Old January 15th, 2011, 20:06   #1
DaveLinger
DaveLinger's Avatar
Default How many labor hours to replace clutch/flywheel?
Hello.
I'm wondering how many labor hours I can expect to be charged by a shop for replacing a clutch and flywheel on my ALH. It's a SBC Stage 2 Endurance. I know it'll vary from shop to shop, but I'm looking for an average. 6? 7?
DaveLinger.com
DaveLinger is offline   Reply With Quote
Old January 16th, 2011, 08:55   #2
Curious Chris
Fuel Economy: 47/42/38
I think they will charge you at least 6 and maybe 8. There are those here who do clutches a lot and claim they can do it in 4-5. I just did the clutch on my car and it took us closer to 10-11 but it was our first time. I did call the one dealer I trust and they said 8 hours but then I know him so I said something like it can't take you that long and he admitted they could probably do it in 5-6 hours.
Wavetrac LSD, Bosch 230'a with RC4.5, Whitbread 2.5" downpipe, PD lift pump, South Bend Stage 2 Endurance Clutch, steel skid plate, Wingnut inspired EGR mod, MyCruiseAgent no drill EGT, MoGolf skidplate mod
Curious Chris is offline   Reply With Quote
Old January 16th, 2011, 09:25   #3
PDJetta
PDJetta's Avatar
8 hours from the dealer sounds about right. I called the dealer where I live, Northern Virginia, and a clutch replacement was $1550! I was told half was the labor charge.
I too replaced my clutch, first time, and I took a leisurly weekend to do it solo. Only paying $380 for a clutch kit and some bolts and gear oil, I saved quite a bit!
Savings for replacing your own timing belt (with a complete kit) save about the same. Dealer quoted $1550 for that too!
--Nate
Old January 16th, 2011, 09:29   #4
oldpoopie
oldpoopie's Avatar
It takes me 3.5 hours if I'm really hustling, using no lift, with air tools, every nut and bolt torqued to spec.
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old January 16th, 2011, 09:29   #5
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
It's 4.5 hours. Book time.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old January 16th, 2011, 09:43   #6
joetdi
Originally Posted by DaveLinger View Post
Hello.
It will depends on what book someone uses. If can vary depending on this.
joetdi is offline   Reply With Quote
Clutch and Dual Mass Flywheel--labor mcguirejw VW MKV-A5 Golf/Jettas 8 April 7th, 2010 17:43
when to replace the clutch/flywheel? SoaceMunky TDI 101 8 March 6th, 2010 21:22
New clutch. Replace flywheel? Bradtholomew Ontario 5 January 28th, 2010 15:34
Labor hours to clean intake manifold and replace turbo? 03_01_TDI VW MKIV-A4 TDIs (VE and PD) 1 January 5th, 2008 12:54
How much labor to install clutch/flywheel? DieselSmoker TDI Power Enhancements 35 April 18th, 2007 22:29
Page generated in 0.14372 seconds with 10 queries
[Output: 76.94 Kb. compressed to 67.26 Kb. by saving 9.68 Kb. (12.58%)]
