Old March 9th, 2011, 11:37   #1
gillywilly87
TDI(s): bora st 150
Default bora 150 tdi wiring diagram help!!!!!!!
hi there im in desperate need of a wiring diagram for the fuel tank lift pump for a 2002 bora pd 150 tdi with arl engine.
need the complete diagram from pump to source as the lift pump keeps losin its feed. thanks for any and all help.
gillywilly87 is offline   Reply With Quote
Old March 9th, 2011, 15:13   #2
JB05
Fuel Economy: 43/41/40
You are not getting battery voltage to the pump when you turn on the ignition? It will only be a couple of seconds, but constant voltage with the engine running. According to WD 81-13, power to the pump comes from relay(J17), whose control circuit comes from fuse 28. Relay(J317) the power supply relay, feeds the pump, and then there is another feed from the pump to the ECM. The fuel pump relay is #409, 4th one from the left on the top row.
JB05 is offline   Reply With Quote
Old March 9th, 2011, 15:22   #3
JB05
I forgot to mention that the feed wire to the pump is the outer, blue/red thicker one and the thicker brown is your ground.
Old March 9th, 2011, 15:22   #4
JB05
Old March 10th, 2011, 12:42   #5
gillywilly87
TDI(s): bora st 150
Default thanks
if i disconnect the 4 pin connector and turn the ignition on i get the brief battery voltage and all is fine.
Only after acelleration of moderate to full and then backing off to overrun you can here the lift pump cut out and the car then runs out of fuel and stalls about about a minute later.
Any reason for the pump to cut out after acelleration.
Also the initial battery voltage is lost once this happens and to resolve this you need to disconnect and reconnect the connecttor again. Any ideas? thanks for your help
Wiring Diagram a3 tdi ninedee_golf_tdi VW MKIII-A3/B4 TDIs 2 March 7th, 2010 16:33
Bora 1.9 Tdi 150 Weisel_T VW MKIV-A4 TDIs (VE and PD) 3 February 16th, 2007 11:35
1z tdi engine wiring diagram a2gtd VW MKIII-A3/B4 TDIs 2 March 21st, 2005 05:11
TDI Engine wiring Diagram racingzeus Other VW Group TD(I)s 3 March 19th, 2004 18:31
BORA TDi 150 cv - Racer Jetta/Bora/Vento TDI Picture Gallery 35 December 20th, 2001 15:11
Page generated in 0.08942 seconds with 10 queries
[Output: 65.95 Kb. compressed to 58.41 Kb. by saving 7.54 Kb. (11.44%)]
