Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI News/Tech
TDI News/Tech This Forum is for the posting of TDI news related items.
Old November 19th, 2011, 18:15   #2131
manual_tranny
Smyth Performance- Intern
manual_tranny's Avatar
Fuel Economy: Is just one piece of the puzzle that is our bottomless appetite for oil. Cars don’t have to be consumable. Instead of throwing them away, we can rebuild them, better. We have the technology.
Originally Posted by Tarbe View Post
Good grief! You can't possibly believe this....
You too??
You guys just need to sell your cars.
Wait... when did HPFP failure become a conspiracy?
I met a guy who works for Bosch recently. I mentioned what was happening and he said "we don't like to talk about..." those words drifted off and he left to get to a meeting.
This car saves more than 150,000mi worth of oil from being used before you've even turned the key: Smyth Performance
Common Rail SELF STUDY,Fix our soil, fix our discourse, fix our world.
manual_tranny is offline   Reply With Quote
Old November 19th, 2011, 20:58   #2132
Trooper81
Fuel Economy: 72 MPG Record for 00' TDI
Everyone is way too stressed out over this, first of all the Euro design of the Fuel pump is nearly identical. There are obviously a few failures that happen, from contaminated fuel to maybe a bad pump. But with the take rate of the TDI at 80% in alot of places in Europe and this CR engine and pump in hundreds of markets, the design of the pump in itself with proper fuel is NOT faulty. If it were it would be failing at massive rates all over the world and this is NOT the case.
I can point you to someone in the USA who already has nearly 200,000 miles on his 09 CR with NOT one problem with the HPFP. This is obviously a fuel quality issue. Vw and bosch have repeatedly stated that contaminated fuel will cause premature wear/catastrophic failure. And I'm sure that is the case in the "MAJORITY" of cases.
Misfueling is a tiny % of the over all failures.
Watch where you fill up, use only high quality diesel at places with high turnover and CHILL OUT. I live in canada and not too far from here a small gas station pumped gasoline into their diesel pumps imagine what happened next? Chevy, BMW, VW, Mercedes, and ford dealerships were all scratching their heads as to why all these diesels were comming in at the same time.
Find a station you trust, fill up, hey stick a finger in it and smell it every now and then just relax.
I think if anyone should be getting chewed out and taken to court over this it should be the fuel suppliers not the manufacturers. If the suppliers can't provide the quality "EXPENSIVE" fuel that we pay for they should be held accountable. Everyone is sniffing up the wrong tree here and it's so obvious it's rediculous.
Vw is covering MOST HPFP failures in the US even WAY WAY out of warrenty. Trust me on this, and ya Chill out and enjoy the ride.
Trooper81 is offline   Reply With Quote
Old November 20th, 2011, 03:14   #2133
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
Except, in the US, there are states where it's literally impossible to get high quality diesel without exceeding the B5 limit, or getting drums of fuel shipped to you.
Whole states.
The design of the pump is incorrect for the United States, because the pump requires fuel that is far higher quality than the minimum standards for the US. It's a fine design for Canada, because Canada's fuel standards, at least in the lubricity category (the one that affects the pump) are harmonized with Europe's.
I also feel that the fuel filtration system is insufficient, due to the amount of allowed water and sediment in diesel fuel in the US, and how little enforcement there is of even that.
1999.5 golf tdi | 5 speeds | 2 doors | crank windows | candy white | rc3 | t502 | 11mm | fsd
emit more NOx (in VOC-limited areas), save the planet | reverse polish notation good is
The really cool ToofTek made "Emperor's Clothes" injector fork risers only worked until someone pointed out that there wasn't any thing there.
bhtooefr is online now   Reply With Quote
Old November 20th, 2011, 08:06   #2134
manual_tranny
Yeah, blame the fuel suppliers all you want but Bosch and VW both knew the quality of our American fuel didn't meet the quality of fuel required for their pumps, and they ignored the fact that there would be problems.
Old November 20th, 2011, 08:26   #2135
Niner
veteran member
It's obvious, if you look at NHTSA reports, questions, and time lines that VW contacted and worked with Delphi for design of that Delphi DFP6 HPFP for the 1.3 L TDI 2010 Polo in European Markets, as well as how Delphi markets the pump as being fail proof, compared to other brands.
http://delphi.com/news/pressReleases...010_05_11_001/
"The design safely prevents the shoe on the DFP6 pump from lateral rotation which eliminates the risk of fatal pump damage and allows for a mass of just 2.4kg.
Obviously, VW had to be be working with Delphi at least a year or two in advance to come up with this design to market with a May 2010 date, which may put us at around May or June of 2008. VW knew, they had to know, as did Delphi, about defective designs in existence, they patented it, the square shoe follower. There would otherwise have been no reason to improve on the existing Bosch design. Bosch certainly can't patent a round bore hole design.
