Old March 20th, 2011, 18:34   #1
CanuckCommuter
CanuckCommuter's Avatar
Fuel Economy: 800 l /100 k with a heavy foot
Default Valve cover gasket?
Sorry but i searched as much as i could here and could not see any posts that related to the replacement of this item.
I have just ordered my Bentley manual....But i am looking to see how big of a job this is?
I am leaking oil and would like to replace this gasket.
Any pictorials or breakdowns of this anywhere?
CanuckCommuter is offline   Reply With Quote
Old March 20th, 2011, 19:50   #2
nylonoxygen77
nylonoxygen77's Avatar
TDI(s): A4 1.9 ALH
Looks like you have an A4, you need to replace the entire valve cover as the gasket is integral. Here's where I got mine a few weeks ago:
http://idparts.com/catalog/product_i...roducts_id=654
PLEASE replace the bolts too, they're less than $10.
http://idparts.com/catalog/product_i...roducts_id=922
You need a 5mm hex wrench with a ball end, and you also should get a 5mm hex socket. A torque wrench is also something you should have. Also a universal joint is definitely a plus. There are only 7 bolts, but four of them are in the back, and the two on the left side are difficult to get out. Some recommend using a stubby 5mm socket, but I found that the ball-end hex wrench works pretty well and the universal joint combined with a wobble extension works wonders.
Before you start, you may want to whack each one with a hammer a few times. The bolts are pretty soft, and if they're in there tight, you may end up rounding them out. This happened to me. I used a 6mm triple square to get it out. I just hammered it down into the rounded-out hex hole and used that to back it out.
Please only tighten them down to 7 ft lbs... if you don't have a torque wrench, use a regular ratchet but keep your hand on the head of the ratchet when you're tightening. It's an aluminum head.
Hope that helps.
99 NB Red - affectionately named "Blinky" : CCV "Pipebomb" filter, viton inter-injector lines
nylonoxygen77 is offline   Reply With Quote
Old March 20th, 2011, 20:14   #3
Dodoma
This is expensive just for the gasket. I wonder if you can remove the old rubber from the cover and use it as a stencil to make one from cork. Spending $174 after opening the cover once is too expensive. See if you can use the existing cover and gasket atleast 45 times because the old cork valve cover gasket that is being used on 1.6 diesels cost about $4. If you think your gasket is not preventing leak, use it along with gasket sealant. You will alway see some leak from these vehicles valve cover gaskets because the engine is sweating.
Dodoma is offline   Reply With Quote
Old March 20th, 2011, 21:36   #4
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
Where is it leaking? You might get by with just adding a dab of RTV in the corners of the gasket where it meets the cam caps.
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old March 20th, 2011, 21:49   #5
nylonoxygen77
TDI(s): A4 1.9 ALH
I tried RTV like greengeeker suggests, but for me it didn't work since the leak was not in the area of the corners of the gasket. Removal of the gasket and fabrication may be difficult. It's not a flat two-dimensional gasket, it rounds over the cam on the sprocket side and again on the vacuum pump side - that may be why it's integrated into the cover and not replaceable. You might be able to get away with some RTV, IMHO it might buy you some time, but keep an eye on it. Do what you think is best. My guess though is that you'll get the cover off and find that the old gasket is compressed, rigid, and maybe even a little brittle. Good luck!
Old March 20th, 2011, 22:05   #6
Dodoma
If the rubber gasket is removable, I believe it must then be available separately. We need to do more research on this issue. It seems weird that just for gasket you need to replace the cover. We need to find if the gasket has a vw part number.
Old March 21st, 2011, 07:33   #7
Abacus
That helpful B4 guy
Abacus's Avatar
Guys, a 1998 is an A-3, not an A-4. The covers are cheap and easily replaced. It's only held on with 3 bolts, 10mm if I remember correctly. That's all that's needed to replace it, and it can easily be done anywhere. You will have to remove the CCV puck at the top and the hoses, but it's pretty intuitive.
The gasket is $20. I replaced the grommets at the same time. Just don't overtighten the new gasket because then it can leak.
'97 B4: 453,000 miles Malone 3, K03/04 Hybrid Turbo, PP520's, Stage 2 cam, SBC3, ARP studs, Westach EGT/Boost, Koni Reds/Yellows, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR, Evo plate,
BUG*PWR 2013 Award Winner
Old March 21st, 2011, 12:23   #8
greengeeker
Ha! Wasn't even paying attention. Nice catch abacus.
- Nick -
Old March 21st, 2011, 18:56   #9
CanuckCommuter
Thank you all for the help.
Abacus...that is great news!
As i read on it was looking bleak until i clicked the link for the $20.00 gasket.....Just a few bolts and the removal of the ccv pucks....good stuff.
I will order a gasket and get to it as soon as it gets here.
Thanks again for your help.
Old March 22nd, 2011, 06:27   #10
Abacus
That helpful B4 guy
Abacus's Avatar
Can't tell you how many times I've done the same thing.
Glad I could help.
Old March 25th, 2011, 22:35   #11
Dodoma
If a vw owner is unaware where his/her car is a1 (or mark 1), a2, a3, a4, a5, a6, etc., s/he ought to read introduction on this site to find that out.
Valve Cover Gasket erbenson VW MKIV-A4 TDIs (VE and PD) 2 January 22nd, 2010 05:10
Valve cover gasket KwikSilver Jetta/Bora/Vento TDI Picture Gallery 1 April 2nd, 2009 19:26
Dealer wants $547 for Valve Cover Gasket replacement force me to buy new valve cover honesttussey TDI 101 11 May 4th, 2008 10:02
Valve cover gasket TDILOVE TDI 101 19 January 30th, 2006 19:42
Valve Cover Gasket bndrpa VW MKIV-A4 TDIs (VE and PD) 10 January 8th, 2005 12:58
Page generated in 0.15338 seconds with 10 queries
[Output: 106.46 Kb. compressed to 90.37 Kb. by saving 16.09 Kb. (15.11%)]
