Old March 8th, 2011, 20:59   #1
V8Boatbuilder
Default HELP - Battery Died and I need my Nav/Radio Code!
Hello,
The battery died on our 2006 TDI w/Nav system, and upon jumpstart, the radio/nav asked for a code. Of course, when we bought the car, we didn't get one.
What's odd is that I've pulled the battery out several times before, and I've never needed a code before!
I have Vag-Com, can I use it to do a reset?
Thanks,
-Aaron
...And then there was one left. His: 2013 Passat TDI 6m
Hers: 2017 Golf Sportwagen TSI/SEL
Toy: 1997 Mercury Mountaineer: Lifted & Modified
Work Trucks: Lotsa Ford vans and pickups...
V8Boatbuilder is offline   Reply With Quote
Old March 8th, 2011, 21:08   #2
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
Originally Posted by V8Boatbuilder View Post
Hello,
Thanks,
You should scan and clear all codes anyway, but all may be well after a few start/warmup cycles even without intervention.
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old March 9th, 2011, 06:47   #3
ZiggyTheHamster
ZiggyTheHamster's Avatar
...and if clearing codes doesn't fix it, I think that the radio code is something the dealer would have to look up in a database.
2009 VW Jetta TDI - Black w/ DSG Born: 5/2009
DSG Paddle Shift Steering Wheel
RCD-510 Stereo
9W2 Bluetooth
ZiggyTheHamster is offline   Reply With Quote
Old March 9th, 2011, 19:22   #4
Professor121
TDI(s): 2009 jetta
Fuel Economy: 43mpg
Your bentley service manual should show the radio codes in service bulletin section . . . at least it does for me and my 2009 jetta tdi
Wonder Lake Illinois
2009 black Jetta TDI
Professor121 is offline   Reply With Quote
Old March 9th, 2011, 19:40   #5
V8Boatbuilder
Just opened it up (I have the CD), but I can't seem to find it!
-Aaron
Old March 9th, 2011, 21:10   #6
dzcad90
Rolex & gin
dzcad90's Avatar
You will need to get the code from the dealership. Each radio has it's own code that can be looked up in some system that the dealer has access to.
Unless it's a very new thing, I've never heard of radio security codes being available in a service manual. It really doesn't make much sense either..
Any decent parts guy should be able to retrieve it for you for free.
- Don
'97 Jetta TDI - 135K - R.I.P. 10/22/03
'03 Jetta TDI - Silver / Black Leather, 161K miles - Sold.
'09 Jetta TDI Sedan - Sold!
'14 Passat TDI SEL - Blue / Black Leather
VCDS Available in Chicagoland - trbodsl@gmail.com
dzcad90 is offline   Reply With Quote
Old March 10th, 2011, 16:43   #7
Professor121
TDI(s): 2009 jetta
Fuel Economy: 43mpg
dzcad90 is correct. The security radio code is not listed and you have to go back to the dealer. The radio code that I thought you meant is the code that tells the system what kind of radio that you have. I finally found my radio code (A 2009 car) as part of a bulletin buried in the manual. Everytime I read the service manual I run across something new.
Old March 10th, 2011, 16:45   #8
JetPuf
JetPuf's Avatar
Fuel Economy: loswest mpg 32 Towing, average 45, highest 53 hwy
I've noticed on the CAN enabled vehicles that you leave the radio off, start the car and turn it on. it realizes nothing has changed and will activate on it's own.
This happened on our '04 Jetta and our '10 Wagen.
White '98 NB TDI "Jetpuf" 310k miles Tune, Injectors, Turbo, Peloquin, 02J 6-Speed..
Gray 2010 X164 GL350 Bluetec 94k miles
Member of The Joneses
JetPuf is offline   Reply With Quote
Old March 10th, 2011, 17:27   #9
dzcad90
Rolex & gin
dzcad90's Avatar
Yeah, the radio must mate itself to the car via VIN or CAN bus MAC address (or whatever the CAN bus has that's equivilent to a MAC)
- Don
Old March 10th, 2011, 17:36   #10
40X40
Experienced
I've had the battery out of my 2006 Jetta and did not need a radio code upon reinstallation of the battery.
I'll get to revisit this in the next few days as my battery charger tells me I have an open cell in the battery.
Bill
battery died.. now radio wont work steve6 Ontario 13 October 20th, 2010 18:12
7" TFT Nav Radio off ebay?? patter98 Upgrades (non TDI Engine related) 1 January 23rd, 2010 14:19
Battery disconnect and radio code ?? D-Cell_Mekanick VW MKV-A5 Golf/Jettas 11 June 12th, 2009 09:15
Changed battery now radio has SAFE 1000 code and will not work TDIfarmer TDI 101 3 July 1st, 2008 09:34
Replacing battery without radio code tgeo169 TDI 101 7 April 29th, 2007 11:31
Page generated in 0.15430 seconds with 10 queries
[Output: 100.65 Kb. compressed to 85.61 Kb. by saving 15.04 Kb. (14.94%)]