Niner is offline   Reply With Quote
Old November 20th, 2011, 13:03   #2136
Trooper81
Actualy the "specification" for the Quality of US fuel does barely meet the qualification for lubricity of the pump, with slightly reduced longivity. However the problem is the "actual" quality of US fuel is varying. From barely meeting spec to severly below spec, and as a result it is having an effect on the pumps. If all the fuel was at the minimum specification required with zero contamination we would probably see next to no fuel system failures.
Again, Vw covering the pumps is really a goodwill act in my eyes as the fuel suppliers should really be held accountable for not providing the quality and specific grade of fuel that is required of them by federal mandate.
Old November 20th, 2011, 13:10   #2137
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
No, the specification does not meet the pump's spec.
Pump requires 460 um maximum wear scar fuel, US spec is 520 um with 560 allowed, and there is plenty of fuel that exceeds even that in the US due to weak laws.
Old November 20th, 2011, 15:22   #2138
Trooper81
It seems you are correct. Those numbers would be definitely in the insufficient lubricity catagory with significant reduced pump life.
Old November 20th, 2011, 15:50   #2139
manual_tranny
Believe me, I wish I were wrong about this.
Old November 20th, 2011, 17:23   #2140
Tarbe
I have fueled in 20 states over 110,000 miles.
If the pump was so bad that we should expect a failure every 36k - 60k miles....well, let's just say I am way past 3 sigma beyond the average.
'09 JSW 6spd Man 167K Miles (On one HPFP ) Running Mobil 1 ESP FM 5W-40 and B3 + PS White
'12 Touareg TDI Lux 15k miles (also on B3 + PS White)
'12 Jetta SE 15k miles
Tarbe is offline   Reply With Quote
Old November 20th, 2011, 17:36   #2141
GTIDan
GTIDan's Avatar
Who is your source for such information? Always someone who claims this and that but no source. Since no one I've seen on these forums has ever tested any diesel fuel for lubricity how do we know what the truth is..
All I can add is that I was told by someone way up the chain with 76 here in California that they guarantee their diesel to spec out at 480 or less. Insofar as they are also among the few companies who quality for 'top tier' recognition is good enough for me.
9/02/09 Build date.
GTIDan is offline   Reply With Quote
Old November 20th, 2011, 18:48   #2142
manual_tranny
So what? You can find quality fuel yourself, so there isn't a problem? What if you wanted to drive to another state? Would you call every gas station and ask to speak with some "higher up" management guy who's job is to caress your ego by assuring you that the fuel they sell is infallible?
I get what you're saying... but there are a minimum of three major flaws in the original design of this fuel system and pump. The most critical of these flaws is a total intolerance to a higher wear scar level.
You posted in another thread that these pumps are going to last at least 500K miles because they were supposed to last 750K miles on European fuel. Do you really believe that?
Old November 20th, 2011, 18:59   #2143
GTIDan
GTIDan's Avatar
[QUOTE=manual_tranny;3610976]So what? You can find quality fuel yourself, so there isn't a problem? What if you wanted to drive to another state? Would you call every gas station and ask to speak with some "higher up" management guy who's job is to caress your ego by assuring you that the fuel they sell is infallible?
You posted in another thread that these pumps are going to last at least 500K miles because they were supposed to last 750K miles on European fuel. Do you really believe that?[/QUOTE]
Does it really matter what I believe? Nope, didn't thing so.
Season's greeting to all
9/02/09 Build date.
Old November 20th, 2011, 19:26   #2144
pogo
Fuel Economy: Golf 48 Passat 43
If lubricity is truly the root cause of these failures, it should be possible to prevent them: (Diesel fuel additive study results.) Not so if its an inherently bad pump design. Do we have a record yet of any failures on pumps that used 2% soy bio-diesel?
'72 Fastback/'85 Jetta 1.8/'94 Jetta 2.0/'02 Golf TDI 195K
(check fuelly notes for MFD mpg values)
pogo is offline   Reply With Quote
Old November 20th, 2011, 20:27   #2145
Trooper81
The problem with biodiesel is that often poor quality bio can contain water which also will add to the wear. I'd like to see a failure with someone using a good quality additive such as Optilube XPD and fuel that has had zero conatamination. At that point i will believe that the design of the pump is bad. Until then the design is fine it's the quality of the fuel that is bad.
Currently Active Users Viewing This Thread: 15 (7 members and 8 guests)
BenzBob, DPM, PoliPino, SalsaRed2010, Tin Man, flyboy320, padlock
HPFP Failure in V6 TDI, or only in 2.0 CR? Trooper81 Fuels & Lubricants 61 May 16th, 2013 03:26
CR High Pressure Fuel Pump "HPFP" failure FAQ - Updated 2/8/2011 dzcad90 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010+) 0 June 28th, 2010 13:52
Good Job! NHTSA investigation candywhite VW MKV-A5 Golf/Jettas 15 July 28th, 2009 02:26
NHTSA opens investigation on DSG transmisisons dieselyeti VW MKV-A5 Golf/Jettas 1 July 24th, 2009 11:07
Page generated in 0.18443 seconds with 10 queries
[Output: 146.30 Kb. compressed to 123.60 Kb. by saving 22.70 Kb. (15.52%)]
