Old March 10th, 2011, 18:54   #1
NOLA_TDI
Default Diesel smell
Is there any reason why when I open my windows and/or sunroof, there is a strong smell of diesel inside the cabin? Random question for sure.
Use to own 1999.5 Golf TDI 2dr
Currently own 1999.5 Golf TDI 4dr
NOLA_TDI is offline   Reply With Quote
Old March 10th, 2011, 18:59   #2
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
Burned or unburned diesel? Would you mind adding your car model to your post/profile?
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old March 10th, 2011, 19:14   #3
NOLA_TDI
2000 Golf TDI 4dr 90k miles 5 spd man.
Burned fuel.
Old March 10th, 2011, 19:23   #4
Lightflyer1
Lightflyer1's Avatar
Exhaust leak somewhere.
2015 Beetle TDI.
Old March 10th, 2011, 19:38   #5
NOLA_TDI
I mean, it's pretty unbearable. So bad that you think there would be a noticeable noise level difference in the exhaust.
Old March 10th, 2011, 20:32   #6
Lightflyer1
Get it checked and fixed fast. Even with the windows closed some is probablu getting in. Probably get a free check at a muffler place.
2015 Beetle TDI.
Old March 10th, 2011, 20:46   #7
AndyBees
AndyBees's Avatar
No offense, but the "chopped off" style of the Golf tends to create more vacuum at the rear of the vehicle..........so, check for poor sealing of the gasket around the deck lid!
In the '80s I drove diesel Rabbits........ diesel odor was a problem if the back deck lid was ajar or the seal was comprimised!
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old March 10th, 2011, 21:20   #8
bgsnyder
bgsnyder's Avatar
With a souped up DCell obviously I smell some diesel exhaust backing up out my garage, my mechanic friend even likes it working on gas engines all day, but if you are smelling it every day there is a problem. Exhaust leak is obvious, but check for an intake leak (from turbo to intake manifold). My hose going to the intake manifold split a little bit, and i didn't notice for little bit and it smoked like all hell when taking off from stops. Also pretty stinky. Stock car taking off from stops I always tended to floor it, I can see sitting in soot for a second.
"1999" "Golf" "ALH"
bgsnyder is offline   Reply With Quote
Old March 10th, 2011, 22:13   #9
Dodoma
Check the engine fuel hoses for leaks, especially the return hoses joining the injectors.
Dodoma is offline   Reply With Quote
Old March 11th, 2011, 04:25   #10
PDJetta
PDJetta's Avatar
Check for fuel leaks. I had that happen on my '85 Jetta TD once and I thought the tractor-trailer in front of me had a bad fuel leak. Turns out the little termination nipple on the #4 injector rotted out and diesel fuel was being sprayed on my hot motor.
--Nate
Old March 11th, 2011, 06:06   #11
AndyBees
AndyBees's Avatar
Read the posts ...........
The OP says it is Burned Fuel....the posts that follow all refer to EXHAUST....not leaking fuel!
Old March 12th, 2011, 06:44   #12
NOLA_TDI
Thanks for your thoughts...I am going to get it checked out, just wanted to narrow down some options.
Diesel smell Tom Brown TDI 101 7 December 15th, 2010 08:24
Eliminating Diesel Smell emergencee Fuels & Lubricants 31 July 8th, 2010 13:05
diesel smell? rockyrunner99 General Automotive 1 October 10th, 2009 06:42
Diesel smell Trimmy TDI 101 11 March 15th, 2008 14:47
diesel smell stan43 TDI 101 3 July 19th, 2002 00:24
Page generated in 0.14983 seconds with 10 queries
[Output: 106.40 Kb. compressed to 88.75 Kb. by saving 17.64 Kb. (16.58%)]
