CR1756 turbo, PD intake, EGR delete, BV, modified intake, 80mm MAF, turbo back 2.5" Milltek, 11mm IP, R520s, 3bar MAP, TD tuning box, PD130 O/C,Spax adj's, Eibach A/R bars, powerflex bushings, 312mm discs, top and bottom strut braces
04 Passat AWX, 98 Impreza turbo, 97 A4 1.8T sport
http://forums.tdiclub.com/showthread.php?t=298788
leon10tagg is offline   Reply With Quote
Old May 9th, 2012, 18:29   #509
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
Originally Posted by struikie View Post
what smoke ?
JW
Here.. I'll lend him some of my extra smoke haha
http://youtu.be/WvCgJHD3FUk
Trusted northeast TDI guru (They tell me I can fix these things)
TDIJetta99 is offline   Reply With Quote
Whitbread Performance Innovations is now in operation! Whitbread Vendor & GroupBuy items for sale 463 January 24th, 2013 10:27
Wanted GTB2056VK RCPaul Private TDI Items for Sale/Wanted 8 November 15th, 2010 23:20
gtb2056vk help ibiza83 TDI Power Enhancements 3 October 9th, 2010 23:44
FS: Whitbread 2.5" down-pipe for B4 (maybe A3 too?) Sprocket Private TDI Items for Sale/Wanted 3 August 13th, 2010 10:14
Page generated in 0.16543 seconds with 10 queries
[Output: 134.90 Kb. compressed to 113.17 Kb. by saving 21.72 Kb. (16.10%)]
