Closed Thread
Old January 13th, 2011, 17:35   #1
Mark@MaloneTuning
Mark@MaloneTuning's Avatar
Default Dynamic EGR Control for TDIs
Background: I permanently turned down EGR as far as the ECU could manage in my 2006 TDI. I immediately noticed a difference in 8C/46F weather:
  • With EGR turned off right from the start, my engine took significantly longer to warm up. A cold engine is bad for longevity and fuel economy.
  • I was losing coolant heat during traffic stops because heat from the exhaust was not being recycled. Even if the coolant temperature was optimal @ 90C (194F), I could see my temperature needle drop below 40C (104F) whenever I tried to leech engine heat for my interior comfort.
After putting the EGR settings back to stock, the TDI is able to build and retain heat with much less effort. I enjoy better MPG too.
Some people with EGR delete report lower MPG during short commutes, and better MPG during long trips. Here's an example from a 2005 PD 1.9L BEW TDI customer in Los Angeles:
City/Highway Mix:
All Stock: 42 mpg
Stock, EGR OFF: 34 mpg
Tuned, EGR OFF: 35 mpg
Tuned, EGR ON: 43mpg
Highway:
All Stock: 46 mpg (trip to Vegas)
Stock, EGR OFF: 44 mpg (trip to San Francisco)
Tuned, EGR OFF: 47 mpg (trip to Seattle)
He later re-installed his EGR components and his fuel economy shot up back to normal.
I get requests every week to delete EGR completely so I developed a Dynamic EGR tune that may be an attractive alternative for the following reasons:
Reduced Wear and Tear
Cold engines have greater engine wear and it is exacerbated by EGR delete because of slower warm-up time. Even if you live in a hot climate, a little increased wear every day will add up.
Mercedes Benz has also documented increased engine wear caused by EGR (soot abrasion in cylinders), and by minimizing EGR once the engine is warmed (EGR is minimized for the majority of engine run-time), you further reduce overall wear & tear.
Optimal Fuel Economy
Cold diesel engines have a lot of blow-by and once the engine is warmed up, the engine seals tighter and gets better fuel economy. By reducing your engine warm-up time with EGR, you reach optimal fuel economy sooner in every drive.
Emissions
Emissions with a cold engine is especially dirty. Normal EGR operation during warm-up can significantly reduce your annual emissions compared to a full EGR delete.
Runaway Engine Protection
If a turbo leaks oil into your EGR-deleted intake, the engine may start running on its own. Shutting off the "ignition" key will not stop it because the oil self-burns. It will continue to rev high until potential damage occurs. Or until you shift into a high gear and stand on the brakes to stall the engine. If you get the timing right you'll probably save the engine. Otherwise you're out of luck, especially if you have an automatic transmission.
The EGR has a valve that can block airflow from entering into the intake once you turn the key off, thus suppressing the oil burn and stopping the runaway.
Smoother Engine Stop
This may not be a big deal to some people, but the engine will shake noticeably when turned off, if the intake valves are removed. Retaining the EGR valve (especially for ALH TDIs that don't have an IMF) will maintain smooth engine shut-offs.
Smoother Idle
Some customers have reported smoother idle with Dynamic EGR compared to stock EGR. If your TDI occasionally has a slight "miss" while idling, Dynamic EGR may reduce or eliminate that issue.
Improved Performance
Some customers who still have their stock performance tune have noticed slightly improved low RPM response, especially off the line. That's with only Dynamic EGR as their only modification.
Cleaner Intake
With Dynamic EGR, EGR is activated only during the short warm-up period. It's turned down as far as possible for the rest of your drive. Your intake will be free of soot build-up much longer, perhaps even the lifetime of your vehicle.
The Dynamic EGR feature has been in use for a year with no issues. It requires custom tuning price (about $50-100 more than standard). Other features are available with custom tuning: Dynamic idle control, left-foot brake fix, and glow plug duration & strength change.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Mark@MaloneTuning is offline
Old January 13th, 2011, 22:57   #2
blizzard60
blizzard60's Avatar
Mark, I find this VERY interesting. Here's a question for you though (of course, it's me ): what about BEW, etc customers that have gone do an ARL/PD150 intake and therefore only have the option for a vacuum EGR now. Can you re-map the software to work the valve for the intake flapper as an EGR or something?!
This is something that I probably want to take you up on depending exactly how it can work for the above situation!
Cheers,
-Chris
blizzard60 is offline
Old January 13th, 2011, 22:59   #3
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
This looks pretty cool Mark!
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline
Old January 14th, 2011, 22:05   #4
Vesparide
I've got a question regarding how the dynamic EGR control would work with an egt probe and a EGR block off plate as my next upgrade will be a boost/egt gauge.
I currently have the EGR delete and I have always wondered why everyone was getting mileage into the 40's with their car and I would be lucky if I got over the mid 30's and now I know.
And if it is doable with the probe and block off plate, count me in.
Vesparide is offline
Old January 17th, 2011, 14:38   #5
foxracer1
foxracer1's Avatar
Fuel Economy: Low34/Avg40/best54
I kinda wish i would have left the egr on my dads 98 now just for warm up!
If you turn it off after it warms up would you still need the EGR cooler? I might put the intake mani back on for this function but don't really have room for the cooler with current turbo setup.
