Old January 13th, 2011, 22:58   #1
tivoKlr
tivoKlr's Avatar
Fuel Economy: 44
Default Door locks driving me crazy! Help!
OK, I already know all four door position sensors in my 2003 are shot. 3 show up as open all the time and one shows as implausible in VagCom.
This has been an inconvenience for the last 2 years. I have not felt like dealing with it honestly.
Now there's a problem. The alarm is sometimes going off shortly after I lock the car.
Can I disable it? I don't care about locking the car but if I don't the radio won't turn off for several minutes (aftermarket).
Any thoughts would be appreciated. I will be replacing the door position switches this summer but it's snowy out for the next 5 months...
~tivoKlr
2003 Jetta TDI - KERMA tuned - VNT 17/22 - Bosio PP764 - 2.5" Passenger Performance DP with AR25 resonator and 2.5" catback - SB Stage 3 clutch - 3 bar map - Boost gauge - EGT gauge - TT Fat Fives - KONI Yellows - Apex 40mm springs - UGLY Trailer Hitch
tivoKlr is offline   Reply With Quote
Old January 14th, 2011, 08:41   #2
puter
Fuel Economy: 57 mpg
No way to disable the alarm/immobilizer without sending your ECU to be tuned and immo/alarm delete (I'm not even sure they can stop the alarm, I just know they can stop the immobilizer).
Why not just fix the issue? It's not very hard. There is a link in my sig that says how.
puter is offline   Reply With Quote
Old January 14th, 2011, 11:27   #3
Powder Hound
Powder Hound's Avatar
Originally Posted by tivoKlr View Post
... but it's snowy out for the next 5 months...
So quit bragging. Forget about your troubles and go enjoy the powder for the next few months!!
Powder Hound is online now   Reply With Quote
Old January 14th, 2011, 15:06   #4
tivoKlr
tivoKlr's Avatar
Fuel Economy: 44
I'm going to this summer. I'm trying to keep from annoying my neighbors until then...I will be doing the immob delete this summer as well, when I can use two wheeled transportation the few days the car is down.
Hehe, I've been killing it
~tivoKlr
Old January 14th, 2011, 15:39   #5
BobnOH
Fuel Economy: 50/45/35
temporary solution, double click the unlock before you lock it, that may keep the alarm happy
Old January 14th, 2011, 18:45   #6
Herm TDI
Herm TDI's Avatar
Have you tried turning off the auto-locking with VCDS ?
This would leave the doors unlocked and may solve your alarm problem .
Malone Tuning Service.
HermTDI@Yahoo.com
Herm TDI is offline   Reply With Quote
Old January 14th, 2011, 21:05   #7
tivoKlr
tivoKlr's Avatar
Fuel Economy: 44
There is no way to turn auto-locking off with VCDS that I am aware of, at least the last time I looked into this. Is there something new along this line that you know of?
I could care less about the alarm, and if I want to lock the car I'm certainly capable of doing so manually...
~tivoKlr
Old January 15th, 2011, 07:38   #8
Herm TDI
Herm TDI's Avatar
You can turn off the auto-locking as well as the the auto-unlocking with VCDS.
Here is the "How-To":
Mk IV Lock/Unlock Horn/Flash:
[Select]
[46 - Cent. Conv.] (35 - Cent. Locking for manual window cars)
[Adaptation - 10]
Channel (03..08)
Adaptation Value (1 = on, 0 = off)
[Save]
Channel 03 Auto Lock = [Change this to a 0]
Channel 04 Auto Unlock = [Change this to a 0]
Channel 05 Unlock, horn sounds
Channel 06 Lock, horn sounds
Channel 07 Unlock, turn signals flash
Channel 08 Lock, turn signals flash
You have to select "central convienence" for pwr windows / "Central Locking" for manual windows.
HermTDI@Yahoo.com
Old January 15th, 2011, 10:16   #9
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
Use the door switch to lock the 3 doors. Then use your key to lock the drivers do.
I've been doing it this way for years since my alarm will go off as well.
