Old January 26th, 2011, 05:20   #1
folgart
Fuel Economy: 57/46/41
Default Wheel Speed Sensor Wiring harness
Hi all, VCDS reports:
Component: ESP FRONT MK60 0102
Coding: 0019458
Shop #: WSC 01266 785 00200
VCID: 346C03FB2EBD
1 Fault Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
012 - Electrical Fault in Circuit - Intermittent
I have already replaced the sensor, time to check the harness.
Anyone have a wiring diagram?
folgart is offline   Reply With Quote
Old January 26th, 2011, 21:13   #2
mp3mike05
Fuel Economy: 46ish
Coding: 0019458
VCID: 346C03FB2EBD
1 Fault Found:
Don't have a diagram but I will say did you take a good look at the wires where they go into the connector? Pull back the rubber and look in there. One of mine was pulled out when I bought my car (I think PO had dropped the spindle forgetting to unplug the sensor and it pulled it out)
mp3mike05 is offline   Reply With Quote
Old February 1st, 2011, 08:08   #3
drrck
Hope this helps.
'05 Jetta PD - Spice Red, RC2 - 25psi, Darkside SMIC and pipes, VNT-17, Koni Reds, Alpine ida-X100, VR6/G60 Clutch, VR6 Springs
drrck is offline   Reply With Quote
Old February 7th, 2011, 06:47   #4
folgart
thanks drrk!
Old April 3rd, 2011, 10:22   #5
folgart
Default now revs weird
So I still have this issue, but it is getting a little more strange. Periodically thwe codes will self clear, and every time I brake the ABS fires. A couple of applications of the brakes and the codes come back on, and the car brakes normally. Today it happened, and with the clutch in the car revved on its own. No accelerator peddle, clutch in, cluth out, the car revved. ***?
Old February 15th, 2012, 16:57   #6
simtdi
I have the same problem, I put a new sensor and my ABS is coding
00283 - ABS Wheel Speed Sensor Front Left (G47): Electrical Fault in Circuit
simtdi is offline   Reply With Quote
Old February 17th, 2012, 14:57   #7
SheeB
I have the same issue as the OP but I cannot get the bloody connector disconnected at the sensor. I tried working it up and down etc with no luck.
SheeB is offline   Reply With Quote
I need help removing wheel speed sensor thermo VW MKIV-A4 TDIs (VE and PD) 15 January 26th, 2017 13:46
FS: PD130 Engine Complete Wiring harness 6-speed tranny, ECU, ect. LOUD SLOW N'LOW Private TDI Items for Sale/Wanted 3 June 28th, 2010 20:15
ABS Wheel Speed Sensor Helven Ink TDI 101 3 April 2nd, 2008 10:34
Changes to PD engine speed sensor wiring? jstar89crx VW MKIV-A4 TDIs (VE and PD) 0 September 20th, 2006 12:36
ABS Wheel Speed Sensor Gap rocketman VW MKIV-A4 TDIs (VE and PD) 1 March 25th, 2003 07:16
Page generated in 0.15299 seconds with 10 queries
[Output: 77.89 Kb. compressed to 67.70 Kb. by saving 10.19 Kb. (13.08%)]
