Old February 4th, 2011, 20:39   #1
rallyruss
rallyruss's Avatar
Default Add another BHW tesioner failure
To all you naysayers.... Come on! Another one.....
Finally had a chance to dig into my wife's passat to get down to actually inspect where that noise and vibration is coming from. As I dropped the pan the smaller chunk o bad design clunked into the pan. Its been this way for a while based on the wear.
118K miles on the car and it actually ran decent like this.
Listen to Oil hammer, Mo Golf, Runonbeer and the rest who do these or know about it.
VWOA set us up good.
http://pics.tdiclub.com/data/567/Photo0131.jpg
This is a heck of a fun job
98 TDI jetta BillyHDs, Softsports, 16"wheels, corrado brakes, running B99. PP520s and chip to match and some other stuff....250k+
(Hers) 05 Passat TDI GLS wagon. Unchained, Koni FSDs, RC2, audi S4 wheels and full tint.
rallyruss is offline   Reply With Quote
Old February 4th, 2011, 20:43   #2
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Better to catch it now than 30 seconds after the chain breaks.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old February 4th, 2011, 22:21   #3
rallyruss
rallyruss's Avatar
Thats for sure.
There is a reason why we have been avoiding using this car for any kind of distance away from home.
This thing is a glorified bike chain.....
will start reassembly tomorrow. So far so good.
Old February 5th, 2011, 05:39   #4
Sloppy Snood
Sloppy Snood's Avatar
TDI(s): Passsat
Fuel Economy: 31 mpg (city) / 38 mpg (hwy)
Put some J-B Weld on there, slap it back on.
Got Meleagris gallopavo silvestris?
Don't know what a "Snood" is? Click Here and Move Cursor Over the Beak
'05 VW Passat TDI GLS - The Unofficial TDIClub VW B5.5 Passat oil pump balance shaft crybaby!
Sloppy Snood is offline   Reply With Quote
Old February 5th, 2011, 07:51   #5
abctdi
abctdi's Avatar
Don't forget the duct tape too!
05 Passat GLS 2.0 PD, UnChained & Steel GPs by VW, 15" steelies, New TB/WP, motor mounts, alt pulley, trans filter, cv boots, TSB #P9/66C8, clear bra & tint, both raxles. Now only driven 1-2 times per week. 123k miles (sold)
DD is a 2012 Kia Optima SX turbo with 274 hp and 269lb-ft@1,750-4,500rpm
abctdi is offline   Reply With Quote
Old February 5th, 2011, 11:46   #6
thundershorts
what a surprise, it broke right along the "perforation"
' cast into it.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old February 5th, 2011, 12:31   #7
rallyruss
rallyruss's Avatar
My wife wants to mail the parts back to VWOA with a note...
So we baked the gear this morning. My fluke temp probe only registered 350deg F although the oven was at 400+
Wish I had an infrared heat gun at home.
The gear went on no problem. It makes me a little nervous possibly heating a gear above 375 deg F.
Old February 5th, 2011, 13:23   #8
aja8888
aja8888's Avatar
Looks like you would have to get above 1154 degrees centigrade before anything happened to the gear's properties:
Old February 5th, 2011, 13:54   #9
rallyruss
rallyruss's Avatar
interesting.
when fitting gears and couplings on our equipment at work they normally recommend staying below 400deg F to not change any of the heat treatment properties.
Well its happily on and I'm working on fitting the new balance shaft now.
Old February 5th, 2011, 15:40   #10
aja8888
aja8888's Avatar
interesting.
Actually, at 1154 C it turns liquid. Depending on the way steel is hardened, and the carbon content, things can happen to lower temperatures. But in the low hundreds, not much can happen other than some coloring.
Old February 6th, 2011, 21:11   #11
rallyruss
rallyruss's Avatar
Well shes a runnin!
I fired it up tonight. Its still on stands for other unrelated repairs but the engine runs great. Feels smoother to me but a real road test is in order soon.
I really took my time but it really was not that bad now that its all done.
This is NOT a job for a rookie shade tree mechanics. Only experienced shade tree mechanics
Old February 6th, 2011, 21:22   #12
aja8888
aja8888's Avatar
Well shes a runnin!
Great, nice job. Did you change out your motor mounts or were they not leaking?
Old February 6th, 2011, 23:41   #13
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
IIRC the coating on the gear is the reason for the lower temp. or does the intermediate gear only have the coating?
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old February 7th, 2011, 03:30   #14
thundershorts
i used my forge and cones to raise the temp.less than two minutes was enough to melt the 350 degree cone and i had no bluing. gear is made of pressure cast steel.
Old February 7th, 2011, 03:56   #15
s4phillips
s4phillips's Avatar
Location: Live in d/FW, TX. Transplanted from the Pacific Northwet
Coating is only on the intermediate gear.
Perform scheduled maintenance; drive more, worry less; balance shaft module; drive more, worry less; torque converter; drive more, worry less...
2005 Passat Wagon TDI w/gear driven buzz reducer and lubricant circulator
2002 Beetle TDI
2003 DL1000K3
s4phillips is offline   Reply With Quote
Aux Fuel Pump Failure (Formerly:HPFP Failure!) EOTS VW MKV-A5 Golf/Jettas 35 February 15th, 2012 07:06
AWIC located on BHW TDIsyncro TDI Power Enhancements 13 September 17th, 2009 11:11
Are all N. American BHW motors the same? texascadillac42 VW B5 Passat TDIs 13 December 16th, 2008 18:12
BHW no start Dead Larry OBD Scanners 9 August 15th, 2008 11:17
coolant pump failure = timing belt failure? 3800rpmDiesel TDI 101 33 June 2nd, 2006 05:31
Page generated in 0.17231 seconds with 10 queries
[Output: 135.71 Kb. compressed to 113.48 Kb. by saving 22.23 Kb. (16.38%)]
