nylonoxygen77
IP plunger broke during on-car pump head seal install
Bad day. This morning before work my car would not start at all. It's been hard to start for a while, especially in the cold. If I don't plug in my TDIHeater I'm not going anywhere, the engine can't spin fast enough to fire. I determined that the pump was losing prime somewhere when sitting for several hours. Well, a week or two ago, I actually found that the pump head was DEFINITELY leaking, and this morning it wasn't going to start. So I called off work and decided to finally install the viton o-ring I got from Dieselgeek last year. I've been reluctant to do it because several people have broken their pumps during the procedure, but many have done the procedure with great results. Well, I'm pretty careful, but apparently not enough. I read the procedure over many times. I printed it out and had it with me during the procedure. I had everything ready to go before I started. I read posts on this forum to find all the gotchas and things to look for. It went great up until the part where you put the long 55mm bolt in that will prevent the pump from falling apart. I turned that bolt in, and it drew the pump head in with it almost right away, when the head should have been able to slide freely along the shaft of the bolt. I took it out and reinserted it so many times, tried greasing it, nothing worked. I'd put it in, start turning it with my fingers, and after a few turns the pump head would start pulling in with it. So I wasn't able to tighten it all that way in. I think something had gotten crooked during the process, because it seemed like the dieselgeek bolt was going in straight, meaning it wasn't crossthreading, but the pump head wasn't straight. I tried a few things - I thought maybe putting the other bolts back in and tightening them evenly to a certain degree to straighten the head would help. Whatever I did, at one point something gave way, I heard a snap, and fuel gushed out from behind the head. The bolt I was tightening was suddenly very easy to move. I knew right away something bad had happened, so rather than finishing the job, I took off the QA and this is what i found.
I'm pretty sure that jagged space isn't supposed to be there.
So now the pump has to come out. Anyone else had the 55mm bolt do that? I was so sure I could do this. I'm not yet sure what to do next. I can either swap it with a reman or send it to DFIS for a rebuild. In any case I'm either going to have to tow it to my guru an hour away or get my hands on the TB tools to do it myself. If I do that though I'll have to get the TB off without jacking the car up... it's in a gravel driveway with NO space on either side, off an alley. I'm not terribly upset, the car has almost 170000 miles on it and the pump is original AFAIK. If it was going to break, better during this job than on the highway. So it was probably time for another. Suggestions? Thanks everyone.
