| TDI 101 Got a simple/basic TDI question? Are you a newbie (new to the forums). Feel free to post your question here. |
March 3rd, 2011, 15:59
#1
Timing belt replacement interval 2011 Golf
VW service center suggests replacent of 2011 Golf TDI timing belt at 130,000 miles.
Does this sound right?
MC
March 3rd, 2011, 16:22
#2
Yep, better materials keep moving the changing point up, as long as the bearings hold out.
"Drink the Kool-Aid" -Jim Jones
"Baa-baa-baa" -Sheep
Now, I drive more, worry less.
March 3rd, 2011, 16:26
#3
Have you read your owners manual? The interval should be in there. I thought it was 100k on these but I may be wrong.
NJ's best shop performing Quality Repairs on TDI's, Toyota, Lexus, Scion and other European and Asian cars as well as Motorcycles & ATV's. Written warranty, reasonable prices. ASE L-1 & A-9 Master re-certified. NEW LOCATION: Montague NJ. Hunter Wheel Alignment. Snap-on Tire Service.I don't need to have specials, my prices are better already!
www.mmautocycle.com
April 4th, 2011, 22:12
#4
I had the exact same question. I just bought a 2011 JSW last week and my service manual also says to replace the timing belt at 130,000 miles. I would think there be something along the lines of 130,000 miles or X years, to take aging into account, but I guess that's what inspections are for.
April 5th, 2011, 11:43
#5
Inspections don't help much unless a tooth is missing or something else real obvious, otherwise they appear okay.
05 Passat GLS 2.0 PD, UnChained & Steel GPs by VW, 17" (CC) Spas, New TB/WP, motor mounts, alt pulley, trans filter, cv boots, premature cam wear?  now driven only once or twice a week
2012 Kia Optima SX turbo, 274 hp, 269 ft-lb @ 1750-4500 rpm, corsa blue, new daily driver
April 5th, 2011, 12:17
#6
I second this. There isn't a whole lot to be gained from inspections save from identfying catastrophic failure of the belt itself. The issue generally lies within one of the bearings or the tensioner or the waterpump seizing up and shreding the belt.
April 5th, 2011, 14:02
#7
When all esle fails, read the owners manual / instructions!
The Commuter Car: 01 Golf GLS TDI
RC5, 17/22, PP502, 11mm IP, , PD150 Intake, FMIC, OMI, R32 Airbox & MAF, R32 Euro DSG Intake System, PD lift pump
3" DP & exhaust, .658 5th gear, DC Stage 3+ clutch, 17" Ariettas, TT short shifter, FSD's, R32 front bumper
The Fast Car:
95 Impala SS
Stroked & Bored 383, 6 speed converison , Way too many other mods
391 RWHP , 440 RWTQ
12.60's @ 108 - 4500 lbs
Looking for Battery Cables, better & cheaper than OEM? Click here for more info
April 5th, 2011, 19:12
#8
Given how long it will probably take me to hit 130,000 miles, I think I will plan on getting this replaced sooner. Any recommendations? My old Passat (not a diesel) had its timing belt replaced around 100k miles, just before it turned 10 years old.
April 6th, 2011, 07:56
#9
There was a big debate about miles vs. time on these. Some said 6 years of use IIRC.
