Old February 24th, 2011, 16:21   #1
hiepriest
Default YAW sensor where is it? How to disable ESP for real.
Anybody know where the YAW sensor is I want to try to unplug it to disable my ESP during racing.
Last edited by hiepriest; February 27th, 2011 at 18:30. Reason: For better searching
hiepriest is offline   Reply With Quote
Old February 24th, 2011, 16:23   #2
Steve99
Steve99's Avatar
Right above your knees - remove the plastic "trim" and then the metal knee crash pad and it should be pretty easy to unplug.
'04 Tornado Red .:R32
'04 Reflex Silver Golf TDI
Steve99 is offline   Reply With Quote
Old February 24th, 2011, 20:43   #3
milehighassassin
milehighassassin's Avatar
Fuel Economy: 43
Why not just push the button on your dash? As far as I can tell everything is killed with the push of the button, unlike many other manufactures.
http://www.hardeysmotorwerks.com/
http://www.20vturbo.com (R.I.P)
2005 Golf TDI PD, FM100, Frostheater, Hidden Hitch,
Clear-bra, Tint, VR6/G60 Clutch Combo, EuroJet SMIC, Custom Lower intercooler Pipe, VNT-17, Panzer Plate
Custom 3" turbo-back exhaust
milehighassassin is offline   Reply With Quote
Old February 26th, 2011, 21:56   #4
hiepriest
Actually it doesn't. Hitting the button only kills the traction control part of it. It still keeps the ESP part of it which will do stuff like apply brakes to the inside rear wheels as it thinks your going to spin out. I did figure out that if you unplug a "yaw" sensor it disables the real ESP and the ASR (traction control part of it). Cool thing is that as when you plug it back in the light goes right off. It doesn't store a code or anything. That and when you unplug the ESP switch it doesn't mess anything up. MEANING I'm off to unplug my ESP (leaving it's plug hang) and splice the esp switch into the yaw sensor wiring so when I hit the switch it truly disables everything and not traction control only. The only hiccup I've found is it that the ESP switch is a momentary switch so you have to get another switch that isn't (Like the defrost or I found a foglight switch from an Audi on ebay that fits the same slot). You have to switch faces of the switch and do some minor mod to the tabs. I haven't done it yet but this is what I've figured out and plan and do. Wish me luck
Old February 27th, 2011, 00:49   #5
graeme86
Fuel Economy: Worst ever 40.9 l/100km
Do you have a part number for the Audi switch (or a pic)?
I am following your mod with interest. Good luck.
graeme86 is offline   Reply With Quote
Old February 27th, 2011, 11:36   #6
blizzard60
blizzard60's Avatar
Could you not just find a defrost switch (super cheap used) and switch the face with your ESP one?! Quickest/easiest IMHO.
What wiring are you planning to do to disable the yaw sensor? If I remember correctly the only wires from the yaw sensor are 4 wires that go directly to the abs module. You planning to interrupt those?
blizzard60 is offline   Reply With Quote
Old February 27th, 2011, 13:45   #7
milehighassassin
Fuel Economy: 43
How about in inline switch to turnoff the yaw sensor? Is that what you are planing on the dash switch?
Old February 27th, 2011, 18:23   #8
hiepriest
Yes, I plan on unplugging the normal esp harness to the dash switch and stuffing it in the cracks behind the dash. Then getting a new switch (while switching the face with the ESP button) and using it to interrupt a wire or two (of the 4- correct) between the YAW sensor and the ABS module. As far as which wire it may not matter as any one will most likely disable the system... however I'm going to unplug it and check for voltage with a meter, once I find it I'll break that one. That way when I hit the "new and improved ESP" switch it will throw the "triangle" dash light like normal but not only will it kill the traction control it will also disable the ESP portion of it" but NOT disable the ABS. Hit the button again and you back to factory. Same as when I just unplugged the yaw sensor and plugged it back in the light came on and went right back off (only thing I didn't test is doing it while the ignition was on... I shut the car of to get on my back and plug the thing back in... but I believe it will work hot also... The only difference is the light will be throw because the sensor is not working and not because it's in "spin your wheels" mode.
96-02 Audi A4 S4 A6 S6 A8 Fog Lamp Switch Part# 4D0 941 563. Should be able to search completed listings on ebay if you want a pic. Now, I don't know if it will be perfect but I took a chance on it. It was $15 bucks same as the defog switch. The problem with the defrost switch is that it is of the 6 terminals on the back only two of them function as a switch when checking with an ohm meter. Naturally they are normally open and when you press the button to make those terminals close. However the switch is depressed slightly and I would have to stare it the slightly depressed switch during the 98% of the time I had the system working like normal and it would bug me. My hope is with the other switch that I might get lucky and have one set of terminals that is normally closed or at the very least have it not stay slightly depressed. I figured that at the very worst it would be the same as the defrost switch. As far as staying depressed or being normally open so I would be no worse off. Give me time to get the switch in and wire it up and I can come back with a full report.
Old March 7th, 2011, 18:39   #9
kd7iwp
Fuel Economy: http://www.fuelly.com/driver/kd7iwp/golf
I'm in the process of installing ESP in my car. I should send you my old parts and you send me all of your sensors
2002 Golf TDI: FIS instrument cluster, FreakWithRacket HID lights, ESP.
kd7iwp is offline   Reply With Quote
17563 - Manifold Pressure Sensor (G71): Short to Plus, new sensor???? greg123 OBD Scanners 5 November 10th, 2011 23:29
WTB: Thust sensor AKA. map sensor big67 Private TDI Items for Sale/Wanted 0 February 4th, 2010 10:27
Cam Position Sensor & O2 sensor codes? mparker326 VW B5 Passat TDIs 2 March 4th, 2009 11:56
Turbocharger Vane Pos. Sensor/Speed sensor Jools TDI 101 2 March 14th, 2008 05:39
1999.5 fuel temp sensor G81 and displacement sensor G149 freebirdtdi TDI 101 9 March 22nd, 2007 10:08
Page generated in 0.14620 seconds with 10 queries
[Output: 94.14 Kb. compressed to 80.79 Kb. by saving 13.34 Kb. (14.17%)]
