Old February 1st, 2011, 21:15   #1
khs_team
Default Rear running light not working but brake light works
Hey there,
First of all this forum rules! I've learned a ton about my new TDI. But I have a funny issue. I've noticed my right rear running light isn't working. The left one works fine. Here's the rub; the right rear brake, blinker, and reverse lights all work. I have new bulbs and even tried the bulb from the left side, no dice. What gives? I've thought about getting a replacement bulb housing, but since 3 out of the 4 work, what are the odds that the bulb housing is faulty? Any help would be greatly appreciated! Thanks!
khs_team is offline   Reply With Quote
Old March 4th, 2011, 06:10   #2
newride
TDI(s): 2005 Golf
Default Left rear running light not working.
I have the same problem, however, my left rear running light will not illuminate !!! All other lights- fronts, left and right and rear right work properly. Yes i have changed bulbs and swaped with good. No help. I would appreciate help with this matter. Thank You.
newride is offline   Reply With Quote
Old March 4th, 2011, 10:39   #3
PDJetta
PDJetta's Avatar
Wiring problem in the trunk?
--Nate
Old March 4th, 2011, 11:04   #4
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
--Nate
x2
clean and inspect the bulb socket, be sure the bulb can contact both nubs and body
3rd Brake Light acting as running light? TDIdragon VW MKIV-A4 TDIs (VE and PD) 15 May 24th, 2017 23:07
Running light not working AARodriguez Corp. TDI 101 4 June 22nd, 2009 12:13
daytime running light not working Hexar TDI 101 7 January 15th, 2008 22:21
Yeah, but my brake light works scknight OBD Scanners 8 March 25th, 2007 18:22
Using rear fog light as second brake light BruhahaX Upgrades (non TDI Engine related) 37 October 10th, 2003 18:36
Page generated in 0.11522 seconds with 10 queries
[Output: 63.22 Kb. compressed to 56.62 Kb. by saving 6.60 Kb. (10.44%)]
