Old March 16th, 2011, 17:12   #1
BERyan
Default How do you clean sun roof drains on 2003 Jetta wagon TDI
My sunroof is leaking every time it rains. It leaks out through the lights behind teh sun visors.
I've tried cleaning the drains with compressed air and I see water dripping out the bottom of the car, but I can't see a drain opening under the car.
I'm able to push a small diameter air hose down about two feet in the right and left drains but can find an outlet point. I can hear air hissing inside theh dash board beside the door.
Any guidance on how to clean to stop the leaking in the rain?
BERyan is offline   Reply With Quote
Old March 16th, 2011, 18:01   #2
cow0man
There should be two outlets. I will try to be descriptive, as I do not have a picture. They are located just inside the the driver and passenger doors. They look like a rubber hose that has been pinched and left flat. Usually if you just squeeze them, you should see water come out if there is any in the line. I had seen a procedure published once, but do not recall where, but it stated to pour warm water near the drains in the sunroof and to squeeze the rubber nipples. Also, it mentioned something about running a piece of wire down the drain tubes, but have not seen a reason as to why if you are able to keep the drains open.
There was a TB on it.
A VW dealer near Seattle wanted over $100 to do a 5 min job.
PM if you you cannot locate and I will get pictures this weekend.
cow0man is offline   Reply With Quote
Old March 16th, 2011, 18:05   #3
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
http://www.volksbloggin.com/2007/07/...-flowing-well/
2015 Golf TDI Comfort line
2L, 6spd, Leatherette 4.5L/100 km
2001 Jetta TDI 357,000 km 01M/2002 Golf TDI 285,000 km 01/2010 GSW TDI 115,000 km 6MT/2013 Jetta TDI 47,000 km 6MT
JASONP is offline   Reply With Quote
Old March 17th, 2011, 07:03   #4
KLXD
Problem with using compressed air is that you can blow the hose off the nipple up where it connects to the drain.
Use string trimmer line for a snake, not wire, and rotate it as you push it in.
Sounds like it might be too late for cleaning the drain for you.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old March 17th, 2011, 07:51   #5
belome
Fuel Economy: 47'ish
Have you had it in for the recall yet? Maybe they will unplug it during the recall.
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is offline   Reply With Quote
Old March 17th, 2011, 15:59   #6
mrGutWrench
mrGutWrench's Avatar
Fuel Economy: 63 MPG/56/47 (2nd tank) '02 Sedab
Originally Posted by BERyan View Post
(snip) Any guidance on how to clean to stop the leaking in the rain?
__. There are a couple of failure modes. One is the plugged drains -- that lets the water back up and overflow into the header area (the light area). Another problem is that the frame of the sunroof has metal drain pipes that are only a couple of inches long. There are plastic tubes that attach to those metal pipes; if they get pushed loose, the water leaks into the area above the sunvisor pivots. From there it can easily run across the top of the headliner to the area where the lights are.
__. Unfortunately, it's really hard to get in the area where those metal pipes join to the plastic tubes. Some people have had some success fishing down the drains from the open sunroof but it's really hard. Do a search on "sunroof drain tubes" on this forum and also the "A4" forum for more details. (PS This is the failure mode that's often caused by too much air pressure if someone is trying to "blow out" the blocked drains.)
MrG, Wallace NC (2002 Jetta, Totalled by drunk, 11/'06) 130K mi in 4 1/2 years/~57 MPG lifetime; New car, '03 Jetta Wagon, CAT filter, .681 top gear, 270K mi. in 8 1/2 yr, ~52
mrGutWrench is offline   Reply With Quote
Sun Roof Drains tdiblair VW B5 Passat TDIs 0 April 2nd, 2010 08:15
Humming sun roof on 09 Jetta TDI cloud09 VW MKV-A5 Golf/Jettas 11 January 1st, 2010 15:31
useful tool for cleaning wheelwells and sun roof drains ben stevens VW MKIV-A4 TDIs (VE and PD) 3 September 18th, 2006 09:44
'03 Jetta Wagon TDI Leaking Sun Roof Tar Heel General VW Discussion 2 May 17th, 2006 07:16
2003 Jetta wagon roof rack question JerryPT VW MKIV-A4 TDIs (VE and PD) 5 April 12th, 2006 05:39
Page generated in 0.12443 seconds with 10 queries
[Output: 75.39 Kb. compressed to 66.13 Kb. by saving 9.26 Kb. (12.28%)]
