Old January 21st, 2011, 09:49   #1
droptail
TDI(s): '02 bug
Default red & blue dash lights on?
Upon cold start up, my girlfriends '00 NB can get a red, red flashing, or blue light, she thinks it might be the same light turning colors. They will go off after a few minutes. It can be freezing in the AM here. Is this a temp idiot light?
We don't have an owners manual yet, just a service.
Any pics here of the dash lights explaining what they are?
'01 NB Blue
E-Diesel mod
droptail is offline   Reply With Quote
Old January 21st, 2011, 09:54   #2
steelmb
Check your coolant level. I think the proper colour on startup is blue.
steelmb is offline   Reply With Quote
Old January 21st, 2011, 09:55   #3
krystlelite81
TDIGUY Associate Vendor
krystlelite81's Avatar
Fuel Economy: 45 mpg
The coolant temperature light can come on either blue or red. It should be blue upon start up and then go out when the car reaches operating temp. If it beeps and flashes red its telling you the car is low on coolant. Occasionally I have seen the red coolant light flash and there is coolant and just the sensor in the expansion tank needs to be cleaned. Just be careful on the NB as there is no temperature gauge and when the red coolant light flashes you need to pull over immediately and check it.
Krystle, Manager at Alternative Solutions, Inc
krystle@thetdiguy.com
(408) 879-9062
www.thetdiguy.com
MALONE DEALER (KESSv2 and K-Tag)
krystlelite81 is offline   Reply With Quote
Old January 21st, 2011, 11:59   #4
droptail
TDI(s): '02 bug
It only displays upon cold start up.
I'll check the coolant/sensor.
Thanks.
'01 NB Blue
E-Diesel mod
Old January 21st, 2011, 13:30   #5
procupine14
Yup I will also say, I myself having a Beetle, that the blue color is saying that the car is cold and you should keep your revs low if you like your turbo in one piece for the long haul etc. flashing red and beeping means low coolant and I think that it does something else to indicate over heating condition.
procupine14 is offline   Reply With Quote
LED Strobe lights Red&Blue Poolboy1191 Private TDI Items for Sale/Wanted 0 November 25th, 2010 06:50
dash & instrument lights out mackconsult VW MKIII-A3/B4 TDIs 7 November 10th, 2009 16:17
Coolant Cold/Hot Dash Light Red & Blinking amishman VW MKIV-A4 TDIs (VE and PD) 9 November 20th, 2006 18:57
Feeler for GB of 3MM OEM vacuum hose (Red &Blue) Herm TDI Private TDI Items for Sale/Wanted 12 June 14th, 2005 05:08
Warning Systems & Lights (Red Lights…) VTJC Upgrades (non TDI Engine related) 1 June 14th, 2002 06:01
Page generated in 0.13933 seconds with 10 queries
[Output: 68.31 Kb. compressed to 60.28 Kb. by saving 8.04 Kb. (11.76%)]
