Old February 17th, 2011, 18:48   #1
Bdpprocessors
Fuel Economy: L 37/ H 52 avg 43
Default Tdi slow start hot and cold.
Im having slow starts about 10 seconds cold and 5 or 6 hot on my 99.5 tdi jetta. It started after i changed my fuel filter ( i cranked the motor quite a bit til it started about 10 mins. Letting the starter rest every 10 seconds for 30 seconds).
Ive done some testing. And the car starts up with the coolant tem sensor unplugged. So i replaced it with the one from napa and this did nothing.
I also unplugged the glow plug harness and coolant temp sensor and it fired right up. Which leads me to believe theres a fuel pressure problem at start up when the sensor is plugged in .
Is there a way to test this in vcds.
Is it possible that my starter is not spinning fast enough
Is there a way to raise start up pressure or ammt in vcds?
Thanks for any help
Bdpprocessors is offline   Reply With Quote
Old February 19th, 2011, 10:01   #2
Danno!
Fuel Economy: HIS avg 53 mpg@60 HERS 48 mpg@60
I replaced my starter because it was the only thing left that prevented my car from starting cold weather. Not only does the car crank over in bitter cold now, but it surprisingly fixed the hot starting problem that has plagued the car since the day I bought it.
It all has to do with cranking speed.
Danno! is offline   Reply With Quote
Old February 19th, 2011, 10:15   #3
Bdpprocessors
Thanks! I guess thqtll b next. But what gets me is it starts perfect withou the coolan temp sensor plugged in
Old February 19th, 2011, 11:28   #4
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
There's glitch in the ECU that does not allow fueling if the engine spins less than ~250RPM. When it's cold(ie unplugging the temp sensor), the engine uses a cold start map and it brings it out of a glitch area.
If you do a search there is a HUGE thread on this very topic.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old February 19th, 2011, 11:48   #5
Bdpprocessors
That makes sense. So ill need a new starter. Is there a way to fix this in vcds or do you need a tune to fix it?
Old February 19th, 2011, 13:49   #6
Dana Hanchett
TDI(s): 2011
Check your fuel injection timing. If it's not in the upper range it will not start quickly. Hope this helps.
Dana Hanchett is offline   Reply With Quote
Old February 19th, 2011, 13:58   #7
Bdpprocessors
What block ?
Old February 19th, 2011, 14:05   #8
turbocharged798
Group 000, hit go, switch to basic setting, hit tdi timing. Select ALH from the drop down menu.
Old February 19th, 2011, 14:23   #9
Bdpprocessors
It bounces from dead On to slightly retarded. But the car started fine brior to replacing the fuel filter and cranking it alot toget it started
Old February 19th, 2011, 18:19   #10
lifer
Replace the starter. VW starters seem to like to draw a huge amount of power when they start going bad. It has been that way for years. I had an 86 TD did the same thing . I just put a starter in my 2000 jetta 5 or 6 weeks ago that was doing the same thing. If you can wait a few days you can order one from ebay. I got a high torque starter brand new for $79 on ebay. I believe it was from california starter. Just make sure you get the high torque 2 kw starter. The one I got works great even in sub zero temps. The car starts like new now.
lifer is offline   Reply With Quote
Old February 19th, 2011, 18:25   #11
Bdpprocessors
Sweet that definantally beats 130 from the parts stores here. Ill order it today and put it on next week! Strange thing is. I just got in the car and its cranking up perfectly fine now.... Its been taking a long time the past two weeks. But now its fine. Ill order it just to be safe
Old February 19th, 2011, 18:46   #12
TheBullwinkle
Next fuel filter interval fill the new filter with diesel or a power service additive that can be found pretty much anywhere. She'll start right up with no wear on the starter. Hope u get it figured out.
I can't be wrong all the time, I'm not that consistent!
TheBullwinkle is offline   Reply With Quote
Old February 19th, 2011, 18:51   #13
Bdpprocessors
Im sure i just destroyed the brushes on it when i was oriming the system
Old February 19th, 2011, 19:13   #14
turbocharged798
I would recommend nothing less than a Bosch reman starter if you are going to replace it.
Old February 19th, 2011, 20:33   #15
Frank M
BANNED
TDI(s): NB
Why not do a little trouble shooting before you replace an expensive starter it may not need anyway.
Since this occurred right after replacing the fuel filter try to determine if you fuel is draining back into the tank due to an air breach.
check the o-rings are sealed on the thermostatic T and check if all hoses are snug where they attach to the filter. Perhaps the T cracked and is letting air into the system after shut down.
The last thing one should do when buying parts is to buy quality parts from a known source. If you find your starter has really failed buy a quality one such as the Bosch or better yet take it apart and replace the brushes as 95% of the time this is all that is needed to repair a starter.
Fixing a car the shotgun method not prudent, especially in light of INTERNET forums with good advice from experienced technicians.
Trouble shoot don't just shoot.
Frank M is offline   Reply With Quote
Slow Cold Start: Something Different... Stealth TDI TDI 101 23 December 21st, 2008 18:15
knocking on cold start, very difficult hot-start eli VW MKV-A5 Golf/Jettas 14 December 9th, 2007 18:59
2002 Jetta slow cold start, sometimes slow hot start PSDExcursion VW MKIV-A4 TDIs (VE and PD) 3 November 25th, 2007 09:17
Reason for slow hot restart & cold no start. dbain VW MKIV-A4 TDIs (VE and PD) 1 February 18th, 2004 08:16
TDI 115hp - "Hot Start" vs "Cold Start" SmokingSoul TDI 101 6 December 23rd, 2003 05:12
Page generated in 0.16689 seconds with 10 queries
[Output: 123.12 Kb. compressed to 102.67 Kb. by saving 20.45 Kb. (16.61%)]
