Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old February 24th, 2011, 18:19   #1
NickBeek
Default Tail Pipe Soot
Someone else asked about this issue with their CR TDI. I looked at my tail pipes and there is a hint of soot in mine as well. Here are a few pics. Also of note, I ran my finger inside the tail pipe and it came out with a little black on it. This is at around 3800 miles on the odometer. How do all of your tail pipes look.
Left
2013 Passat TDI SE with Sunroof DSG Platinum Grey.
Traded - 2011 Jetta TDI Sedan Manual 6 Speed Silver.
NickBeek is offline   Reply With Quote
Old February 24th, 2011, 18:20   #2
NickBeek
Both
Right
Old February 24th, 2011, 18:59   #3
tdi90hp
my golf is same...super clean...mind boggling how they have cleaned these babies up....my 03 Jetta was a smoker...
tdi90hp is offline   Reply With Quote
Old February 25th, 2011, 18:40   #4
NickBeek
My point is there IS a little bit of soot in there. I believe it should be completely clean......
Old February 25th, 2011, 18:55   #5
tcp_ip_dude
tcp_ip_dude's Avatar
Fuel Economy: 46@75mph/51@60mph/City 38mpg
Looks clean to me. Mine is similar.
______________________________
'10 Jetta 6M Sedan, 35% Llumar tint, WeatherTech Floor Liners, TDIclub Plate Frame, B2, PS, ScanGauge II, Micro-Can VAG-Com
tcp_ip_dude is offline   Reply With Quote
Old February 25th, 2011, 20:52   #6
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
Considering the vehicle is a combustion engine, there will always be some remnants of that combustion, especially when the vehicle is first started and the emissions components aren't warmed up yet. It is very difficult to COMPLETELY clean all of the exhaust all of the time.
Fixmy59bug is offline   Reply With Quote
Old February 26th, 2011, 09:09   #7
NickBeek
IDK, some of the big three diesel pickups with DPF look pristine inside their tail pipes. Personally, I wouldn't care if the whole exhaust fell off and was replaced with straight pipe. Although I won't do that to my vehicle. I just found it odd.
Old February 26th, 2011, 18:22   #8
budtoh3zo
My 2008 f-350 the tail pipes were spotless until 60,000 km when something happened to it. But you should get it checked out you could have a cracked DPF
budtoh3zo is offline   Reply With Quote
Old March 2nd, 2011, 12:30   #9
Pelican18TQA4
Ah, most gasser cars have tail pipes with more carbon build-up than those pics...
"I interviewed the late Steve Yokich, then UAW president, almost ten years ago. When I suggested that Detriot might be putting too many eggs in one basket with its utter devotion to SUVs at the expense of passenger car development and asked if the union might take a position in favor of more economical cars, he started screaming at me." -Jamie Kitman, Automobile
Pelican18TQA4 is offline   Reply With Quote
Old March 3rd, 2011, 10:53   #10
Dean
You sure it's not dust or dirt from being outside in those 3800miles?
Dean is offline   Reply With Quote
Old March 3rd, 2011, 16:30   #11
NickBeek
I thought about it being dust or road grime, that's why I shot the pics straight on so I could see inside the tail pipe not just the chrome tips. I also stuck my finger in the tailpipes, I'm fairly certain it is a light dusting of soot.
I stopped by my dealer this week to ask a service advisor about this and my long crank issue. I really wish I could speak to a tech, because the SA started talking nonsense about fuel quality. I told him I use the same fuel stations I have been using for 157k miles in my truck. He says are you sure your using ULSD? Umm yeah, that's what the pump is labeled! I stopped talking with him before I lost my cool. No sense in arguing with an idiot. I asked him about HPFP issues, and he said they have seen none. I later asked a lube tech, and he said they have seen a few......
Old March 3rd, 2011, 21:15   #12
Mach1
Fuel Economy: 49.3, 48, 21.2,19.99
Those are clean compared to older diesels, you will get some residual contaminants..
http://www.rsbdiesel.com/
2006.5 DE DSG, RC2, Sunroof, Rear airbags, 73K miles, 61MPG best.
2005.5 Jetta-5 SP, LSD, Spec S2, 110K, 48 mpg every tank. Best-49.3 mpg-LOCAL. ELF 506 0-30W/15K OCI/37PPM FE, Best=740 MPT, RSB Diesel custom 2.5DP/3" SS exhaust, Synthetic fuel, Koni lowering springs. One of the first Mark V Jettas to hit the street. Pkg 1, MFD, Autowipe, Auto-headlights, Auto-dim mirror, auto-climate. 248C=150HP RC2
2004 6L 89000 19MPG
2000 7.3 388 HP-818 FT lbs Propane
Mach1 is offline   Reply With Quote
Old March 4th, 2011, 05:51   #13
MayorDJQ
I wouldn't be worried about it. I doubt the DPF can trap 100% of all particles. I would think .001% gets through or some similarly insignificant amount.
With all the grime on the roads of New England, I haven't even bothered looking at mine.
MayorDJQ is offline   Reply With Quote
Old March 4th, 2011, 06:20   #14
turboboost1
Smile To NickBeek
My 2010 Jetta TDI now has about 14K miles on the clock, and my exhaust is pristine. No soot at all. My car see's 90% highway driving though. Very little around town and stop and go.. Also, you're right about not arguing with an idiot. .They've had a lot more practice than you.
turboboost1 is offline   Reply With Quote
Old March 4th, 2011, 06:35   #15
MayorDJQ
I've noticed that the Big 3 trucks have those funny looking tips on the exhaust. Maybe the extra airflow helps keep them clean?
Engine full of soot! Cracked EGR Pipe the culprit?! Lil' White TDi VW MKIV-A4 TDIs (VE and PD) 9 October 7th, 2009 16:19
Soot + Oil=Soilt intake (Race Pipe) meshplate TDI Power Enhancements 4 October 10th, 2002 17:36
Tail Pipe Soot TDiRoy VW MKIV-A4 TDIs (VE and PD) 5 May 7th, 2002 04:27
Wet Tail Pipe Soot ? Vanigh VW MKIV-A4 TDIs (VE and PD) 2 July 26th, 2001 10:42
Page generated in 0.19562 seconds with 10 queries
[Output: 120.50 Kb. compressed to 99.86 Kb. by saving 20.64 Kb. (17.13%)]
