Old February 20th, 2011, 07:45   #1
hymato
Default 2010 jetta Battery light on
2600 miles on my jetta and the battery light came on last night while driving home. I went to check the car this am and it fired right up, but the battery light is still on. I've had the battery go dead on me once but I charged it back up and everything has been fine since. Any ideas afraid car might die on me waiting for VW to open to see if I can get loaner car. Thanks Chris
hymato is offline   Reply With Quote
Old February 20th, 2011, 07:51   #2
NovaMoto
NovaMoto's Avatar
TDI(s): '11 TDI Golf
If the battery light is on I'd check the alternator. I also wouldn't drive it for fear of breaking down!
NovaMoto is offline   Reply With Quote
Old February 20th, 2011, 07:53   #3
hymato
Well if the alternator dumps while i'm driving how long can I go on just the battery?
Old February 20th, 2011, 08:04   #4
NovaMoto
NovaMoto's Avatar
That light means there's a charging problem. You need it looked at ASAP before the car shuts down on you - hopefully not in traffic.
Old February 20th, 2011, 08:05   #5
hymato
hopefully VW just gives me a loaner car today or I'm gonna be pissed
Old February 20th, 2011, 08:17   #6
hymato
Has anyone had this happen to them before?
Old February 20th, 2011, 08:52   #7
PlaneJob
PlaneJob's Avatar
TDI(s): 2010 JSW TDI
Fuel Economy: 41.9 mpg
Chances are, the alternator has already 'dumped' and that is *why* the light is on. SO you are driving on borrowed time now.
Anything that draws electrical power is going to reduce your drive time. Think Apollo 13 - you need to shut down everything that is not absolutely required. Use the turn signal stalk to disable the DRLs, turn off the radio, turn off the nav, do not plug you cell phone charger in, make sure the dome lights are off, do not turn the headlights on (read: don't drive at night).
I would wag that you could go 30 to 60 minutes before a fully charged battery dies.
On older diesels you could drive indefinitely without an alternator or battery. You snipped the fuel shut off plunger off at the injector pump and once you got it started (push starting...) it would run until you stalled it (the key would not shut it off, as it was all mechanical at that point).
The newer diesels use electricity to power up the fuel pumps, ECU, injectors, crank timing sensors, etc. The electrical load is pretty high even with the non-essentials powered down.
2010 Platinum Grey JSW, 03/10 build date, 6M, 9w3, non-holy roof, MDI, mudflaps, Monster Mats, 35/20 tint, color matched cheese blocks
PlaneJob is offline   Reply With Quote
Old February 20th, 2011, 08:57   #8
OldManWinter
Can't say that I have, but I was talking with a fellow tdi owner at the dealership on Friday and his 2004 is having alternator problems and his battery went flat and he had to coast the last two blocks into the dealership since his fuel pump stopped.
OldManWinter is offline   Reply With Quote
Old February 20th, 2011, 09:43   #9
hymato
I just got off the phone with the dealership and I told them the alternator is done and I need a loaner car. And I got told call back Monday when the service dept opens. What a bunch of #$@%
Old February 20th, 2011, 10:05   #10
PlaneJob
PlaneJob's Avatar
It's pretty normal to have to wait until the service department is open to get service.
It's also always a bad idea to tell the shop what is broken. Tell them the symptoms/indications. Let them determine the cause.
In a non-warranty situation if you walked into the shop and declared that the alternator was bad and you wanted a new one, the dealer just might put a new alternator on without checking anything else. When you get the car back and the light is still on.. the dealer will say, "You said the alternator was bad and wanted a new one - you never asked us to troubleshoot the light".
Old February 20th, 2011, 10:50   #11
Ski in NC
Fuel Economy: 48-52 typical
Get a digital voltmeter and check battery voltage at the battery terminals with engine running. 13.5 to 14.5 Vdc and alternator is keeping battery up, meaning you can probably drive as far as you wish. 12.0 to 12.6 Vdc, and alternator is doing nothing and battery will eventually go dead. Under 12 and battery is pretty well discharged and it will not drive far before it quits.
Put a battery charger on to top it up before you drive and that will extend your range.
Home Depot, walmart, any hardware store will have a digital voltmeter for 20-50 bucks or so.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old February 20th, 2011, 11:10   #12
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
Agreed to all posts above.
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old February 20th, 2011, 15:01   #13
ihatespeed
Guest
if you don't want to buy the meter, autozone will check the charging system for you. but a meter is real handy for all sorts of troubleshooting around the house and garage, well worth the bucks.
Old February 22nd, 2011, 08:33   #14
MayorDJQ
I wouldn't have expected the dealership to do much on a Sunday...of Presidents' Day weekend, when many dealerships are running big sales.
Instead of screwing around with Autozone, call VW Roadside Assistance and let them tow it to the nearest dealer. Then go rent a car. After your car is repaired under WARRANTY, submit the car rental receipt to VWRA for reimbursement.
MayorDJQ is offline   Reply With Quote
Old February 25th, 2011, 13:11   #15
hymato
Turns out the bolt for the belt tensioner walked out and everything was spinning. I ended up doing what you said just calling VW roadside assistance had the car towed and went a rented a tiguan lol
Oil light flashing while battery light is on 97 VW Jetta Twinn TDI 101 8 January 2nd, 2012 16:07
Battery light, ABS light, Airbag light + really loud (like a tractor trailer) digdug VW MKIV-A4 TDIs (VE and PD) 4 July 28th, 2010 18:51
2010 Jetta Fog light JdubsTDI VW MKV-A5 Golf/Jettas 23 April 12th, 2010 19:10
2001 Jetta TDI battery light on smokemac VW MKIV-A4 TDIs (VE and PD) 5 August 31st, 2007 17:47
01 Jetta Battery Light gbillman VW MKIV-A4 TDIs (VE and PD) 3 February 9th, 2004 14:54
Page generated in 0.16899 seconds with 10 queries
[Output: 122.00 Kb. compressed to 101.60 Kb. by saving 20.40 Kb. (16.72%)]
