Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old March 10th, 2011, 17:08   #1
Nextwhat
Default Um, How Do I View the Odometer?
OK, I consider myself of reasonable intelligence, but I can't for the life of me figure out how to view the odometer, rather than the trip odometer. I've tried the MDF stalk but to no avail...
Nextwhat is offline   Reply With Quote
Old March 10th, 2011, 17:30   #2
NickBeek
Right side of dash just below the instruments there is a rectangular button embedded in the dash. Push it but don't hold it down. Holding it down resets the trip Odo.
2013 Passat TDI SE with Sunroof DSG Platinum Grey.
Traded - 2011 Jetta TDI Sedan Manual 6 Speed Silver.
NickBeek is offline   Reply With Quote
Old March 10th, 2011, 19:10   #3
warbird24
Do you have the Cruise Control "ON"?
2011 Golf TDI, 6M, Sunroof, Dynaudio, Cold Weather, Golf Protection Group
warbird24 is offline   Reply With Quote
Old March 11th, 2011, 07:38   #4
scdevon
scdevon's Avatar
TDI(s): None
Fuel Economy: Awesome
With the cruise control on, you should see the odometer every time the car comes to a stop. I think switching the cruise off turns the odometer on all the time. I'm not sure since I leave my cruise control on all the time.
scdevon is offline   Reply With Quote
Old March 12th, 2011, 10:30   #5
Nextwhat
I figured it out. I didn't have the cc on. The manual doesn't specifically say the way to toggle between the trip odometer and regular odometer is to briefly press the square button below the speedometer.
Old July 12th, 2011, 11:19   #6
kathorchid
Default Bless You!
OMG. I thought I was totally stupid. I toggled the various settings for the displays and didn't see anything that looked like an odometer reading. I read the manual and it was of zero use. I've reset the trip odometer a few times since getting the car, but I had no idea this was the same button to get the odometer. I'm going to try this as soon as I get back into the car. I've been worried about when to do my first oil change, and I had NO idea on the total km driven since I bought the car on May 3rd, 2011. Bless you for asking the question.
kathorchid is offline   Reply With Quote
Old July 12th, 2011, 15:13   #7
TDI_Timmy
TDI_Timmy's Avatar
I must be missing something on this, couldn't you cycle through the MFD and and where you see the trip meter press the button on bottom of stalk to cycle between 1 and 2? 1 being trip miles and 2 being miles on tank? Or looking at total mileage on car? Guess I cycled using those dash buttons and left it back on the odometer.
Note* 2 - will reset completely though after 19h59m or a set mileage 1,XXX miles or 1,999.9 km (I'm lazy - don't want to do conversion )
2012 JSW DSG sunroof - white - "Wally"
2004 Chevrolet Aveo - red - "Lil' Red"
1967 Ford Fairlane 500 convertible - converted to 5 speed manual - red - "Betsy"
TDI_Timmy is offline   Reply With Quote
Old July 12th, 2011, 15:22   #8
TDI_Timmy
TDI_Timmy's Avatar
Just answered my own question - maybe I am not so upset about *2 in MFD resetting after 19h59m - as when toggling with button on dash seems like a real trip meter.
Old July 15th, 2011, 09:53   #9
mwayner69
mwayner69's Avatar
Yes, there is a real trip on the dash. That's what I use for my mileage calculations. I did get some good info from the other thread as I didn't realize that I could use trip 2 for a whole tank. I thought they were both the same.
2011 Jetta TDI DSG
2007 Rabbit 2.5 5-speed
2001 New Beetle 1.8t 5-Speed
mwayner69 is offline   Reply With Quote
Old July 15th, 2011, 22:35   #10
jettahighline
Fuel Economy: 5.6L/100km
[0.0/SET] button (Y) trip/odometer... brief press: toggle between the two, long hold @ trip: reset trip.
jettahighline is offline   Reply With Quote
Um, where'd it go?... Oh, there it is. VT TDI TDI 101 3 April 27th, 2010 17:47
UM and Hit and Run ObscuredByClouds General Automotive 5 September 4th, 2009 08:43
Thanks Fix Um Haus Russnut West Coast Canada/USA 9 August 9th, 2009 08:56
Help, Odometer, trip odometer and clock blank and run car MadDogBrenner TDI 101 2 February 19th, 2009 15:33
Page generated in 0.15141 seconds with 10 queries
[Output: 94.22 Kb. compressed to 79.66 Kb. by saving 14.56 Kb. (15.45%)]
