Old February 4th, 2011, 05:31   #1
Ryanr912
Default 04 BEW loss of power; shaking when accelerating.
Driving into work today my car started driving horribly. At highway speed it just lost power and started decelerating with the pedal to the floor. Going up hills I was only able to drive ~55 mph (until I hit the next downslope). When the car is under acceleration/load, the entire car starts shaking incredibly hard. When I let off the pedal, the shaking stops immediately. The car can get up to ~30mph without shaking too bad (I can hear the turbo spool up) but beyond that the shaking only gets worse. Acceleration is much worse than normal.
I believe the in-tank lift pump (original) is working, as it makes a normal noise when I turn the key on. The car idles fine (at least to me, while sitting in a windy parking lot in -1 degF weather). With the engine at running temp, it started up fine with no hesitation.
Maintenance history:
Fuel & air fltrs replaced ~8k miles ago
Timing belt & water pump replaced by Guru ~30k miles ago
Suspension replaced ~5k miles ago by Guru
Tires replaced/balanced/aligned last week.
Unfortunately I am at work until 6 pm tonight and can only get on the internet for minutes at a time once or twice. I will try to get my car hooked up to VAG later today or tomorrow.
I would appreciate all the help you guys can give me with a diagnosis.
'04 Jetta PD Auto - Ventectomy, Doggie Collar...otherwise stock
Ryanr912 is offline   Reply With Quote
Old February 4th, 2011, 05:38   #2
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
Look to see if your rubber intake pipe blow out of the intake manifold or backed way out. That'll cause the problem for sure. You need a doggie collar to fix this. Some zip ties, wire or duct tape work in a pinch.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old February 4th, 2011, 05:42   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
I also wonder if for some reason the fuel gelled slightly and plugged the filter up.
oilhammer
www.cardocautomotive.com
Old February 4th, 2011, 05:46   #4
jasonTDI
jasonTDI's Avatar
Could be. Would explain the shudder under load.
Old February 4th, 2011, 06:10   #5
Sooch
Sooch's Avatar
TDI(s): 2005 Golf
Fuel Economy: 44-45
This very thing has been happening to me when the temp falls below about 10 F. I use a double shot of power service too, but I suspect some gelling is still happening. I think a new fuel filter will clear up the problem, I just havn't got around to doing it.
To the OP, does it clear up once the fuel is up to temp, say after about 20 minutes of highway driving?
Chris
OCD TDICLUB MEMBER #2
John Deere Telematics
05 Golf TDI - Modified
Sooch is offline   Reply With Quote
Old February 4th, 2011, 07:27   #6
Ryanr912
I already have the "Doggie Collar" installed so that is not the problem.
Fuel gelling is a possibility so I'll pick up some PowerService on the way home and also order a new fuel filter.
The shaking and acceleration did not improve as the fuel and engine warmed up.
Any other suggestions? I really appreciate all the help guys.
Old February 10th, 2011, 13:42   #7
Ryanr912
UPDATE:
While I waited for my new fuel filter to arrive, I drained the installed fuel filter (lots of black particulates) and filled it with Diesel 911. This only seemed to improve the shaking under load for approximately 10-15 highway miles before it returned. I did this two days in a row. My acceleration is back to normal (or close). Cruise control can maintain 75 mph without downshifting up hills.
I installed a new fuel filter and tee (after I broke the first one ) and added a good dose of PowerService (White bottle) to the filter and tank. I filled up my tank with fresh diesel when I was at 1/4 of a tank. Unfortunately the car is still shaking heavily under load, especially > 40 mph. As soon as I left off the "gas" pedal, the shaking goes away.
Have I ruled out gelling fuel? I've confirmed that my lift pump delivers fuel to the filter but could a degrading pump cause these symptoms? Injectors? Tandem pump? Or is it my newly installed & balanced tires? I'm at a loss guys. Any suggestions would be a huge help.
Or maybe I should just bring it to my local Guru .
Old February 10th, 2011, 20:14   #8
Sooch
Sooch's Avatar
TDI(s): 2005 Golf
Fuel Economy: 44-45
Sorry it wasn't something simple. Shaking under load, but smooth while coasting, sounds like you might have one CV joint that is bad. Does the engine hold RPM smoothly in neutral while parked or does it sputter? In other words, if you press the accelerator and rev it up to 2500RPM does it stay there or do weird things, or does this only happen when under load?
Chris
Bad shaking and loss of power after the engine heats up civilator VW MKIII-A3/B4 TDIs 0 November 3rd, 2010 14:12
brief power loss shortly after first accelerating 02vdubtdi TDI 101 3 June 18th, 2010 20:38
Power loss while accelerating freeantelope024 TDI 101 3 September 17th, 2008 06:33
Page generated in 0.09361 seconds with 10 queries
[Output: 87.06 Kb. compressed to 74.51 Kb. by saving 12.56 Kb. (14.42%)]
