Old January 29th, 2011, 09:45   #1
Franko6
Default Simplified Setting of PD Injector Lash
The Bentley book gives a complicated and problematic method for setting the PD injector clearances. The method is to use a dial indicator mounted onto the rocker, then rotate the engine until the full depth of the stroke is reached. Screw in the adjustor screw until it bottoms out. Then back it out 180 degrees. Tighten the ball screw lock nut to 24 ft lbs. VW did standardize the setting for all PD motors for a 180 degree setting.
The problem is, there is no decent place to attach a dial indicator's bolt-on or magnetic mount.
The following pictures show how to do the operation with no dial indicator.
this is the position of the cam with the #4 injector rocker fully depressed, side and top view:
The injector is pressed to full depth when the top of the INTAKE valve cam lobe is aligned with the center of the injector lobe roller. Note that for each cylinder, the intake lobes are located across the head e-i-e-i-i-e-i-e (i=intake, e=exhaust)
This makes adjusting the injectors a very simple 'eyeball' method.
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Old January 29th, 2011, 13:35   #2
PDJetta
PDJetta's Avatar
Thanks Frank! I like that. Nice and easy.
Bentley shows a special VW tool that bolts onto the cylinder head using a valve cover bolt hole to hold the dial indicator and I was hoping a universal dial indicator holder would do, but I have no idea on how to attach it.
--Nate
Old February 24th, 2011, 15:04   #3
jdennison
jdennison's Avatar
Fuel Economy: 42/45
Frank I was wondering if you could send me those pics, I'm unable to enlarge them the site say I must register
jdennison is offline   Reply With Quote
Old February 24th, 2011, 15:28   #4
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
You have to log in to the tdiclub picture gallery with your current username/password.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is online now   Reply With Quote
Old February 24th, 2011, 19:50   #5
jdennison
jdennison's Avatar
Fuel Economy: 42/45
Thanks turbocharger I see how to do it now, thanks also Frank nice pics
Old February 24th, 2011, 20:04   #6
Farfromovin
Torque Addict
Farfromovin's Avatar
Fuel Economy: low: 35 high: 56 avg: 42.0
Yeah, I got a real kick out of the Bentley procedure. Dial indicator lol. That thing is at a low spot for so long a 5yr old could set the cam correctly!
[/old setup]212whp/354 ft-lbs14.862@96.677-Way faster than Chris [/new setup] At least 213whp, and way way faster than Chris.
Farfromovin is offline   Reply With Quote
Old April 18th, 2011, 07:43   #7
Henrick
Any ideas on how much of resistance there should be when turning the adjusting screw clockwise, before the backing off? I mean, how tight should it be? How do I know it's enough?
Henrick is online now   Reply With Quote
Old April 18th, 2011, 23:31   #8
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
No kidding!
runonbeer is offline   Reply With Quote
Old April 18th, 2011, 23:32   #9
runonbeer
You'll know when it bottoms out.
Old July 4th, 2011, 05:41   #10
Franko6
I've seen guys over-tighten the ball screw. Loosen the set nut and turn the ball screw until you feel a change in resistance. Don't force it. Then back the screw off 180 degrees. Lock the set nut to 24 ft lbs.
1007 Olive St.
Lockwood, MO 65682
417-232-4634
Old January 30th, 2012, 12:46   #11
rick.johnson0330
TDI(s): golf gt tdi
Default tdi 130 injector adjustment
can i ask how often should this adjustment on the injectors be done, my golf has done 120k as far as i know its never been done
thanks
rick.johnson0330 is offline   Reply With Quote
Old January 30th, 2012, 22:15   #12
Lightflyer1
Lightflyer1's Avatar
subscribed
2015 Beetle TDI.
Old January 30th, 2012, 23:09   #13
runonbeer
thanks
You only need to do it if you remove/change injectors.
Old April 5th, 2012, 06:41   #14
apples12
Apologies for thread revival...
i'm going to be doing this procedure on my mk5 as it wasnt done when we changed the injectors 22,000 miles ago and i'm trying to eliminate things for my current 'best' of 43mpg (UK) motorway mileage....
am i correct in understanding the procedure is as follows:
1) remove rocker cover
2) Rotate CAM using 18mm spanner until the rear of the roller of the rocker arm is at its highest point... (thus compressing the injector the most)
3) screw the adjusting screw in all the way in until resistance is felt
4) turn the adjusting screw BACK 180 degrees
5) maintain position of adjusting screw and tighten the lock nut
6) repeat the procedure 1-5 with the other 3 injectors
i'm guessing the use of the dial gauge in the bentley manual/vw workshop manual is to ensure the rocker follower is at its highest point and the injector is compressed the most?
many thanks for any help
apples12 is offline   Reply With Quote
Old April 5th, 2012, 07:08   #15
Nutsnbolts
Nutsnbolts's Avatar
Fuel Economy: Average is about 46 now (2016)
Franko6: Great post!
If anyone feels better about using a dial indicator for this procedure, I have a method that doesn't require the factory tool. I put the magnet mount on the injector rocker, which is steel, and it holds itself there securely and without any wobble. I then put the tip of the indicator on the cylinder head, on the machined surface between each cylinder bank, and rotate the engine until the indicator stops. Then set the injector lash. Works every time...
-Rich
574,500 miles now and counting...25,500 until cluster swap!
'00 Jetta GLS, '03 Jetta GL, 08 Highlander, '72 Plymouth Satellite, '68 Chrysler 300, '75 Benz 300D, 78 LeSabre Turbo.
Nutsnbolts is offline   Reply With Quote
Injector Fault and Setting Timing Suzuki TDI 101 6 March 13th, 2009 07:18
Need help setting injector timing - Seattle Jimwsea VW MKIV-A4 TDIs (VE and PD) 2 August 12th, 2005 18:45
TB Change Need help setting the injector pump Da_Body VW MKIV-A4 TDIs (VE and PD) 3 November 4th, 2003 20:46
injector pump setting GoFaster VW MKIV-A4 TDIs (VE and PD) 1 November 30th, 2002 01:37
Pumpe Duese or PD 101 (Simplified Version) Turbo Steve VW MKIV-A4 TDIs (VE and PD) 13 November 29th, 2000 20:46
Page generated in 0.16200 seconds with 10 queries
[Output: 129.49 Kb. compressed to 107.94 Kb. by saving 21.55 Kb. (16.64%)]
