Closed Thread
Old January 13th, 2011, 17:55   #1
Mark@MaloneTuning
Mark@MaloneTuning's Avatar
Default Dynamic Idle for TDIs
We have seen European industrial TDI engines with a fixed 1250 RPM idle and some of our clients are curious about elevated idle to possibly shorten the warm-up period. They however don't want to consume more fuel with high idle on all the time, especially if the engine is already warmed up. Enter our dynamic idle tune:
The idle also will return to stock if ~12 minutes has been reached, regardless of coolant temperature.
If the car starts up with the coolant temperature already at 60C+ (140F+), the idle RPM will immediately be stock.
Some other idle examples:
  • Cornell University Serial Hybrid 1.4L TDI vehicle - Starts at 1000 RPM and then idles permanently at 1500 RPM once warmed up. This is the optimal RPM range for charging batteries. The 1000 RPM start-up avoids the cold engine wear-and-tear that could occur with a sudden 1500 RPM start. A similar configuration was used in a TDI-powered drilling machine in Alaska.
  • 1100 RPM fixed idle in a highly modified TDI with stiffer engine mounts. This reduces idle vibration. 1200 RPM elevated idle was also applied at lower coolant temp to potentially warm up the engine faster.
This feature has been in use for a year with no issues. It requires custom tuning price (about $50-100 more than standard). Other features are available with custom tuning - dynamic EGR control, left-foot brake fix, and glow plug duration & strength change.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Mark@MaloneTuning is offline
Old January 13th, 2011, 18:01   #2
Farfromovin
Torque Addict
Farfromovin's Avatar
Fuel Economy: low: 35 high: 56 avg: 42.0
Also a good idea for those with super stiff dogbone mounts!!! I like the innovation here Mark. More options are always great.
[/old setup]212whp/354 ft-lbs14.862@96.677-Way faster than Chris [/new setup] At least 213whp, and way way faster than Chris.
Farfromovin is offline
Old January 13th, 2011, 18:39   #3
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Very nice. Can you reduce the rediclously long afterglow that these cars have too?
It would be neat if there was a complete list of these modifications you are able to do.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 395K miles and climbing.
09 Jetta Gasser, autofailmatic. Backup car. 230K.
turbocharged798 is offline
Old January 13th, 2011, 22:52   #4
blizzard60
blizzard60's Avatar
^ Agreed to this! Kinda like a buffet, or smorgasbord of tuning choices!!
As Phillip said, nice work on the innovation!
Cheers,
-Chris
blizzard60 is offline
Old January 13th, 2011, 23:05   #5
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
I can attest that high idle helps with stronger mounts. It also helps with smooooth launches.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline
Old January 14th, 2011, 03:19   #6
ryanp
ryanp's Avatar
i have 1050rpm idle, it makes the stiffer mounts bearable! Launching is also improved as stated before!
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline
Old January 16th, 2011, 11:44   #7
Evil-Diesel
Evil-Diesel's Avatar
TDI(s): '05 TDI PD-R
i have had a 1200RPM idle (see sig) since putting in my hybrid vnt20 and it works amazing not only for warmups but for a lightened flywheel (had 14lbs FW)..made the flywheel feel more like a stock 22lbs FW. Malone did it for me when he was with kerma. the only thing though, mine starts up at the normal 900rpm but after 10 minutes, it climbs and stays at 1200rpm. and only because i was told they couldnt figure out how to startup and stay at 1200rpm on the bew's. that was 3 yrs ago...i guess its been figured out.
good job.
KERMA HYRBID VNT20 + HIFLOW CAST MANIFOLD, HYBRID PD100 INJECTORS, PRECAT EXHAUST DUMP + 0 LAMBDA, SRI, OMI, FMIC, BHW OIL COOLER, OIL CATCH, EGR DELETE, JOM's, WAVETRAC LSD, VR6/G60, BFI MOUNTS, TT LCA'S, TT SUBFRAME BUSHINGS, TT SHORT SHIFTER, VR6 AXLES, VR6 SWAY BAR, VF ENDLINKS, POWERFLEX SWAY BAR + STEERING RACK + REAR AXLE BUSHINGS, ZIMMERMAN XDRILLED, KERMA WIDGET, 1200RPM...
