Old February 23rd, 2011, 13:45   #1
mattds
TDI(s): 06 jetta
Default Is the driver side door wiring harness issue covered under the warranty?
Hi there,
I have an 06 with an extended new car warranty and I've noticed that the 'open door' symbol does not come on when i open the driver side door and the lights don't come on...and the boot is torn a bit...is this coverd under the warranty? If not i can prob fix myself....
M
2006 Jetta TDI Pkg 1, Malone Tuning Stage 2+ , in dash NAV/DVD, 2" drop, 18" Huffs, SG II
mattds is offline   Reply With Quote
Old February 23rd, 2011, 15:50   #2
El Dobro
El Dobro's Avatar
TDI(s): 2014 Volt
Fuel Economy: 120 MPGe
Extended warranties vary, so you'll have to check with the dealer or the warranty company.
"Drink the Kool-Aid" -Jim Jones
"Baa-baa-baa" -Sheep
"He's opening our minds to new ideas, KILL HIM!!!" -Futurama
Now, I drive more, worry less.
Penguin -The other white meat.
El Dobro is offline   Reply With Quote
Old February 23rd, 2011, 19:38   #3
mattds
TDI(s): 06 jetta
it' the VW factory warranty
Old February 23rd, 2011, 20:11   #4
El Dobro
El Dobro's Avatar
TDI(s): 2014 Volt
You still have to ask the service writer if it's covered. Sometimes, there are different grades of coverage.
Old February 23rd, 2011, 21:20   #5
Deansel
We have an '06 Jetta TDi and I had to repair the drivers door wiring harness today - took about 5 hours to splice all of the wires. Nothing on the drivers door worked except for the speakers. Two of the main wires were severed and about half of them had cracked insulation and were close to failing.
Does anyone know how much a new door harness runs?
'06 Jetta TDI - Blue Graphite - DSG - Pkg One
'07 Silverado 2500 - Extended cab
Deansel is offline   Reply With Quote
Old February 23rd, 2011, 22:09   #6
Mach1
Fuel Economy: 49.3, 48, 21.2,19.99
Its covered in the 3/36, but I dont think its covered on the 5/60 drivetrain warrantee.
The harnesses are $150, depending on where purchased..Its a big job to dismantle the entire door to do the harness...
http://www.rsbdiesel.com/
2006.5 DE DSG, RC2, Sunroof, Rear airbags, 73K miles, 61MPG best.
2005.5 Jetta-5 SP, LSD, Spec S2, 110K, 48 mpg every tank. Best-49.3 mpg-LOCAL. ELF 506 0-30W/15K OCI/37PPM FE, Best=740 MPT, RSB Diesel custom 2.5DP/3" SS exhaust, Synthetic fuel, Koni lowering springs. One of the first Mark V Jettas to hit the street. Pkg 1, MFD, Autowipe, Auto-headlights, Auto-dim mirror, auto-climate. 248C=150HP RC2
2004 6L 89000 19MPG
2000 7.3 388 HP-818 FT lbs Propane
Mach1 is offline   Reply With Quote
2006 Driver Side Door Issue edemusmaximus VW MKV-A5 Golf/Jettas 3 January 27th, 2011 08:55
Driver side door lock issue with key only Crispy TDI 101 8 October 5th, 2009 09:22
Problem: Driver side door light issue bostondeezel Eastern USA 2 November 22nd, 2008 19:31
driver side door wire harness issues... noairbag VW MKIV-A4 TDIs (VE and PD) 3 July 25th, 2008 01:06
95-97 Passat pass side front door/driver side rear door 79veedub Private TDI Items for Sale/Wanted 0 September 11th, 2007 05:54
Page generated in 0.17460 seconds with 10 queries
[Output: 74.05 Kb. compressed to 64.66 Kb. by saving 9.40 Kb. (12.69%)]
