Old February 24th, 2011, 12:23   #1
gtalum
TDI(s): none yet
Default 2005 Passat TDI - Rough Idle Problem
I have a problem, and no local mechanics seem to be able to find it. Our 2005 Passat TDI, with 155,000 miles on it, has started to idle very rough in one specific circumstance: at a stop, brakes applied, in Drive or Reverse gear. When I release the brakes, it smooths out. When I put it in Park or Neutral, it smooths out. It seems to drive fine, no troubles at all otherwise. Any ideas what could cause this issue?
The car has always vibrated, obviously since it's a TDI, but now it feels like it's shaking itself apart just in this specific situation. Any help would be greatly appreciated.
gtalum is offline   Reply With Quote
Old February 24th, 2011, 12:38   #2
Dunno513
Dunno513's Avatar
Fuel Economy: 44.5 lifetime
Dmf Or motor mounts would be my first suspects
Dunno513 is offline   Reply With Quote
Old February 24th, 2011, 12:46   #3
johnboy00
Have the axles ever been replaced? Cheap Chinessium axles cause this problem all the time.
John
2005 Passat Wagon
1999.5 Golf
johnboy00 is offline   Reply With Quote
Old February 24th, 2011, 12:53   #4
aja8888
aja8888's Avatar
Fuel Economy: About as good as it gets!
No DMF in this car (ZF trans).
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
Bring the 1971 Beetle back to life thread:
http://forums.tdiclub.com/showthread.php?t=472400
aja8888 is offline   Reply With Quote
Old February 24th, 2011, 13:02   #5
gtalum
TDI(s): none yet
I'll see if I can take a look at the engine mounts, though I had them replaced once under extended warranty at around 95,000 miles.
I've read about failed CV joints possibly causing this issue too, is that a real possibility?
It seems weird that it's ONLY occurring in one specific circumstance: stopped and in gear.
Old February 24th, 2011, 13:15   #6
aja8888
aja8888's Avatar
If you see red colored stains on the two side motor mounts, they are leaking. There are upgraded motor mounts now available.
If you have bad CV joints (or had them replaced with cheepo Chinese ones), yes, they can cause vibration.
A goofy alternator pulley can make the engine vibrate also.
A chain drive balance shaft assembly that's pretty worn can add to engine vibration.
There is a front engine mount attached to the front cross member that will cause the engine to "lift" if worn and you put the car in gear with your foot on the brake. That could add to the vibration if its worn.
Old February 24th, 2011, 16:28   #7
thundershorts
other than the above menyioned areas to check, have you had the new software update/recall done? it may not fix your vib but it may help and its free.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old February 24th, 2011, 20:39   #8
leobg
Fuel Economy: 39/27/23 U.S. mpg 6/8.7/10 L/100km
I vote "alternator pulley clutch stuck". Check that first if you haven't already.
leobg
2004 Passat GLS TDI (unchained )
leobg is offline   Reply With Quote
Old February 25th, 2011, 05:25   #9
s4phillips
s4phillips's Avatar
Location: Live in d/FW, TX. Transplanted from the Pacific Northwet
...add worn cam to the bottom of the list of things to check. The items already listed should be checked before getting to the cam.
Perform scheduled maintenance; drive more, worry less; balance shaft module; drive more, worry less; torque converter; drive more, worry less...
2005 Passat Wagon TDI w/gear driven buzz reducer and lubricant circulator
2002 Beetle TDI
2003 DL1000K3
s4phillips is offline   Reply With Quote
Old February 25th, 2011, 05:37   #10
JFettig
JFettig's Avatar
I have ridden in a B5.5 that had this symptom that he describes above, when shifted into neutral, the vibrations went away. It wasn't like it was anything the engine or mounts were doing, the trans seemed to invoke it.
Jon
Minnesota Malone Tuning dealer
1998 B5 Passat TDI Compound Turbos
2009 JSW Stage 3 196whp so far
DIY injector calibration http://forums.tdiclub.com/showthread.php?t=383324
JFettig is offline   Reply With Quote
Old February 25th, 2011, 06:38   #11
sirpuddingfoot
sirpuddingfoot's Avatar
The key is that vibration is when you are in gear, using the brakes to keep the car from moving. I suspect it may be a sign of the torque converter's eventual demise. I have noticed that our B5.5 will occasionally not immediately shift fully into gear, as if the torque converter gets stuck half way, then eventually realizes its mistake and clicks on all the way. The really strange part of that is that it doesn't act like its slipping, but more like it is pretending to have an extra gear between 2nd and 3rd and another between 3rd and 4th. I also wonder if perhaps the Chain Drive BSM is slightly out of phase, since it was added to the engine for the precise reason of eliminating that kind of vibration from the automatic transmission, or so I gather from reading.
'05 Passat TDI - Ventectomy - BSM Delete - Nicktane Head with 2u Cat Fuel Filter - MaloneTuning Stage 1.5
'05 Mk4 Jetta TDI - Ventectomy - DG FMJ Panzerplate - HR Sport Springs and 28mm Rear Sway Bar - TT LCA Bushings -Nicktane 1u Fuel Filter - MaloneTuning Stage 1.5 ...for now
sirpuddingfoot is offline   Reply With Quote
Old February 25th, 2011, 06:55   #12
gtalum
TDI(s): none yet
Thanks for all the suggestions. I'll be taking a look this weekend.
Just to add to the mystery, now I notice it's shimmying under hard acceleration from about 30-40 mph.
I haven't noticed any problems in the transmission shifting gears, as it shifts smoothly and at the right times so far. I'll try to pay really close attention to that when I drive home tonight to be sure.
Old February 25th, 2011, 07:08   #13
thundershorts
that would lead me to axles. get the recall flash just the same
Old February 25th, 2011, 11:01   #14
ekkoh99
I had severe vibrations until the serpentine tensioner belt pulley went south.
2005 Passat WGN TDI "Balance shaft upgrade by OilHammer on 3/27/2009" NGK-09 plugs in Jan 2011
ekkoh99 is offline   Reply With Quote
Old February 25th, 2011, 15:11   #15
thundershorts
[QUOTE=gtalum;3305407]Thanks for all the suggestions. I'll be taking a look this weekend.
belts or alt pulley don't cause shimmying, axles are the culprit
Low pwr, rough idle, sputtering in 2005 PD Zampano77 TDI 101 14 January 3rd, 2010 18:15
Rough Idle Problem with Auto trans, ALH and mods FirstOrbit84 TDI 101 1 November 11th, 2008 20:09
Rough Idle and Quantity adjuster problem escore TDI 101 14 August 15th, 2007 18:21
rough idle problem mimpett VW MKIV-A4 TDIs (VE and PD) 17 March 4th, 2005 17:24
Rough idle problem okcjack VW MKIV-A4 TDIs (VE and PD) 18 February 4th, 2004 18:08
Page generated in 0.14566 seconds with 10 queries
[Output: 125.68 Kb. compressed to 104.33 Kb. by saving 21.35 Kb. (16.99%)]
