Old February 27th, 2011, 21:08   #1
s.pavel6
s.pavel6's Avatar
Default Hood Latch Deflecting..
Hi Everyone,
Hoping someone has had this problem.. My hood latch is not latching. When I drop the hood down, the latch actually deflects towards the engine, and does not open to receive the hood bar. I have tried to bend the whole assembly forward, but doesn't really help.
Is there something I can do with this one, or how do I get it out to replace it?
Thanks!
s.pavel6 is offline   Reply With Quote
Old February 27th, 2011, 21:16   #2
Seatman
Seatman's Avatar
Fuel Economy: No idea
It might be needing freed off, you could give it a good dose of releasing fluid like WD40 then get someone to work the release in the car while you work the other end with a screw driver. Make sure that the cable isn't holding the latch unlocked or that somehow the latch hasn't gotten locked by some bizzare accident.
Seatman is offline   Reply With Quote
Old March 2nd, 2011, 14:14   #3
s.pavel6
s.pavel6's Avatar
It seems like it's moving fine, but I can try to see if I can get some more penetrant in there. Is there an easy way of taking the lock off to inspect?
Old March 3rd, 2011, 09:08   #4
eb2143
eb2143's Avatar
TDI(s): None
I have the same exact problem: Hood will not close, and inspection reveals that the hood latch deflects towards the engine quite a bit. I'm almost positive this is not a lubrication issue.
When I need to close the hood, I use a thin rope threaded into the latch that manually opens the hood latch to accept the bar. Once I've yanked the rope and done a little song and dance, the hood falls into place and can be pushed shut. I then pull the rope out and store it back in my trunk.
I think it's either a weak latch or alignment issue with the hood bar; my hood bar is noticeably crooked so I was leaning towards that. I've avoided digging into it, but I hope somebody has more information for us as I'd like to fix it eventually without having to troubleshoot it.
The car has mostly lived in central NH, so maybe we have found an problem endemic to the region!
SOLD MY BABY: 2001 Jetta TDI 5mt, Bosio Sprint 520s, Koni FSDs, VW HD Springs, 10mm spacer, Audi TT LCA bushings, 034 motorsports strut mounts, E-code lights, Audi TT "short"-shifter, IDparts rear sway bar, DG Panzer plate, Caterpillar 2m fuel filter, Frostheater, GLI Recaros, GTI 3-spoke steering wheel, Audi S3 shifter, R-line stainless pedals[/URL]
eb2143 is offline   Reply With Quote
Old March 7th, 2011, 17:52   #5
Seatman
Seatman's Avatar
You could try loosening the bolts for the catch a bit, just enough for the catch to be able to move and no more then lower the hood down and see if it can latch, if it does then open the hood back up and tighten the bolts back up. Don't be scared to get stuck in, just take pics as you go and keep an eye on where everything goes.
Old March 7th, 2011, 22:24   #6
zukvw
ok, so i recently went through a6hr ordeal with re-aligning a hoodlatch on my salvage beetle...it never shut quite right....heres what i did, so you can see whats not working, get a bolt thats about the same size as the hoodlatch and press it down in the lock and hopefully you can see whats wrong... in my case it was the top latch hook is attached to another piece that helps guide the hoodlatch in, it usually starts to bend away from the lock (there gets to be a large gap to work properly), you need to try bend it back as flush as posible (i stuck a screw driver in by where its rivited together then hammered towards the lock). also i found that the hoodlatch should be positioned to the far right of the gap, when you are closing the hood. wish i could post pics.... hope this helps
zukvw is offline   Reply With Quote
Old March 8th, 2011, 14:17   #7
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
I gave up and ordered a new latch. Attempting to bend it was not working for me. There is a few places that sell it and it doesn't take much to change.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is online now   Reply With Quote
Old March 8th, 2011, 14:34   #8
s.pavel6
s.pavel6's Avatar
Wondering if I should buy a new one, or hunt for an old one.. Was it pretty straight forward to r+r?
Old April 25th, 2011, 08:19   #9
s.pavel6
s.pavel6's Avatar
UPDATE: Ended up going to the junkyard and pulling a "better looking" latch. Installed it, and what do you know, no difference. Hood still didn't latch. I then decided to check to see the level of the carrier, and of course, the whole lock carrier (rad. support) was sagging. I pulled upwards on it (with considerable force), and voila: the hood latches.
Sold the car, and just repaired the latch on my new-to-me 99.5 tdi with the "broken" one from the gasser. Everything works. I guess the latch wasn't the problem after all..
Old May 3rd, 2011, 12:12   #10
eb2143
eb2143's Avatar
TDI(s): None
Thanks for the update Pavel!
My problems started soon after a front end collision and a AFTERMARKET radiator support was installed. So it looks like you found my problem too.
I haven't dug into things: do you recommend adjusting the latch height (possible?) or do I need to look into altering the level of the whole radiator support?
Old May 4th, 2011, 04:29   #11
s.pavel6
s.pavel6's Avatar
I found that my latch was already at it's highest position. You might try adjusting, but there really isn't much room to adjust there. Loosen the two screws on either side of the latch, and the one right below it. If the tops of the "wings" of the latch are already poking above the plane of the carrier, I doubt you will have much further space to move.
I would try seeing if you can raise the whole carrier. My golf has something of the same problem (bumper sags because the whole front end was not put on properly, but I have not yet taken the time to remove the bumper and mess with the radiator support. It's not really noticeable, so I don't mind.