1994 Jetta 1.8 2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TFSI 4Motion, 2014 Jetta 2.0
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Old January 15th, 2011, 20:28   #10
rocketeer928
rocketeer928's Avatar
The little horn sound doesn't occur when I use the key fob and my alarm also goes berserk in the cold weather. As a winter fix, I've been opening the passenger door, manually hitting the lock button, and closing the door. This locks all the doors without setting the alarm. Happier neighbors.
2003 Jetta GLS TDI with RocketChip RC5-ASV-Euro tune specific to my performance modifications - Platinum Gray
yo
rocketeer928 is offline   Reply With Quote
Old January 15th, 2011, 21:29   #11
77 K20
77 K20's Avatar
Apparently my Golf decided to do this tonight. When I came in to work tonight I got out of the car and locked it with the remote. No beep. Odd... I opened and closed all 4 doors and hit lock on the remote. Beep. Thought all was well.
I was at work for an hour when someone came into work that just got there. Hey your alarm is going off. I was busy and ignored it. 2 hours later some guys left for lunch and came back in saying the car is just making random beeps now. (no parking lights flash). So went out and opened all 4 doors again and shut them. Stood there for 5 minutes and nothing.
So a stupid door switch will cause something like that? I'm working 7 days a week and don't care if the car alarm works or not. I'll have to try just using the key to lock the door.
It is 34 degrees F here now... so not that cold. Last week it was -15 and I didn't have the alarm going off. I did however have problems with the rear hatch. It didn't want to latch completely. I sprayed some WD40 in it and it shut- and I haven't used it since. Does the hatch have a microswitch also?
2007 VW Touareg sport
2014 VW Passat 1.8T 5 speed manual
2004 VW Passat TDI GLX Sedan 5 speed manual TDT Stage 2 tuning
2003 Chevy 2500HD 8.1L 6 speed
1977 K20 Fuel injected HT383
77 K20 is offline   Reply With Quote
Old January 16th, 2011, 14:01   #12
tivoKlr
tivoKlr's Avatar
Fuel Economy: 44
Unhappy no go
Unfortunately, when I went out to make these mods, I noticed I already have channel 3 set to 0, and I intentionally set channel 4 to 1 a long time ago to have the car unlock all of the doors when the key is removed.
There still does not appear to be any way to disable the auto-relock function, which is what I've wanted for 2 years +.
Thanks for the suggestion though.
As for the trunk issue mentioned above, yes, there is a position sensor in the trunk too, and I unlock, open and then shut trunk to keep the doors unlocked when I want to be sure they're going to stay unlocked.
It seems the only real fix is to fix all four door position sensors, which isn't happening for a while...
~tivoKlr
Old January 16th, 2011, 17:25   #13
77 K20
77 K20's Avatar
So I have prodiag for my PDA. I went out and did the auto scanning of all modules for DTCs. It came up with 0. With my old audi I had the alarm go off maybe twice and under central locking it would then display a DTC of alarm via interior monitoring so I knew what was going on.
So how do I figure out which of the 4 door switches, the hatch switch or the hood switch is causing the stupid problem? I opened all doors/hood/latch and firmly shut them and now the alarm will not activate when I lock the doors (no beep, no blinking red light). To me this is not necessarily bad... if it doesn't arm it won't go off all night- right?
Old January 16th, 2011, 18:57   #14
NB_TDi
NB_TDi's Avatar
I have zero codes from the door locks. They are just damaged switches, the controllers don't pick up on that.
You can test the door latches, by going into measuring blocks and find the channel for each door. Watch the information as you lock, unlock and open/close the doors.
PLEASE HELP this is driving me crazy sask tdi TDI 101 38 February 14th, 2011 10:31
Driving me crazy... takebars VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 5 November 4th, 2009 16:15
my brakes are driving me crazy PnutButrJelytime TDI 101 27 July 17th, 2009 12:45
Crazy Crazy lights and locks - Central Conv? Westro OBD Scanners 12 September 19th, 2006 12:04
HELP!! the chiming is driving me CRAZY!! Deezel VW MKIV-A4 TDIs (VE and PD) 5 November 21st, 2004 20:26
Page generated in 0.15444 seconds with 10 queries
[Output: 129.02 Kb. compressed to 107.79 Kb. by saving 21.23 Kb. (16.46%)]
