Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI News/Tech
TDI News/Tech This Forum is for the posting of TDI news related items.
Old October 14th, 2009, 16:44   #1
dzcad90
Rolex & gin
dzcad90's Avatar
Default NHTSA Update on CR HPFP failure investigation
This thread has been moved from the MkVI section to the TDI News section as it covers a wide scope of vehicles, and of course, it's news!
- Don
'97 Jetta TDI - 135K - R.I.P. 10/22/03
'03 Jetta TDI - Silver / Black Leather, 161K miles - Sold.
'09 Jetta TDI Sedan - Sold!
'14 Passat TDI SEL - Blue / Black Leather
VCDS Available in Chicagoland - trbodsl@gmail.com
dzcad90 is offline   Reply With Quote
Old February 11th, 2011, 12:18   #2
timwagon
Bloomberg Business news just posted this update on the NHTSA investigation of the HPFP failure.
VW insists that all HPFP failures are caused by "mis-fueling" issues.
NHTSA is estimating that 0.53% of 2009 models (1 in 200) and 0.11% of 2010 models (1 in 1,000) have experienced these failures.
According to the report, the HPFP pump has now been redesigned three times!
This issue has been escalated by NHTSA and may result in a recall.
Bloomberg Article:
http://www.bloomberg.com/news/2011-0...ump-flaws.html
NHTSA document:
http://www-odi.nhtsa.dot.gov/acms/do...10034-6542.PDF
timwagon is offline   Reply With Quote
Old February 11th, 2011, 12:35   #3
Jackiechan005
Jackiechan005's Avatar
Fuel Economy: ~40 MPG
"Volkswagen indicated that the testing of fuel samples from complaint vehicles found that nearly 90 percent contained high amounts of gasoline. Volkswagen implemented design changes for the HPFP in May 2008, September 2009 and November 2010 to
improve the robustness of the pump when used with poor quality fuel."
Anyone know what design changes were implemented?
2010 Golf TDI 6M
Jackiechan005 is offline   Reply With Quote
Old February 11th, 2011, 12:35   #4
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
0.01% is 1 in 10,000.
NHTSA intensifies probe into 100,000 VW diesel vehicles
Federal safety regulators stepped up an investigation into nearly 100,000 Volkswagen and Audi diesel vehicles over fuel pump failures.
The National Highway Traffic Safety Administration said today it had upgraded its investigation into 97,272 diesel 2009-10 Volkswagen Jetta, 2010 Volkswagen Golf and Audi A3 vehicles.
Old February 11th, 2011, 12:37   #5
ilyago
From the NHTSA document, VW mostly blames most cases on gasoline contaminated diesel fuel, but also states that:
Volkswagen implemented design changes for the HPFP in May 2008, September 2009 and November 2010 to improve the robustness of the pump when used with poor quality fuel.
-Ilya
2015 Jetta TDI S DSG
2015 Passat TDI SE manual
2010 JSW TDI 6-sp manual - SOLD in 2015
1998 Jetta TDI 5-sp manual - SOLD in 2010
ilyago is offline   Reply With Quote
Old February 11th, 2011, 12:40   #6
timwagon
Thanks, corrected OP to actual numbers from NHTSA findings, .53% (2009) and .11% (2010),
-TimWagon
Old February 11th, 2011, 12:42   #7
timwagon
VW's current stance is: DENY, DENY DENY.
If it's only caused by gasoline contamination, why three separate HPFP redesigns?
Why redesign the HPFP at all if it's not a bad pump issue?
Old February 11th, 2011, 12:46   #8
quadrun1
According to the NHTSA document,
For 2009 the number is 0.53% (roughly 1 in 200)
For 2010 the number is 0.11% (roughly 1 in 1000) (not 0.01% which would be 1 in 10,000)
Jason
2015 Subaru Forester XT Touring "Sachihiro";
2006 Acura MDX Touring "Emmitt"; --- previous:
mods: Ed's HID projectors w/LED DRLs(type 1); Torque Pro; grocery bag hook; VCDS: hill hold disabled, hazards flash w/ABS activation, brighter taillights via higher voltage
quadrun1 is offline   Reply With Quote
Old February 11th, 2011, 12:49   #9
timwagon
Smile
Jason
-typo in OP has already been corrected
Old February 11th, 2011, 12:51   #10
dubStrom
dubStrom's Avatar
I had a feeling that design changes (or at least improvements in quality control at bosch) were underway.
I bought my car in May last year (full tax credit!!), but I wonder if it got one of the last, most recent fuel pumps? I would like to know manufacture dates for the last HPFP version, and check it against my engine build date.
