Old February 19th, 2011, 12:45   #1
TDIronworker
TDI(s): 2000 Jetta
Fuel Economy: 46
Default Oil filter cap leak
Hey all, I have a problem that I can't solve. It seems that no matter what I try to do, tighten to cap more, loosen the cap a little, new filter, new O rings, new filter and O rings AGAIN!!!. I can't stop the leak from between the cap and housing. After each time I try, it seems the leak will be in a different spot. I marked the cap, removed and replaced cap, leak in totally different area.
Has anyone been through this before??
TDIronworker is offline   Reply With Quote
Old February 19th, 2011, 13:01   #2
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Are you putting the O-ring in the correct spot? It MUST be in the groove that is in the cap. When you tighten, the o-ring should go between the metal filter housing and plastic filter cap.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old February 19th, 2011, 13:22   #3
nate379
nate379's Avatar
TDI(s): 05 Jetta
cap is available at the parts store, I got mine at Napa I believe around $20.
05 Jetta 4th Gen.
nate379 is offline   Reply With Quote
Old February 19th, 2011, 13:24   #4
TDIronworker
TDI(s): 2000 Jetta
Fuel Economy: 46
It is in the correct place. I have owned this car since new and now it has 270,000 miles and I have done almost all of the oil changes myself. I have never had this happen and it started about 5000 miles after an oil change if that helps.
Leak around the oil cap seekthejoy TDI 101 14 April 19th, 2015 09:06
Oil Filter Cap Leaking? High Oil Pressure? Jeepmb VW MKIV-A4 TDIs (VE and PD) 16 January 20th, 2010 04:42
Help Needed: Oil Filter Cap Leak subdvr99 VW MKV-A5 Golf/Jettas 11 December 6th, 2008 08:45
Oil leak filler cap - 2.0 TDI PD Dutch VW MKV-A5 Golf/Jettas 13 September 28th, 2008 12:40
oil fill cap/valve cover oil leak theotherskip VW MKIV-A4 TDIs (VE and PD) 3 December 19th, 2004 19:14
Page generated in 0.13917 seconds with 10 queries
[Output: 63.08 Kb. compressed to 56.46 Kb. by saving 6.63 Kb. (10.50%)]
