Old March 9th, 2011, 18:16   #1
DZL_WANTED
DZL_WANTED's Avatar
Default Help!!!! Large amount of oil in intercooler!!!!
Alright heres my problem, I am in diesel truck technology and were working on my 2003 NB TDI in the shop for the heck of it. Well my instructor wants to know why in the world is my intercooler full of oil and how and why the oil is getting there. He says that in normal heavy diesel motors that are in big rigs this is a sign of a bad turbo. I read something on the forum about it being normal in a TDI.......I think..........basically what i need to know is the exact in depth reason there is oil running through my intercooler piping and through my EGR and into my intake manifold.
the link to what i read on the forum is here:
http://forums.tdiclub.com/showthread...rcooler+Piping
German Engineering thats built in Mexico
DZL_WANTED is offline   Reply With Quote
Old March 10th, 2011, 04:48   #2
Corsair
Corsair's Avatar
Fuel Economy: 52/48/??
Need more info. How many miles? What is the repair history? Define "large amount of oil" and "intercooler full of oil". Reading some of the other associated posts, you may want to park the car while you post more detailed info and await replies.
If you're noticing that the engine oil dipstick seems to show high oil consumption and you're finding lots of oil in the intercooler, that could be a sign that you have luckily caught a failed turbo (oil seals, dumping oil into the intake tract, as your instructor says), and possibly avoided a very expensive engine runaway or hydraulic lock condition. If that's the case, I'd recommend don't run the engine until you get this confirmed / sorted out. It is typical to find some oil in the intercooler over time, but not several cups or a quart etc.
Best Regards.... Corsair....
2002 Jetta GLS TDI 5-spd 325Kmi, 2014 JSW TDI 6M
2006 Audi A4 Quattro Avant 2.0T 6M
2004 Jetta GL wagon 2.0L (gas) 5-spd (sold)
[also had 03 TDI GLS 5spd wagon bought new, sorely missed]
Corsair is offline   Reply With Quote
Old March 10th, 2011, 05:27   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
There is always some oilyness in the entire charge air tract. But if a cup of oil pours out when you take the lower charge air cooler hose off, you probably do have some problems.
Keep in mind, driving the car too easy for too long can also allow for more accumulation than normal.
oilhammer
www.cardocautomotive.com
Old March 10th, 2011, 06:50   #4
Ol'Rattler
Ol'Rattler's Avatar
Your instructor is correct. "A large amount" of oil is a sign of the turbo oil seal failing. Best to investigate further before you have a runaway or hydrolock from the engine consuming it's own oil.
Like the oilhammer said, some oil in the intake tract is normal.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Ol'Rattler is online now   Reply With Quote
Old March 10th, 2011, 18:08   #5
joetdi
I would judge the amount of oil in the intake to be related by how much is in the crankcase. In other words, if you are not adding oil all the time and it stays near full to the next oil change you're good.
As for the big trucks, those guys always have their foot in it all the time so no oil will collect in the intake system.
joetdi is offline   Reply With Quote
Old March 10th, 2011, 20:26   #6
AndyBees
AndyBees's Avatar
Default Oil in inter cooler
I agree!
100% of the TDIs will accumulate oil in the Intercooler....just a fact! The normal accumulation is oil mist in the blow-by from the crankcase ventilation system. And, as alluded to by others posting in this Thread, taking the RPMs up to or near 4000 occassionally will generally keep the accumulation to a minimum!........blows it on down stream to the Intake into the cylinders and burned!
But, ...........the dip stick is the way to tell the difference in Normal and something more serious ......Turbo Seals about to go kaput!
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old March 6th, 2018, 04:42   #7
blis
Fuel Economy: 5L/100Km
Default Large amount = 600ml
Removed the lower intercooler junction in the hose and drenched my arm in a pouring of oil and then drained another 300ml or more into catch tray... will post pics as I get to the turbo.
blis is offline   Reply With Quote
Old March 6th, 2018, 05:41   #8
jettawreck
jettawreck's Avatar
Should probably start new thread regarding your situation and findings. This one was started/last active six to seven years ago.
2004 Cadillac SLS (wife's)
Old March 6th, 2018, 16:57   #9
Mongler98
Please go start a new thread, this one is old,7+years
also DO NOT DRIVE THIS CAR
your turbo journal bearings have failed, if you run it, you risk a run away as that oil can become fuel to a engine that will blow the F up on your azz. Member here just had a run away and his engine exploded and cracked into 3 parts on the block.
Take the turbo off and report back how much play it has, we will help you, but you need to start a new thread and DO NOT DRIVE IT or even try and start it up, suck it up and trust me on this one.
Old March 7th, 2018, 00:03   #10
blis
OK Guys, will take some pics and I've made good headway, it's slow but good
Old March 7th, 2018, 08:30   #11
AndyBees
AndyBees's Avatar
Guys, why would you want Blis to start a new Thread? We see comments time and again, "use the Search function." His question and concerns are relevant whether this Thread is old or somewhere in between.
Looks like I commented 7 years ago. And, I have an entirely different opinion today. Most of the oil is from the Turbo opposed to the blow-by mist. The CCV on the ALH in my Vanagon is vented to the exhaust via an Evac-extractor and I still get some oil in the IC, related pipes and Intake
Somewhere in my stash of photos, I have pics when I removed the pressure hose at the Inter Cooler on a 2003 Jetta with 149k miles on it. I was drenched with oil..... worst one I have ever dealt with. This was the first TB job on the engine (2nd owner and verified by the 1st owner). Today, at 301k miles the car is running just fine with the same Turbo.
Depending on the miles/kilometers on the Turbo and proper maintenance, it may not need a Turbo. They all, even new, dump some oil, especially at engine idle due to less back pressure!
Old March 7th, 2018, 09:29   #12
JB05
Fuel Economy: 43/41/40
I agree with Andy in regards to not having to start a new thread; especially when the subject matter has been discussed numerous times before. I would not consider reviving a seven year old thread as hi-jacking either.
JB05 is offline   Reply With Quote
Old March 7th, 2018, 09:50   #13
Nevada_TDI
I appreciate the points expressed here regarding the age of this thread, but his question is relevant here so I see no problem with his post or the need to start a new thread. I would suggest he double check the oil on the dipstick, and if the level is not way down, the oil may have been collecting since the previous owner had the car. Unless there is a bit more evidence, I would try not to scare this new TDI-er into needing a turbo as the only explanation for the oil.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old March 7th, 2018, 10:44   #14
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
I know I'm in the minority, but I like reusing old threads if the subject matches.
The OP was a student, bils popped in 7 years later same problem, but real world.
We know some collection is normal, but I like Nevada's suggestion-monitor engine oil usage.
amount of oil for my compressor chrgnu VW MKIV-A4 TDIs (VE and PD) 1 July 16th, 2010 22:59
audi a6 2.5 tdi v6 thin large intercooler eliasuk98 TDI Power Enhancements 1 June 13th, 2010 13:34
ccv can -amount of oil!!!! joy123 TDI 101 0 February 29th, 2008 08:15
Need a bigger fuel pump but I don't have a large amount of money TDI_STU1 TDI Power Enhancements 3 October 24th, 2007 13:39
Oil change with oil extractor - used oil amount? TDI-NC VW MKIV-A4 TDIs (VE and PD) 6 April 26th, 2004 22:16
Page generated in 0.17267 seconds with 10 queries
[Output: 123.67 Kb. compressed to 103.47 Kb. by saving 20.20 Kb. (16.34%)]
