G60 Flywheel
2003 TDI Jetta 5 SPM.
I do a lot of towing, and have never been happy with the starting power of my TDI.
What are the options if, and, when I decide to replace my clutch and flywheel?
Are there some heavier flywheel options available?
Of the clutch packages that I've installed the following parts compliment the ALH / BEW very well.
028-105-269-B G60 flywheel (A-3 or B-4 TDI engine)
021-198-141-A Sachs VR6 Clutch Kit
N-902-061-03 Flywheel bolts (Qty. 6)
N-101-010-01 Clutch / Pressure Plate bolts (Qty. 6)
02J-141-719-C Clutch Leaver (Qty. 1)
012-141-741 Leaver Spring (Qty. 1)
02A-141-777 Ball Stud/ Pin (Qty. 1)
No noise, Clutch pedel travel is the same as the orignal DMF.
As far as towing with this clutch kit you'll have no problems.