Lost my JSW to a reckless MB E350 sedan driver blowing a stoplight:
http://forums.tdiclub.com/showthread.php?t=472255
Working on a replacement project:
http://forums.tdiclub.com/showthread.php?t=472257
dubStrom is offline   Reply With Quote
Old February 11th, 2011, 12:55   #11
ruking
Fuel Economy: 62/50/44mpg, normal commute range 48-52 mpg:09 Jetta TDI, 47/43/39, normal commute range 39 -43 mpg: 12 Touareg TDI, 39/31/29 mpg:
Indeed. If the pump was "RE" designed 3 times, does that mean the only ones to receive one of the three/four were the ones that failed? I know for example I still have the oem factory HPFP. So if one fails a second time, does IT now get the 2nd/3rd redesign, etc? Or is it dictated by WHEN the HPFP fails and they just use the latest and greatest upgrades? PN#'s bear no evidence of any sequential upgrades (so for example (DASH-) -1,-2,-3, -4)
Looks like the ground work is being laid for a FULL recall. I would assume that VW would give all of us (except those already fixed) the latest and greatest upgrade so they do not have to do ANOTHER full scale recall.
These published numbers were quite helpful in that I had swagged the 09 (one that I have) were 1% or less. Seems the math indicates a schosh more than one half of 1 percent.
ruking is offline   Reply With Quote
Old February 11th, 2011, 13:02   #12
ksing44
Jason
If 90% really are from using gasoline, then the failure rate might be 0.01%, or 1/10,000 for folks that are sure to only use diesel. I'm just doing some wishful thinking with this, not trying to be a jerk.
I do wish I had a car with the November 2010 upgraded pump. I guess my car only has 2 of the updates. It would be nice to know what they did to improve the pump. Honestly, I wish they would just come up with something to prevent the debris from contaminating the fuel system. Then it would just be a new pump for a few hundred bucks, not really a big deal at all.
2010 Golf TDI - Blue (BGM), 4-Dr, 6-M, Sunroof, Xenon, Dynaudio, Nav (RNS-510), Euro light switch, 9W7 BT, R Tinted LED Tail Lights, Monte Carlo 17" x 7.5" ET47 Wheels, 235/45/17 Tires, P3Cars Digital Interface, Sonniboy sunshades, CP3 HPFP!
Flickr slideshow
ksing44 is offline   Reply With Quote
Old February 11th, 2011, 13:09   #13
timwagon
Last pump update was November, 2010, according to the NHTSA report.
The link to the NHTSA report is in the OP.
Old February 11th, 2011, 13:13   #14
dubStrom
dubStrom's Avatar
Default find someone dumping their 09Jetta!
So now I would feel confident buying someone's 09' TDI at a bargain. I know some folks were dumping them, ranting on this site about how they felt outrage (I am sympathetic). Get an '09 prefailure Jetta or Golf at substantial discount, install one of the new pumps, and sail on!!!
Yes! Maybe I should look for a used 2.0 CR Golf 6MT now?
Old February 11th, 2011, 13:17   #15
timwagon
I do wish I had a car with the November 2010 upgraded pump. I guess my car only has 2 of the updates. It would be nice to now what they did to improve the pump. Honestly, I wish they would just come up with soemthing to prevent the debris from contaminating the fuel system. Then it would just be a new pump for a few hundred bucks.
VW's 90% number is pure bulls%$t, as far as I'm concerned.
Who ran these fuel tests, and who certified the test results?
It's apparent that NHTSA is not buying VW's claims, as they've opened a full engineering investigation.
I'll bet the three separate HPFP redesigns in less than two years has also been met with suspicion by NHTSA.
Apparently, VW has learned nothing from the Toyota recall disaster.
It's always better to get out ahead of a defect issue than to delay and deny, which only makes the issue worse, and ends up driving away customers.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
HPFP Failure in V6 TDI, or only in 2.0 CR? Trooper81 Fuels & Lubricants 65 May 30th, 2014 19:52
CR High Pressure Fuel Pump "HPFP" failure FAQ - Updated 2/8/2011 dzcad90 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 0 June 28th, 2010 14:52
Good Job! NHTSA investigation candywhite VW MKV-A5 Golf/Jettas 15 July 28th, 2009 03:26
NHTSA opens investigation on DSG transmisisons dieselyeti VW MKV-A5 Golf/Jettas 1 July 24th, 2009 12:07
Page generated in 0.22190 seconds with 10 queries
[Output: 134.35 Kb. compressed to 112.63 Kb. by saving 21.71 Kb. (16.16%)]