Good luck!
Old April 12th, 2014, 18:38   #12
wdtony
Default Hood Latch Problem FIXED
I wanted to add my experience here since I finally fixed mine. And seems like everywhere online a lot of people had a problem with this.
OK -
2000 VW beetle. Hood was difficult to close to begin with, had to slam it hard to close it all the way.
Hit some road debris so had to have the broken radiator and plastic holder replaced by mechanic.
Back from repairman, hood only closed correctly twice with very hard slams. Then the plastic piece broke from slamming so hard. After that I fashioned a metal piece from a wire hanger but couldn't get hood to close all the way. Bent the primary catch on the hood latch due to slamming. Bent it back but realized slamming was not an option.
Replaced the hood latch and plastic latch lever with new parts just to rule out faulty mechanism. Tried several adjustments but could not get hood to close. Tested both latch mechanisms out of the car and both functioned normally.
I reamed out the bottom of the bolt holes to raise the latch mechanism (on the latch mechanism) about 1/4 inch more. Still would not close. No more travel at the bolt holes or the secondary plastic lever would not function at such an angle.
Looked at hood alignment and realized the mechanic must have removed hood for the radiator job. I could tell the hood bolts had been moved and the alignment was off when the hood was put back on.
I loosened the 4 hood bolts, still wouldn't close while loose. I re-positioned the hood and held it in place while I tightened the bolts back down. I guessed where it should be by the marks near the bolt brackets and by eye-balling it.
Voila, the hood closed perfectly without much pressure at all. I was shocked.
I then moved the latch assembly down about 1/8th inch and took off 2 rubber bumpers from hood to see if misalignment was the only issue. Hood would not close. Latch height was also an issue.
I moved hood latch back to highest reamed position, put rubber bumpers at lowest position and the hood closed perfectly again. I then adjusted the bumpers until the hood wouldn't close and then backed them off a half turn.
Hood now closes easily and perfectly.
2 assumptions/fixes -
1, The hood alignment had been altered by mechanic and misaligned. This is important to hood latching. Hood bolts must be tightened down to properly close into the latch. Something to do with the curved shape of the hood I assume.
2, The height of the radiator assembly and chassis that holds the latch assembly seems susceptible to vertical misalignment (bending) due to repeated hood slams and or misalignment upon repairs. Fix by somehow raising chassis by force and/or reaming out bolt holes on latch mechanism.
Hope this helps someone.
wdtony is offline   Reply With Quote
Old April 17th, 2018, 16:32   #13
eb2143
eb2143's Avatar
TDI(s): None
Talking Finally fixed, thanks in large part to wdtony
I wanted to add to wdtony's excellent description above. I'm selling my car so finally developed the motivation to fix this pesky little problem so the next owner doesn't have to use a clothesline to close their hood, as I have been for the last 10 years.
The deflection problem this thread focuses on is also the focus of this excellent YouTube video, which I suggest watching first:
https://youtu.be/_qpTGMAQJQ0
The primary problem if the hood won't close and the latch is deflecting rearwards is that the hood needs to go backwards or the latch needs to come forward. Both of these can be done. I would start with whichever one is more likely your problem. In my case, a body shop removed my hood and someone backed into my car in a parking lot, so I thought I'd probably have to do both. If your problems started after someone backs into your front bumper and bends your radiator support, misplacing the hood latch, I'd probably start with shimming the hood latch.
Adjusting hood:
Step 1: Loosen the two bolts on each side that hold hood-to-hinge after marking the current outline of the bracket with a Sharpie just in case:
Step 2: Now get a second person to help you. Pop-off the hood strut off by using a flat head screwdriver to remove retaining clip and tuck out of the way (can do lower as pictured or upper (mine was rusted so I avoided it)). Note: The other two hinge bolts (hinge-to-body) are more difficult to access and don't need to be touched to make small adjustments, although Bentley manual suggests that these bolt holes are also slotted to allow ajustments, if needed.
Step 3: The hood can now slide fore-and-aft a few mm (may need a rubber mallet to break it free). With the hood down but not engaging the latch, slide it backwards, while keeping it aligned left-to-right with fenders. Retighten and repeat adjustments as needed. Make sure the hood isn't so far back that its rearmost edge rubs against the plastic cowl when fully open.
Adjusting latch forward: The YouTube video above makes this very clear. Here's a picture of mine (shims (i.e. washers) indicated by orange arrows)
Other alignment issues can be vertical or left-to-right. These can also be adjusted at the latch or the hood:
- On the latch, its three bolt holes are slotted to get some up-and-down and side-to-side movement
- On the hood, left-to-right via hinge bolts, vertical via the rubber bumpers on the ends of the hood which can be screwed in and out.
Old April 19th, 2018, 13:39   #14
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Nice work folks!
Hood latch darkhorse VW MKIV-A4 TDIs (VE and PD) 4 February 2nd, 2011 10:11
WTB: MK4 Golf hood, windshield, grill, hood latch bryanbryan89x Private TDI Items for Sale/Wanted 0 September 9th, 2009 06:14
hood latch jettamama TDI 101 5 May 1st, 2008 06:40
hood latch jettamama TDI 101 0 May 1st, 2008 04:50
HOOD LATCH Jetta4Me TDI 101 2 October 18th, 2004 12:58
Page generated in 0.15847 seconds with 10 queries
[Output: 126.19 Kb. compressed to 106.11 Kb. by saving 20.08 Kb. (15.91%)]
