Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010+)
VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010+) Discussions area for A6/MkVI (2010+) Golf and Golf Wagons (Jetta Sportwagon in the USA).
Old January 17th, 2011, 10:39   #1
Jackiechan005
Jackiechan005's Avatar
Fuel Economy: ~40 MPG
Default ESP Error
On cold starts when it takes a little longer to turn over, I get a message on the MFD,"ESP error" as the engine turns over and it beeps. The engine turns over and the message goes away. Not sure what the ESP has to do with starting the engine. Any thoughts?
2010 Golf TDI 6M
Jackiechan005 is offline   Reply With Quote
Old January 17th, 2011, 10:50   #2
Biffster
TDI(s): 2010 JSW TDI
Your car is having difficulty reading your mind.
I only seem opinionated because I'm right all the time. | Worry more. Drive less.
Biffster is offline   Reply With Quote
Old January 17th, 2011, 11:17   #3
Jackiechan005
I found this article : http://www.justanswer.com/vw-volkswa...weeks-ago.html
I have the same issue, except my car turns over. I will check to see if my ECM wires are corroded.
2010 Golf TDI 6M
Old January 17th, 2011, 14:08   #4
OldManWinter
@Jackie - Are you waiting for the glow plug light to go out before you crank it?
OldManWinter is offline   Reply With Quote
Old January 18th, 2011, 05:01   #5
Jackiechan005
I do wait for the glow plug light to go out
2010 Golf TDI 6M
Old January 19th, 2011, 01:32   #6
MayorDJQ
Fuel Economy: 48/42/39
Corroded ECM wires? Do you live down wind of a salt factory? I seriously doubt you have corroded wires on such a new car.
Are you still under warranty? If so, get it to a dealer and have them scan it. It could be a sensor problem.
How cold is it for these cold starts? Any issues on warm/hot restarts? Your more likely culprit is a weak battery. Despite the car being so new, there have been '09 TDI owners who had to replace their batteries when the car was still fairly young.
'10 Golf 2dr, Black, 6spd. RC1
MayorDJQ is offline   Reply With Quote
Old December 24th, 2011, 15:49   #7
T D I
Just had the exact same thing happen to my 2010 Jetta TDI last week, but after 25 cranks I got it running... It's been a year since the original message was posted, has anyone encountered this problem before? Any suggestions?
Thanks,
D.
T D I is offline   Reply With Quote
Old December 24th, 2011, 16:50   #8
MayorDJQ
Start reading the Iced Intercooler thread.
Old December 27th, 2011, 07:09   #9
740GLE
ESP uses ABS controler, a yaw sensor, and a sensor on the steering rack. My guess is the steering rack sensor may be loosing continuity when shaking/cranking over. Not sure where the sensor is located but would be worth a try locating it and double checking the connection.
His: 2010 Sedan, cog swapper, build date 07/09
Hers: 2012 Passat, Roof+Nav, build date 05/12
"Whole new generation Passat will work with you to create outstanding new classic, defining a new pattern!"
Old December 28th, 2011, 15:32   #10
T D I
It was an iced up inter cooler, dealer quoted me over $1500 for a kit to fix their design flaw since my warranty ended 4000 km ago... Thanks for the tip MayorDJQ... After the numerous problems with this car - from check engine light leading to glow plug sensor replacement, to the recent fuel line recall and replacing several door latches, this might be the last nail in the coffin of me leaving the brand...
Old December 29th, 2011, 10:21   #11
MayorDJQ
I hear ya. I would go back to an ALH TDI in a heartbeat if I could find a decent one that didn't have a ridiculous price tag on it. Another idea I've been toying with is a Ford Focus. It's rated for 39mph highway and people on Fuelly.com seem to be getting those numbers. My friend and neighbor also happens to work at a Ford dealership, and I can get a discount on Ford, GM, or Crapsler products through my job, since the company has such a large fleet of the Big 3.
The dealer (VW only!) that checked my I/C pipes yesterday played dumb about even knowing there was an ongoing issue. After I asked about the TSB (which I left a printed copy of on the seat) he then admitted that he's gotten "probably 50" calls about people having similar issues and VW is working on a fix. I asked about the already-existing intercooler kit and again he played dumb, but then admitted that he ordered 5 to have on hand but they're on backorder.
My frustration level was high yesterday.
Old December 29th, 2011, 13:03   #12
T D I
I am waiting to hear about my complaint at VW Canada. Ironically I just this morning paid off a 2011 golf 2.5. After buying two VWs in as many years, I expected to be treated better than this. Especially since this is an existing issue and I am only 4,000 km over warranty.
My next course of action will depend on what their reply is. Another dealer I spoke with reported over a dozen TDIs being found to have ice in there recently.
There are good dealers and bad dealers, I have seen both. Sorry to hear about your VW experience with this. Was considering a Ford as well...
Old December 29th, 2011, 17:00   #13
PlaneCrazy
Fuel Economy: Passat 6.8-7.2 L/100 km Golf 4.8-5.5 L/100 km (summer-winter)
Sue in small claims court. Known defect, etc. Worth a try. More folks should do it. I've had the issue, but when I took the car to the dealer was told "couldn't reproduce the problem". It's documented and you can be sure if it ever happens when the warranty is expired (in about 45,000 more km) I will be pointing to the documentation, and will be suing if they don't fix it. It's my 5th VW, and my wife is starting to think of a replacement for her B5 Passat (230,000 km). If there's going to be a sixth, they'd better step up to the plate.
Mike
VWs: 13 Golf TDI wagon 6-MT, 11 Golf hatch 6-MT, 05 Passat TDI
98 Honda Oddyssey
79 Beech Sundowner
12 Cervelo R3 Team
PlaneCrazy is online now   Reply With Quote
Old October 27th, 2012, 21:28   #14
pkhoury
pkhoury's Avatar
Not sure if anyone is still reading this thread. I got the same error, and I'm getting all KINDS of crap in VCDS. In my case, it would say ESP error while I was driving, the car would shut off, and I shifted to neutral and started back up (so as not to cause an accident).
Paul Khoury
Mods: 9W7 Bluetooth, Vag Com, Painted Red Brake Calipers, Neuspeed Stage 1 Tune, Neuspeed Sport Springs, Neuspeed 28mm rear swaybar, Thule MOAB
Vehicles: 2010 JSW, DSG, Panoramic Sunroof, crappy RNS-510, Front fogs
1997 Saab 900 SE Turbo
pkhoury is offline   Reply With Quote
Old October 28th, 2012, 05:26   #15
sflier
Sounds like a low battery. I bet the voltage is dropping below a minimum and it sets a warning indicator. That beep also goes off on mine if I forgt to wait for the glowplug light to go out before cranking.
sflier is offline   Reply With Quote
Error code P0605 - PCM Read Only Memory (ROM) Error Marin TDI 101 18 August 22nd, 2012 04:48
Mobil 1 ESP 5w-30 or Mobil1 ESP Formula M 5w-40? spyderhead Fuels & Lubricants 8 September 21st, 2009 08:56
Is it possible to add ESP to a non-ESP equipped car? daniel_mad Upgrades (non TDI Engine related) 4 March 27th, 2009 01:05
ESP p151 TDI 101 37 April 1st, 2005 20:50
ESP *dilemma* 2004 w/o esp OR 2005 w/esp ?? tibbar VW MKIV-A4 TDIs (VE and PD) 8 September 19th, 2004 19:33
Page generated in 0.15519 seconds with 10 queries
[Output: 124.41 Kb. compressed to 103.47 Kb. by saving 20.93 Kb. (16.83%)]
