Old February 21st, 2011, 20:48   #1
Fuel Economy: 42-45
Default P0725 engine speed circuit malfunction
One morning had a hard start after several cranks my Jetta started engine check light P0725 engine speed circuit malfunction? I have changed the speed sensor a couple months ago when I noticed the code the first time and here it is again?? After reading some post I was thinking maybe the fuel lift pump may be causing my intermittent hard start. I have 277,198 miles on my 2004 and maybe that lift pump may not be working??? As soon as I get the wiring diagram I will check current to the pump to see if it is operating. Let me know if anyone has any similar problem. Thanks!
cobraser is offline   Reply With Quote
Glow plug circuit malfunction emp3283 TDI 101 5 October 28th, 2009 19:15
P0725-Engine Speed Sensor Malfunction sdeck TDI 101 4 May 13th, 2009 12:55
Help with CEL: Glow Plug Circuit Malfunction MyAvocation VW MKIV-A4 TDIs (VE and PD) 9 November 19th, 2004 12:08
engine code - Glow plug circuit malfunction Zarnok VW MKIV-A4 TDIs (VE and PD) 6 February 26th, 2004 09:33
Glow Plug Circuit Malfunction... spoilsport VW MKIV-A4 TDIs (VE and PD) 22 October 2nd, 2002 00:39
Page generated in 0.11852 seconds with 10 queries
[Output: 46.27 Kb. compressed to 43.60 Kb. by saving 2.67 Kb. (5.77%)]
