bhodgkiss
Hi all,
I (still) have a KKK BV43 turbo to go on my AFN 110bhp Passat (longitudinal) engine. I'm aiming for 200bhp. Its the biggest OEM turbo I can bolt straight on, and gets a sensible power that I believe the engine will be able to take. This is what I'm currently planning after some research:
Hardware:
a) BV43 turbo (off 2.0TDI 170bhp BVA/BRD Audi). Part no. 03G145702H. Mint condition, All looks good. Vacuum actuator checked. Compressor blades mint. Not had exhaust side apart as it didn’t want to come apart....only done 40k miles though
b) Standard AFN injector bodies with Bosio R520 5 hole nozzles, pop tested.
c) Ported AFN head. Head skim, 3 angle valve seat, port match manifolds.
d) 7mm valves (as opposed to my current type with 8mm stems). Who makes the OEM valves please? Which engines did the 7mm type come on?
d) Rosten double valve springs (+30% over the single springs I have). Comments on whether these are worth fitting please?
e) PD engine lifters/tappets (the black coated ones). Who makes the OEM items? Are these the best type to go for?
f) 3 bar MAP sensor.
g) Decat pipe – already fitted.
h) PD130 Passat inlet manifold, fully cleaned of gunk.
i) EGR delete, race pipe mod with boost gauge boss.
j) ARP head studs. Required for this power?
k) New gaskets all round – OEM items.
l) Boost gauge – suggestions please? Nothing too expensive, but stepper type with blue/red backlight to match interior required. Seen them for about £45.
m) EGT gauge (there is a boss and sensor on my BV 43 turbo) butnot sure what voltage it requires etc. Any ideas?
n) Keep the current 5spd gearbox. Should be ok for 420Nm?
o) Stick with 228mm clutch but uprate. Southbend or similar. Suggestions please?
please. Something which holds 450Nm but feels stock.
p) Change to a single mass flywheel? Suggestions/comments here please.
Software:
- To give 1.7bar max boost, so ~25psi. Sensible for this turbo I believe (19psi standard)
Other questions:
1) Will my stock AFN crank/rods/pistons take this increase in power?
2) Are the R520 5 holes the best option for this power level in terms of efficiency/EGTs?
3) Is a new OEM head gasket sufficient? Or are there better gaskets I can fit?
4) Will changing my OEM side mount intercooler give any real benefit? FMIC required? Is pressure drop and efficiency data available for intercoolers?
5) Pipes – do any OEM pipes work with my installation, or do I need custom pipes to/from turbo?
6) Is it a good idea to drop the compression ratio with PD100 pistons? What max combustion pressure is safe please?
7) Anything else required? 11mm fuel pump? Lift pump? Will i achieve 200bhp with a 10mm item? Or will it be asking too much of the pump?
8) While the head is off, i can look at the cylinder and piston conditions. What is the upper limit on bore wear please before it becomes an issue? 79.5mm is nominal I believe.
9) What tools do i need for cambelt timing on the AFN and any installation tips for fitting turbo (how to run in the head, ensure oil supply to turbo on first startup etc etc)
Any help is greatly appreciated, I have numbered the items so its easier to see which comments you’re referring to in your replies.
Many thanks
Hardware:
Software:
Other questions:
Many thanks
