Old March 7th, 2011, 08:57   #1
pams69ghia
pams69ghia's Avatar
Default 1.9 TDi AUY Overboost....new turbo fitted, what next?
Hi All.
We have a 2001 Ford Galaxy fitted with the 115BHP VW AUY Engine. It had continual overboost problems when we bought it and the vanes on the turbo were badly sticking.
I had the unit rebuilt but we are still getting intermittent problems with overboost, typically when going up a hill at low revs say in 3rd gear and trying to accelerate up it.
Did a bit of searching on here and from what I have read it could be one of the following.
Faulty MAF sensor
Leak from a vacuum line
Faulty N75 valve
Faulty actuator seal.
I have a mity vac tool and also vagcom.
Where would be the most obvious place to start looking. I thought about replacing all the vac lines first as this would probably be the cheapest option. How much and what size tubing would I need to replace it all?
TIA.
www.pamsghia.co.uk
www.mycorvette.co.uk
www.mycorvette.tk .....Now sold.
pams69ghia is offline   Reply With Quote
Old March 7th, 2011, 10:02   #2
Tom W.
Tom W.'s Avatar
Fuel Economy: Getta 49MPG IDI 60MPG Passat 34mpg
follow the thread in my signature- canadiangrizzly's piece - it will guide you through the process of diagnosing your problem
good luck!
Chemically cleaning your turbo: http://forums.tdiclub.com/showpost.p...8&postcount=48
canadiangrizzly's Diagnosing limp mode: http://forums.tdiclub.com/showthread.php?t=179589
GoFaster on loss of power:
http://forums.tdiclub.com/showthread.php?t=75959
Tom W. is offline   Reply With Quote
Old March 7th, 2011, 13:25   #3
pams69ghia
pams69ghia's Avatar
That was where I got my info! lol.
A quick question about the N75. Will that operate the same on my engine and can I cycle it with Vag-Com? I assumed that as the actuator on the turbo was controlled by a vacuum, without the engine running there would be no vacuum to cause it to move, am I miising something or will there be a vacuum reserve to enable it to cycle a few times?
Will check the MAF by disconnecting it and see what happens first, then the N75 with Vag-com. Then its on to tracing the vac lines.
www.pamsghia.co.uk
2001 passat tdi turbo overboost problem passatTDIawx VW B5 Passat TDIs 1 May 12th, 2010 11:59
fitted a hybrid turbo, needed to modify vnt outlet pipe to fit, ok to do?? *pic* ThE_gOg TDI 101 1 September 3rd, 2008 11:36
AUY and AJM engine codes and Correct turbo for these engines JuGGa TDI 101 1 May 14th, 2007 08:43
2.5 TDi V6 - New turbo = underboost, then overboost snapdragon TDI 101 1 May 1st, 2007 13:20
AUY engine code TDI?? bodley VW MKIII-A3/B4 TDIs 2 September 7th, 2005 12:48
Page generated in 0.12292 seconds with 10 queries
[Output: 59.93 Kb. compressed to 54.38 Kb. by saving 5.55 Kb. (9.26%)]
