Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI News/Tech
TDI News/Tech This Forum is for the posting of TDI news related items.
Old February 26th, 2012, 11:40   #2881
DPM
Fuel Economy: 38.5- 47 Forester, Citroen 55- 63
was a problem ten years ago, don't seem to hear of problems any more.
DPM is offline   Reply With Quote
Old February 26th, 2012, 12:04   #2882
pleopard
pleopard's Avatar
Originally Posted by PaulGiz View Post
As this thread gets longer, we drift away from the thing that is most important here. It us not the fact that the HPFP can fail, all compnonts can fail. It is not the frequency of failure -- honestly on the scale of mechanical reliability it isn't all that bad.
It is the fact that the design of the fueling system is such that the failure necessitates its complete replacement, to the tune of $8,000 +.
It is unreasonable to think this is okay, especially for a $26,000 "family" vehicle.
I love my JSW. For well under thirty grand it is a bargain. For $34,000 or $42,000, not so much. I shouldn't have to start an escrow account just to make sure my car can continue to run.
P.
Sent from my Sensation using Tapatalk
Absolutely. We must all remain fully aware of this.
'10 Jetta 2.0 TDI, DSG
pleopard is offline   Reply With Quote
Old February 27th, 2012, 07:42   #2883
Absolute Diesel
Absolute Diesel's Avatar
To answer a few questions earlier: The dealer had no explanation for the failure. The fuel looked fine and the repair was covered under warranty. The fuel was from PA which has a B5 mandate. I always fuel from one of 3 stations in the area unless on a road trip out town. This failure occurred on a tank from one of my usual stations. Car was driven gently except 1 time driving someone to the ER.
Yeah I guess I could've had contaminated fuel a some point. It wasn't the final tank though.
The pump design sucks - I think we can all agree on that. A bad tank of diesel here or there should not cause a catastrophic failure. At worst it should just ruin my pump and not the whole fuel system. It's the 8K repair bill that is unacceptable, not the failure itself.
While mulling over the decision of keep vs. sell, I was given a company car which made the decision easy. When I have to return this company car I'd love to come back to TDI's if this problem is sorted out. loved the car, but this pump design is BS.
Absolute Diesel is offline   Reply With Quote
Old February 27th, 2012, 12:15   #2884
Derrel H Green
Derrel H Green's Avatar
Fuel Economy: Check my Fuelly
Question Any MBZ Failures
Originally Posted by jbright View Post
I'd love to know the HPFP catastrophic failure numbers for all cars with CR engines across the EU.
Is anyone anywhere reporting failures with their MBZ CR diesels?
Sure hope I did not jump from the frying pan into the fire!
Derrel
2010 JSW. Reflex Silver/Titan Interior. A TDI with DSG.
Dynoed 132 HP, 230 ft/lb torque at the wheels.
Traded the VW for a Mercedes Benz W-211 E-320 CDI 12-17-2011.
Dynoed 12-01-12 211 HP, 386 ft/lb torque at the wheels.
View my MBZ E-320 CDI Fuelly: http://www.fuelly.com/driver/derrelhgreen/E320
Compare our previous VW TDI JSW DSG Fuelly : http://www.fuelly.com/driver/derrelhgreen/Jetta
Derrel H Green is offline   Reply With Quote
Old February 27th, 2012, 14:00   #2885
sudseh
Originally Posted by Lightflyer1 View Post
They do.
Introducing our new B5 Syndiesel (R). This is the new spec fuel for the VW Jetta TDI Cup and it's available ONLY AT HYPERFUELS!!!
But at over $10 a gallon, I don't think anyone is going to be buying it as a primary fuel for their car.
$140/fillup vs $8000 for the system.
i'll take my chances.
sudseh is offline   Reply With Quote
Old February 27th, 2012, 14:13   #2886
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
If only you could be sure that would save the pump.
tditom is offline   Reply With Quote
Old February 27th, 2012, 14:40   #2887
Softrockrenegade
Softrockrenegade's Avatar
Nobody is sure what will save the pump !!! Nobody is sure if this really is a problem beyond a few bad pumps ... All we know is the collateral damage is huge !
Softrockrenegade is offline   Reply With Quote
Old February 27th, 2012, 15:03   #2888
tdipoet
tdipoet's Avatar
Fuel Economy: 1 Hojillion MPG
that's the problem. what could be a minor design issue is a freaking time bomb.
tdipoet is offline   Reply With Quote
Old February 27th, 2012, 16:01   #2889
Softrockrenegade
Excuse this question from a diesel noob , but if any other manufactures common rail HPFP were to fail are there provisions to prevent contaminants to the rail and injectors ? Everyone keeps saying poor design but how much does the flow path differ in our CR TDI's from any other non failing CR fuel system ?
Old February 27th, 2012, 16:18   #2890
tditom
I agree with DPM above where he posted that all the designs would spread the shrapnel thoughout the system. The design issue is covered in depth with the threads by dwiesel, eddif, and oilhammer covering the root cause of the failures. I think we've seen enough of these failures now to conclude that they aren't all caused by substandard lubricity. This leads me to conclude that the design itself is weak.
-tom
autos: 15 Volvo V60, 08 MB E320 Bluetec
Find your VW part numbers here.
Why I recommend fuel additive.
Old February 27th, 2012, 18:07   #2891
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
I agree with you. After all if the failures were only related to poor fuel, then we would all be on at least our second pump, maybe third or fourth.
2010 silver/black JSW TDI with DSG, 2011 red Golf TDI with dsg, 2003 red/gray Passat 1.8l gasser
kjclow is offline   Reply With Quote
Old February 27th, 2012, 18:15   #2892
darrelld
darrelld's Avatar
Fuel Economy: Fuelly
HPFP FAQ
http://www.e90post.com/forums/showthread.php?t=333519
darrelld is offline   Reply With Quote
Old February 27th, 2012, 18:21   #2893
tditom
Originally Posted by darrelld View Post
That is referring to gasoline HPFP failures. Primarily the 335i, if memory serves.
Old February 27th, 2012, 18:25   #2894
darrelld
darrelld's Avatar
I know, but all the defective pumps were made by Bosch. If you read toward the end of the post it appears BMW switched to Continental HPFP designs and was retrofitting failed pumps with the new Continental design.
VW appears to be following a similar tract with changing pump manufacturers at least according to the NHTSA inquires with some Blue Motion models. Have yet to see any retrofits from VW.
Old February 28th, 2012, 05:53   #2895
kjclow
Then the question becomes, will VW replace all the Bosch pumps on a recall or only replace them under double secret warranty after one fails.
HPFP Failure in V6 TDI, or only in 2.0 CR? Trooper81 Fuels & Lubricants 65 May 30th, 2014 18:52
CR High Pressure Fuel Pump "HPFP" failure FAQ - Updated 2/8/2011 dzcad90 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 0 June 28th, 2010 13:52
Good Job! NHTSA investigation candywhite VW MKV-A5 Golf/Jettas 15 July 28th, 2009 02:26
NHTSA opens investigation on DSG transmisisons dieselyeti VW MKV-A5 Golf/Jettas 1 July 24th, 2009 11:07
Page generated in 0.21762 seconds with 10 queries
[Output: 135.65 Kb. compressed to 114.00 Kb. by saving 21.65 Kb. (15.96%)]
