Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2011
TDIFest 2011 Discussion about TDIFest 2011 on the Labour Day weekend (September 2-4th, 2011) in Lexington, KY.
Old August 1st, 2011, 18:20   #16
paramedick
paramedick's Avatar
Originally Posted by pugman View Post
Need a pair of 03 Jetta SW rear springs if anyone has a pair that they want to be rid of.
Got a set sitting in the garage. ~70K miles on them, came off my car.
Old August 1st, 2011, 20:53   #17
pugman
Fuel Economy: 47.5/37/35
What would it take for you to bring them?
'03 Silver Jetta Wagon GLS TDI Reflex Silver
'03 Silver Jetta GLS TDI Reflex Silver
pugman is offline   Reply With Quote
Old August 2nd, 2011, 14:37   #18
paramedick
paramedick's Avatar
PM sent. If anyone else needs something, send me a PM. NO BODY PARTS available.
Old August 12th, 2011, 08:37   #19
Nash_TDI
Veteran Member -TDIClub Enthusiast
Nash_TDI's Avatar
Fuel Economy: 63.25mpg max
Don't think I could have the swap done by the fest, but if anybody wants a 5spd:
http://forums.tdiclub.com/showthread...77#post3501477
2.0 ALH, GTB2260, 12mm, etc, etc.....
www.nashimporters.com http://louisvillevw.org/
TDI Repair Available, TBs, Clutches, Manual Swaps, BSM, etc..
PD Cam tools, BSM tool, VE & PD TB tool rental available.
Nash_TDI is offline   Reply With Quote
Old August 19th, 2011, 23:03   #20
TDIDaveNH
Left Lane Coal Roller at Large
TDIDaveNH's Avatar
TDI(s): 1997 Passat
Ok, here it is: my collection of B4 junk going to TDIfest. If you see something you like- buy it and I’ll be sure to bring it. I will however ask that items being delivered to fest be paid for before I leave. If not, it stays home. Yes, I have Paypal. I want to try to minimize the amount of stuff I have to give a two-way 1,900 mile ride to. To be quite honest, I'd prefer to leave this stuff home, but would have to live with it forever, not really, but I can drive it out there if I know someone would like to adopt it. I’d like to think I’ve set the prices low, that is because it’s more important to me to have this stuff gone than money.
I'll update this post as items are sold by deleting pics/descriptions. So if you can still see it, I've still got it.
Be sure to include cel number with payment so I can call/text you once I arrive at Fest.
All parts came from a 97 Passat TDI with 278K miles unless otherwise noted:
Both front brake calipers with brackets $40/set $20/each (functional, but good as cores only)
Both rear brake calipers $30/set $15/each (again, functional but better as cores)
Front spindle assemblies $30each (bearings need to be replaced)
Right side A-arm $20 (rubber parts show all 278K miles)
Short CV axle- $50 (OEM VW- used when I got it, ran it for about 10K miles, no boot stories)
Long CV axle- $35 ( No markings & NOT OEM VW- will need inner boot, but joint still good)
24mm front sway bar w/ hardware $20 (I have the inner hardware to go with it but it didn’t make the shoot)
Zimmermann 5x100 drilled brake rotors $40/set of 4 (280x22 front/226x10 rear - a vernier ride shows about 1mm of wear on both front & back- well within spec)
Pair of B4 VR6 “Bottlecap” wheels 15x6 5x100 et35 professionally refinished $30/each
Per cogo, non per mico (By compression, not by spark)
GLX conversion in Storm Grey- my first TDI engine rides again.
TDIDaveNH is offline   Reply With Quote
Old August 19th, 2011, 23:22   #21
TDIDaveNH
TDIDaveNH's Avatar
TDI(s): 1997 Passat
Default More stuff to 'Fest
AHU coolant pipe $20 (shows a little rust but still very solid - I replaced mine because of this but see that I could have had this one media blasted and been good. Stealership gets $70-not bad, really)
Both rear strut bump stops $5 (I’d be surprised if they were original to the car)
02A code CTN transaxle $75 (has seen all 278K miles, worn synchros, 5th gear set present but all teeth stripped out, broken external shift mech)
OK, see that little bracket below where the starter goes? I’m keeping that- I need it!
B4 14” hubcaps $5/each
Here’s a new UNUSED DieselGeek short throw shifter for the B4. I recently got this from Tomo366, but I really don’t see myself needing it especially with a cable shift system. It’s that whole “polishing a turd” thing. $290 Yup, the good stuff is always at the bottom of the junk!
Old August 21st, 2011, 06:00   #22
tomo366
TDI Lifer
tomo366's Avatar
Originally Posted by mo_focus View Post
I need a mk4 chrome headlight switch for mk6. I can trade in mk5 fog light grills.
