| VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010+) Discussions area for A6/MkVI (2010+) Golf and Golf Wagons (Jetta Sportwagon in the USA). |
January 27th, 2011, 18:54
#1
Fuel Economy: 35 or so. See my "Fuelly" for details.
Key Fob -- One click, unlock ALL doors?
Hello all,
2011 Jetta Sportwagen TDI.
Is there a way to make it so you can just click the unlock doors button on the key fob ONCE (instead of twice) to unlock ALL the doors?
Is there something easy I can do to change this?
Can a dealer easily change this?
I've look around on here, and I think you can do it if you get that VCM (?) mod thingabop and, well, I'm not that together.
Thanks in advance!
SP
January 27th, 2011, 19:06
#2
I think you can do it.
I had bunch of stuff done all at once (seat belt buzzer, remote windows, all doors,) but recall seeing door lock in settings.
05 Cdi traded for 11 jswtdi 10/15/2010, 09 GEM e2 for round town, 98 Cummins Ram sold 3/2011
January 27th, 2011, 19:57
#3
Yes, if my memory serves, I was able to do it myself via the normal settings on my Golf.... had to have the dealer perform the windows trick through, with their VCM.
2010 Golf TDI w/DSG
2006 Jetta 2.5 (sold)
2003 Passat 1.8T (sold)
January 27th, 2011, 20:02
#4
You can do it through the convinience settings on your mfd. It's detailed in your manual.
January 27th, 2011, 20:22
#5
Info is in the manual. This is how I have mine set up.
January 27th, 2011, 20:32
#6
Thanks guys! I got it fixed now.
By the way, what's the "window trick" I've heard mentioned on here?
Are there any simple tweaks I can do or have the dealer do next time I'm there?
Thanks again.
January 27th, 2011, 20:36
#7
You can open and close the windows via the remote rather than the key in the door. Miss that from my S4 big time. Have to go to the dealer or someone with VAG-COM to get that done.
January 29th, 2011, 19:56
#8
Okay, odd, as luck would have it, I lost my primary keyfob (ugh!) and it unlocked all doors on a single unlock push. As I lost it, I had to go to the back up and low and behold, that little unlock all doors trick isn't working. I double-checked the settings and it looks right.
Now, I'm wondering if this was actually done by the dealer for me (I set this up 6 months ago when I first got the car, so I don't remember if it was something I did - and I thought it was - or the dealer at my request) and it's tied to that, now lost, keyfob?? But I know for sure, it's no longer opening all doors and as of yesterday with the old key, it DID.
The "window trick" is setting up the windows to roll down automatically by pushing and holding the unlock button on the keyfob.
2010 Golf TDI w/DSG
January 29th, 2011, 22:34
#9
The unlock all doors and the ATA confirm (honk when locking) and probably other features are key fob specific. They only work on the key fob that was in use when you set the function. If you change key fobs, you must re-do the changes. I learned this when I turned off the honk when locking. I later locked the car with the other fob and was surprised when the horn honked.
Have Fun!
Don
2009 Jetta SportWagen TDI
Candy White/Anthracite
Build date: 01/16/09; Buy date: 02/09/09
Coveted Three Pedal Version, Big hole in roof
Dieselgeek Shortshifter & Panzer Plate (my favorite & my smartest mods)
January 31st, 2011, 13:32
#10
Sweet! I guess I'll change the function to something different, then go change it back.
Thanks for that!
I guess I'll have to have the dealership program the all windows trick again with this keyfob. Certainly not a need at the moment, as it's 7 degrees out right now
2010 Golf TDI w/DSG
February 4th, 2011, 09:38
#11
Interesting. The options on my convenience menu are Door Open, Window Op and Factory Settings. Near as I can tell, all the Door open function does is unlock all the doors when the key is removed from the ignition...
February 6th, 2011, 19:33
#12
Thanks, just set it up via my convenience on my dash! Thanks.
2010 DSG JSW. Malone Stage II, HPA DSG tuning, DP and straight pipe.
