Herm TDI
- Joined
- Nov 21, 2001
- TDI
- 2002 Golf GLS Malone Stage 3, P+520 nozzles, 11MM Inj pump, Sachs VR6 clutch, Stelth Race Pipe, Immo Deleat, EGR Deleat
A-4 Platform front coil spring information
This info is from ETKA:
This data applies to the sedan and the wagon
By no means is this information all inclusive. I'm providing the high to low range for the stock configured A-4 platform.
Color Code & PN / spring compression rate Lbs per in
- 1 Pink 2 Green 357-411-105-T / 142 Lbs (Non-Sport)
- 1 Violet 2 White 1J0-411-105-AE / 143 LBS (Non-Sport)
- 1 Violet 1 White 1J0-411-105-AD / 146 Lbs (Non-Sport)
- 2 Green 2 Blue 1J0-411-105-C / 149 LBs (Non- Sport)
- 2 Violet 2 Pink 1J0-411-105-BK / 155 Lbs (Non-Sport)
- 1 Violet 2 Yellow 1J0-411-105-AG / 161 Lbs (Non-Sport)
- 3 Pink 1 Green 1J0-411-105-P / 170.5 Lbs (Non-Sport)
- 4 Pink 2 Green 357-411-105-AF / 170 Lbs (Non-Sport)
- 2 White 4 Blue 1J0-411-105-CL / 175 Lbs (Non-Sport)
- 1 Violet 4 Pink 1J0-411-105 AR / 2002 Jetta Wgn (Non-Sport)
