Old February 20th, 2011, 18:45   #1
duramax/tdi
duramax/tdi's Avatar
Default 01 JETTA low BEAMS wont WORK? Help...
I have been having problems for the past few weeks from my 2001 vw jetta tdi. At first the low beams would flicker on of for a few seconds didnt think nothing of it. till it was getting harder to keep them on, From brights to low's. Finally one day the low beams would not come on? brights and all other lights come on gerate.
Iv changed, or checked the following. fuses, balbs and the switch to turn the lights on or off in the dash. Is there a known problem? i have been resercing on the net this is my last resort before i have to go to the delership, any thoughts?
2001, VW jetta, tdi, forest green!!!
all stock. DD
work/play, 2003 chevy duramax, 500+ rwhp
duramax/tdi is offline   Reply With Quote
Old February 20th, 2011, 19:03   #2
Seatman
Seatman's Avatar
Fuel Economy: No idea
Is there maybe a relay somewhere for them? That might be worth looking into
Seatman is offline   Reply With Quote
Old February 20th, 2011, 19:08   #3
jeff@mcm
Fuel Economy: dismal, but fun
Most likely cause is the turn signal/combination switch. The circuit goes through that switch as well due to high beam control.
jeff@mcm is offline   Reply With Quote
Old February 20th, 2011, 19:08   #4
duramax/tdi
Tommorow i was going to check into that im planning on testing the volts comming into the relay and out hope its just a realy ill keep you posted.
all stock. DD
Old February 20th, 2011, 19:11   #5
duramax/tdi
Is there any way of checking the switch before buying a new one? I already bought the (on, off switch) that cost me $30 and napa wont do refunds for electrical parts.
all stock. DD
Old April 8th, 2011, 09:40   #6
duramax/tdi
Sorry didnt get back sooner. I did find out what it was.. It was the actuator switch in the steering collom, as said above ^^^^. i took the car to the dealer cost me 450$ would of done it myself as i do 95% of the work on my cars/trucks just didnt have time and the whole taken the steering wheel off and air bag scares me. thanks for the imput guys...
all stock. DD
low beams do not work , DRL's do , high beams do work also timbob3k VW MKIV-A4 TDIs (VE and PD) 26 August 7th, 2015 16:33
Low beams out after work done. dale_p TDI 101 4 August 28th, 2008 09:37
Low-Beams Don't Work Ferg TDI 101 7 September 19th, 2007 20:28
No Low Beams, I'm at work and can't go home DothanTDI VW MKIV-A4 TDIs (VE and PD) 18 February 3rd, 2005 09:46
Low beams out, high beams still work both sides Doug Hanz VW MKIV-A4 TDIs (VE and PD) 4 November 25th, 2003 23:48
Page generated in 0.15907 seconds with 10 queries
[Output: 75.59 Kb. compressed to 66.13 Kb. by saving 9.46 Kb. (12.51%)]