I have 2 one with fogs and one without
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old August 21st, 2011, 16:53   #23
Nash_TDI
Nash_TDI's Avatar
I have a used set of thule #400 feet, Kit2005 fit kit (b5.5), and load bars.
The load bars are a hair on the short side. I cut them to fit on my mk4. They still work in the feet fine w/o the end caps on.
$200 OBO.
Old August 21st, 2011, 17:13   #24
airwolf
airwolf's Avatar
TDI(s): None
I can bring old parts from a timing belt, and camshaft change for a 2006.
_-Airwolf-_
2014 F-150 AKA-Ruby
TDIFest2009 Organizer! | TDIFest2012 Organizer!
airwolf is offline   Reply With Quote
Old August 21st, 2011, 21:28   #25
Nash_TDI
Nash_TDI's Avatar
Old August 21st, 2011, 21:36   #26
Torque_Delight
Modded
Torque_Delight's Avatar
Fuel Economy: ~5 l/100km
I'm looking for the rear seats of a Wolfsburg edition Jetta Mk4 to fit with my front ones...
Jetta TDI 2001 GL (~680 000 km) : GT-1749VB, EGT/O2/Boost Gauges, Scangauge II, Sachs VR6 Clutch kit, OEM G60 Flywheel, 502 Nozzles, MRTuning, Euroswitch, Hella Micro-DE w/ yellow bulb, Rear fog, Wolfsburg's Heated Seats, Koni STR.T Shocks, H&R OE Sport Springs, TT Control Arm Bushings, 17" Santa Monica (GTI VR6) Wheels, DieselGeek Skid Plate, FX35 HID Projectors Retrofit, GLI Tail Lights, 2004 Trunk lid.
Torque_Delight is offline   Reply With Quote
Old August 22nd, 2011, 05:42   #27
airwolf
airwolf's Avatar
TDI(s): None
Originally Posted by Nash_TDI View Post
One mans junk is another mans treasure. **shrug**
_-Airwolf-_
2014 F-150 AKA-Ruby
Old August 28th, 2011, 17:31   #28
pugman
Real Name: Otis Keith, Sr
Handle:
What you are hopefully looking for: Down pipe/race pipe? Not really sure just what you call it but it is used between the Turbo and the muffler without a cat.
Old August 29th, 2011, 06:47   #29
74vwsb
Fast Enough Performance (Dyno Event) would like to invite those swap meet participants to use our parking lot to show their merchandise if there is limited room at the hotel. We have ample space in the parking area.
We will have several Mk4 interior sets for sale (Jetta, 03 GLI, 04.5 GLI). Sorry no wagons. We will also be selling many misc. parts you may be looking for. Lots of watercooled stuff. Something in mind? Give us a call (859.258.2015) or send me a PM or just take a look around when you get here!
74vwsb is offline   Reply With Quote
Old August 30th, 2011, 09:48   #30
mrvermin
mrvermin's Avatar
Default I'll be bringing stuff as well :)
Ok, I'll be bringing a few things that I no longer need and am looking to sell off.
VW trunk mounted 6disk changer
Phatnoise Phatbox, with 20gb cartrige, software CD, Cradle and adapter wiring. Missing the manual, but that can be downloaded.
FK Mk4 Jetta HID headlights w/Fogs Chrome with 6000k bulbs. Ballasts are mounted under housing at back, separate Igniters, needs Turn Signal Bulbs and Fog light wiring kit:
Depot Mk4 Jetta HID headlights w/Fogs Black with 6000k bulbs. Ballasts are not mounted on housing, Igniters are integrated with Ballast, needs Fog light wiring kit:
That's it for now, unless I can think of any other small stuff
MrVermin
NEW: 2011 Golf Sportwagen Highline, Navi, DSG, Pano-Roof
OLD: 2001 Jetta TDI: 6speed ERF swap, Fully Built Block & Head, RC Tuned, Race520's,
Colt Stage2 Cam, PD150 Intake, PD150 RacePipe, VNT17/22, OMI, 3" Full Exhaust, 3BAR MAP, 11mm IP, Defender Skidplate, 17" Ariettas, GLI Suspension, Audi TT LCA Bushings,
mrvermin is offline   Reply With Quote
Swap Meet Possibilities? Nash_TDI TDIFest 2008 12 August 22nd, 2008 09:34
Swap meet anyone? mtltdi TDIFest 2007 10 August 31st, 2007 07:30
swap meet poppy1 Ontario 0 May 3rd, 2006 11:39
Swap meet goodies.. Just4u2c Private TDI Items for Sale/Wanted 6 February 11th, 2004 11:05
Page generated in 0.19827 seconds with 10 queries
[Output: 137.44 Kb. compressed to 115.20 Kb. by saving 22.25 Kb. (16.19%)]