Evil-Diesel is offline
Old January 16th, 2011, 11:49   #8
m1ketdi
TDI(s): Leon BKD
Fuel Economy: 50+mpg
This time based drop is a neat feature. Is this only to be found with an appropriate damos. Or have you written completely new code?
m1ketdi is offline
Old January 16th, 2011, 22:22   #9
foxracer1
foxracer1's Avatar
Fuel Economy: Low34/Avg40/best54
I had Malone do this to my AHU warms up faster i love it!
One thing i've noticed it would be nice if it would idle at stock (9xx) when you first fire it for a few seconds till the engine catches its self, then raise to 1200 for the time. It seems to struggle with the extra fuel when it first lights with the elavated RPM cold start.
15Passat DSG SEL stock for now 63k mi
06 Jetta DSG 253k mi Malone stg2 egr cat delete 18" Audi Flat Fives got totaled and I bought it back. Back on the road.
14 Ram 2500 Cummins 4x4 G56 crew cab long bed 107k mi vgt/s475 compounds
Vag-Com owner
foxracer1 is offline
Old January 17th, 2011, 08:07   #10
JFettig
JFettig's Avatar
I also had Mark do this to my AHH Passat, this thing starts like a bomb and is so smooth. With the elevated idle I can drive around at 20mph in 3rd without touching the go pedal
I have been very happy with my tune and tweaks to it.
Jon
JFettig is offline
Old January 17th, 2011, 08:29   #11
Ski in NC
Fuel Economy: 48-52 typical
My preference would be a switch on the dash. Switch on, hi idle. Switch off, normal idle.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline
Old January 17th, 2011, 14:26   #12
foxracer1
foxracer1's Avatar
A switch would be nice.
I had talked with him about a "valet" switch. To derate power and boost for certain drivers. He said he's been looking into it. My tdi swapped 86 will get it.
Vag-Com owner
Old January 17th, 2011, 15:02   #13
JFettig
JFettig's Avatar
I don't really think a switch would be necessary, It would probably hit 140F pretty quick in warm weather. I'll have to weigh in when summer comes.
Jon
JFettig is offline
Old January 17th, 2011, 19:28   #14
foxracer1
foxracer1's Avatar
It would be nice to idle it up after a hard run to help cool down and such.
Vag-Com owner
Old January 17th, 2011, 19:41   #15
Vince Waldon
Vince Waldon's Avatar
Been giving this some thought as well... unfortunately *after* I got my tunes from Mark.
I'll probably just do it electronically by adding a small variable resistance on a switch to the go-pedal circuit. It is just a pot itself after all.
Vince Waldon Edmonton AB Canada
Canadian Grizzly's excellent low-power/limp mode troubleshooting guide
VW's TSB for scientifically tracking down parasitic current drains
Vince Waldon is offline
Closed Thread
Dynamic EGR Control for TDIs Mark@MaloneTuning Vendor & GroupBuy items for sale 43 April 19th, 2013 13:25
VAG-COM: Setting dynamic timing. colbystephens TDI 101 2 December 8th, 2010 16:28
BMC Carbon Dynamic Airbox Link977 TDI Power Enhancements 55 September 3rd, 2007 20:40
Are IQ and dynamic timing same or different? sccasper TDI 101 1 November 30th, 2006 20:24
dynamic abilities of volkswagens ca General VW Discussion 5 April 21st, 2001 23:59
Page generated in 0.17960 seconds with 10 queries
[Output: 131.80 Kb. compressed to 110.36 Kb. by saving 21.44 Kb. (16.26%)]
