Old January 17th, 2011, 19:37   #1
jetta ,97
jetta ,97's Avatar
Fuel Economy: 39 MPG 20%hwy,80% citi;48 MPG hwy
Default MFA Cluster in 99.5 , Yes I did it
First I would like to tank you to unpimpZauto for finding out that immo 3 cluster can be rewire on circuit board and it can be use in 99.5 cars:
http://forums.tdiclub.com/showpost.p...4&postcount=70
I have done first MFA Immo 3 Sprot cluster in 99.5 car.None CAN car with CAN cluster.
I had to add wiring and stalk which can be found here how to do it:
http://forums.tdiclub.com/showthread.php?p=459818
After that you need to go in address 19 and recode it to 00002.
The tricky part was immobilizer light.I had to install coil reader which on 99.5 will be on key tumbler but pins are missing .
Then I had run wires from coir reader to cluster.Then it comes other problem. As you have none immo ECU key want be able to adopt the normal way , so knowing eeprom and addresses in it I had to add manually key.
This part is not easy to explain so I will just say this much about it.
Here is the video I made :
http://www.youtube.com/watch?v=jgD8jjqJpW8
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK IV 1999.5 With Immo3 FIS Cluster
jetta ,97 is offline   Reply With Quote
Old January 17th, 2011, 20:18   #2
DJGonzo
DJGonzo's Avatar
I knew it was possible!
Awesome. This will come in handy
DJGonzo is offline   Reply With Quote
Old January 17th, 2011, 21:05   #3
jetta ,97
jetta ,97's Avatar
Thanks to you , you was the one who push me to do this
HEX+CAN
Old January 18th, 2011, 03:03   #4
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Great video!
I see you did the same thing as I did with the MFA cluster conversion because that is not an euro cluster. and it's diesel.
For the immobilizer, I would simply put a coil behind the cluster and adapt it to a chip and tuck the whole thing away somewhere.
I have an immo2 cluster that i would try to use in my 99.5, but the thing is that I cannot rescale the tachometer for anything. No matter what diesel dump I put into it, it just reads as a gasser.
99.5 Jetta TDI; DLC1019 nozzles, G60/VR6, Malone Econo tune, EGR delete, ASR/EDL, bilstein TCs/VR6 wagon springs(1.5in lift),rally armor mud flaps. 305K miles and climbing.
04 Jetta TDI . MFA cluster, e-codes, reverse light mod, LED trunk light. 157K miles(still a baby).
turbocharged798 is online now   Reply With Quote
Old January 18th, 2011, 08:27   #5
DJGonzo
DJGonzo's Avatar
Originally Posted by turbocharged798 View Post
Great video!
Coding?
Did you change that?
Hahaha thanks.
Old February 3rd, 2011, 19:13   #6
jetta ,97
jetta ,97's Avatar
I forgot to say that my car had CAN wires in wiring harness of instrument cluster and it was green connector 32A/ 19 and 20 pin and it is orange/ black and orange/ brown wires.
CAN wires needs for reading of MPG.
HEX+CAN
Old February 7th, 2011, 15:05   #7
waspie
TDI(s): 05.5 pkg2!
could i get the eeprom dump for this cluster? please?
also, mention coding CAN gateway to 00002 should turn off the cluster's airbag light (normally=6, 4(airbag)+2(abs)). at least thats why i'm assuming you did that.
waspie is offline   Reply With Quote
Old February 8th, 2011, 19:26   #8
waspie
TDI(s): 05.5 pkg2!
what about.... putting the cluster in an immobilizer capable car and adapting the key to the cluster and then taking it back to the 99.5
i'm assuming the "donor" car would need to be readapted but that should be easy.
that should work, right?
Old February 8th, 2011, 20:47   #9
jetta ,97
jetta ,97's Avatar
It could be done that way , but if you don't have radio code you will pay $60 recodin radio
in dealer.
HEX+CAN
MFA/FIS/Sport Cluster POSSIBLE on 99.5!!! DJGonzo Upgrades (non TDI Engine related) 193 January 24th, 2013 19:54
MFA in the 99.5? YES! w/ 98 Passat 1.8t cluster compu_85 Upgrades (non TDI Engine related) 64 December 28th, 2012 18:00
FS: Half Screen MFA cluster IMMO3, MFA wiper stalk, ESP clockspring etc. gioTDI Private TDI Items for Sale/Wanted 9 May 27th, 2010 18:01
MFA Cluster OFS Vendor & GroupBuy items for sale 0 November 15th, 2003 19:52
MFA cluster on 99.5's - Paging PTC !!!! tongsli Upgrades (non TDI Engine related) 3 July 21st, 2003 01:03
Page generated in 0.15720 seconds with 10 queries
[Output: 97.23 Kb. compressed to 83.13 Kb. by saving 14.09 Kb. (14.49%)]
