Old February 11th, 2011, 15:23   #1
RalphVa
TDI(s): Jetta
Default Full size spare in 2009/2010s?
I pulled the spare out of our 2010 Jetta today to check its pressure. It is larger than the typical donut spare like is in our Cabrio.
Wonder if it'll take a normal sized wheel and tire? The 17 inchers may be too wide.
Ralph
The natural gardener
God's original intent
RalphVa is offline   Reply With Quote
Old February 11th, 2011, 15:24   #2
MPBsr
The spare in my 09 is a smaller rim size and tire, but not a donut.
MPBsr is offline   Reply With Quote
Old February 11th, 2011, 15:34   #3
MayorDJQ
VW has been using full size spares for years. What year is the Cabby? Does it have a trunk large enough to accommodate a full size spare?
My '09 had a full size, 91H rated real tire for a spare. I got a flat in eastern Washington state and installed it. I figured I'd get it fixed the next day, but drove all the way back to Massachusetts on it without a problem.
My '10 also has a full size, I'm assuming it's a real tire.
MayorDJQ is offline   Reply With Quote
Old February 11th, 2011, 15:52   #4
dubStrom
dubStrom's Avatar
Default JSW gets full size spare?
My 2010 JSW has the same full size model/brand of tire that is on the four wheels on the ground, but on a steel wheel instead. It was my assumption that this was the case for the 2010 Jetta as well. Wow. The JSW really has so many standard features. It is surprising.
Lost my JSW to a reckless MB E350 sedan driver blowing a stoplight:
http://forums.tdiclub.com/showthread.php?t=472255
Working on a replacement project:
http://forums.tdiclub.com/showthread.php?t=472257
dubStrom is offline   Reply With Quote
Old February 11th, 2011, 18:23   #5
El Dobro
El Dobro's Avatar
TDI(s): 2014 Volt
Fuel Economy: 120 MPGe
The spare has a 15" rim, but the outer diameter of the tire is the same as the 16" rims on the car.
"Drink the Kool-Aid" -Jim Jones
"Baa-baa-baa" -Sheep
"He's opening our minds to new ideas, KILL HIM!!!" -Futurama
Now, I drive more, worry less.
Penguin -The other white meat.
El Dobro is offline   Reply With Quote
Old February 11th, 2011, 18:43   #6
deezelpower
deezelpower's Avatar
Fuel Economy: ~40 combined city and highway with spirited driving habits.
My wife's 2010 has a 195/65-15 as spare. Still has the silly 45 MPH max sticker, even though the weight and speed ratings are OEM equivalent......
Since tire diameters of 15/16/17's of most jettas are the same and would fit in spare, I'm sure it was due to costs and weight savings.
2015 Audi Q7 TDI Prem+, Tow, Hot/Cool Pkg, 20", 21K (hers+Twins) acquired 10d before stop-sale!
2004 Jetta GLS TDI 5-sp, Kerma Q, 17" Goals, GLI Brakes, DarkSide SMIC, 214K (mine)
1974 Super Beetle Red
deezelpower is offline   Reply With Quote
Old February 11th, 2011, 19:04   #7
MayorDJQ
It's probably a liability/legal requirement. I peeled it off when I installed the spare on my '09.
Old February 11th, 2011, 19:58   #8
El Dobro
El Dobro's Avatar
TDI(s): 2014 Volt
It was probably from workers that were told to put the sticker on all spares.
Old February 11th, 2011, 23:11   #9
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
All sedans with the base 16" alloys will (should) have a 15" steel wheel for the spare. The sedans have the 288mm brakes and can get away with a 15" spare.
All JSW's have the upgraded 312mm brakes that you would find on the 2.0T (gasser) and a 15" wheel will not fit. So Vw HAD to put in a 16" spare.
They are all full size, properly load and speed rated tire. But the bright yellow sticker is there to remind the owner that they are still on the spare and may not have a good 5th wheel should something happen.
I believe the '11 Jetta sedans may have gone back to a space saver spare as a measure of cost cutting.
Fixmy59bug is offline   Reply With Quote
Old February 12th, 2011, 05:03   #10
RalphVa
TDI(s): Jetta
Wonder if there's a weight saving for buying a new alloy wheel to match the others on the car vs. the steel wheel spare. The wife scraped up the one alloy wheel in the back. Damaged the finish but didn't bend it. Could put it in as a spare. (Likely the jack wouldn't fit inside as nicely as it does on this factory spare rim.)
I remember once in the 240D's life that I bought another rim to put a snow tire onto. First bought a steel rim because of price difference. When I got it home and found the HUGE weight difference for the alloy ones vs. the steel one, I went back and traded it for an alloy rim. The 240D alloy rims looked EXACTLY like steel rims in those days. The spare rim was exactly the same alloy as the other 4.
Ralph
Old February 12th, 2011, 07:55   #11
MayorDJQ
Since you have an '09, do you have Bioline wheels? They're pretty readily available. Shop around in the classifieds here, and the tires/wheels section on vwvortex. You should have no problem finding a single Bioline.
Old February 12th, 2011, 15:23   #12
RalphVa
TDI(s): Jetta
Ours is a 2010 Jetta.
Ralph
Old February 14th, 2011, 14:01   #13
dubStrom
dubStrom's Avatar
Of course. I forgot about those brakes. No wonder I got a full size tire.
FS: Full size mk4 spare tires andrew1984 Private TDI Items for Sale/Wanted 0 September 2nd, 2010 09:31
Does the 2009 TDI have a full spare? TDI 4 RD VW MKV-A5 Golf/Jettas 20 October 25th, 2008 15:30
Full size spare blows out after 100 miles Lineman General VW Discussion 20 August 4th, 2003 16:40
Thank you VW for full size spare. 03GolfTDI General VW Discussion 21 July 7th, 2003 15:17
Will A Full Size Tire Fit in a (A3) Spare Tire Well? Ric Woodruff VW MKIV-A4 TDIs (VE and PD) 10 September 4th, 1999 00:41
Page generated in 0.16098 seconds with 10 queries
[Output: 115.53 Kb. compressed to 96.96 Kb. by saving 18.57 Kb. (16.07%)]