15Passat DSG SEL stock for now 63k mi
06 Jetta DSG 253k mi Malone stg2 egr cat delete 18" Audi Flat Fives got totaled and I bought it back. Back on the road.
14 Ram 2500 Cummins 4x4 G56 crew cab long bed 107k mi vgt/s475 compounds
Vag-Com owner
foxracer1 is offline
Old January 17th, 2011, 15:04   #6
UFO
UFO's Avatar
TDI(s): 2001 Beetle
Fuel Economy: 50mpg on B100
I'm all in favor of reducing EGR, but is this legal? The EGR system is an emissions device installed to meet Federally mandated NOx emissions after all...
UFO is offline
Old January 18th, 2011, 18:30   #7
Mark@MaloneTuning
Vesparide: An EGR block-off plate will permanently stop EGR flow, so this tune won't apply.
blizzard60: Using the intake valve control for EGR control is a pretty unusual request but I'll look into it
UFO: Everything still looks normal with all EGR components installed. However even just changing the muffler is frowned upon by some authorities because it is part of an emissions equipment.
You may be surprised to know how many TDI owners request full EGR delete tunes. I get several requests a week. The Dynamic EGR is an attractive alternative as it's cleaner for the environment, speeds up engine warm-up in the winter, and potentially improves fuel economy.
Disclaimer: Any kind of modification to emissions equipment, including this Dynamic EGR tune, should be for off-road use only.
Old January 20th, 2011, 18:46   #8
m1ketdi
TDI(s): Leon BKD
Fuel Economy: 50+mpg
Is this another one that can be done in all TDI generation ecu's?
Much more complex to implement than the dynamic idle mapping, although I have some ideas how it might work, no sleep for me .
Can't wait to see what you come up with later in the tear.
m1ketdi is offline
Old January 23rd, 2011, 15:47   #9
Mark@MaloneTuning
The EGR cooler transfers exhaust heat into the coolant, which contributes to faster warmup. You'll probably want to keep the EGR cooler.
Old January 23rd, 2011, 20:18   #10
foxracer1
foxracer1's Avatar
Oh yup didn't think of that. I'd have to redesign my setup.
Vag-Com owner
Old January 24th, 2011, 18:24   #11
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Of course Malone posts this thread the day I rip out my EGR cooler and plumbing.
My EGR valve was toast (peeing oil everwhere)and I do not think I want to shell out the money for a new one anyway.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 395K miles and climbing.
09 Jetta Gasser, autofailmatic. Backup car. 230K.
turbocharged798 is offline
Old February 5th, 2011, 17:38   #12
2footbraker
2footbraker's Avatar
Cool concept.
2006 Jetta TDI - Malone Tuning stage 4, G60/VR6, Vogtland 55mm/Koni Sports, Darkside GTB1749V, EGR delete, Frank's BRM cam, etc.
Several other IDI's and TDI's
2footbraker is offline
Old February 8th, 2011, 12:01   #13
smltwnguy30
Fuel Economy: Avg 42 mpg Max 52 mpg, before build
This may seem like a newb question here, but I was moments away (literally) from ordering an EGR/EGR Cooler delete for my TDI when I read this. I have to ask a few questions to get a better feel for what all of this means.
1. I have a Frost Heater in my TDI. If that is used properly for keeping the coolant in the block warm, during the cold months, then is deleting the EGR and Cooler still a bad idea?
2. Would this be more practical to continue to use the EGR Cooler inconjunction with the Frost Heater and still delete the EGR? Thus with the cooler intact there would still be moderate thermal exchange helping to keep the coolant warm on cold days but decreasing the soot and increasing air flow by eliminating the EGR?
3. You mentioned MPG drop for a customer on short trips but how long were the trips? What was the temp outside during this time period?
4. Do you have any Dyno runs, or know of any that show what the end result of the EGR and Cooler delete vs EGR delete vs an installed EGR of a car ran when the car was at its regular operating temperatures?
5. The EGR adds hot exhaust gas into the intake mixture, yet we use intercoolers to cool it down to get a more dense air charge for combustion. Eliminating the EGR should increase density by limiting that thermal exchange and therefore make more power??? So... If one uses their Frost heater to warm the block before driving, is there any need for using this tune option instead of deleting the EGR?
smltwnguy30 is offline
Old February 13th, 2011, 17:43   #14
jgeppelt
Fuel Economy: 45hwy - but climbing
Malone Tuning, I am in need of a full egr delete tune. Please PM me what you would charge to do this for me and what your turn around time is.
thanks
1997 Passat TDI / 2005 Passat TDI
jgeppelt is offline
Old February 14th, 2011, 22:20   #15
Mark@MaloneTuning
Using a coolant heater shortens the warm-up period substantially. However, if for example your startup temperature is 100F (38C) then EGR will still bring it to optimal temp quicker. It'll also minimize or eliminate temperature drop while idling outside in really cold weather (especially 5C / 41F or below).
I assume that you're asking about letting your exhaust gas reach your EGR cooler, but not your EGR valve/intake manifold. It sounds a bit odd and I have not seen someone try it, so I can't tell you if it'll be useful.
The commute is 45 miles each way. It was April in Los Angeles. I don't know the exact outside temperature but it isn't terribly cold in LA.
I don't know of any before/after dyno runs for EGR delete.
When you apply full power and need as much fresh air as you can get, the EGR valve blocks exhaust flow as much as it can, so it's not like EGR is always pumping hot air into your engine.
Closed Thread
Are IQ and dynamic timing same or different? sccasper TDI 101 1 November 30th, 2006 20:24
EGR on Euro TDIs... Any hazle? Diesel-Bear Other VW Group TD(I)s 14 May 14th, 2001 12:25
dynamic abilities of volkswagens ca General VW Discussion 5 April 21st, 2001 23:59
Adding cruise control to Euro VW TDIs, here's how to do it. christi VW MKIV-A4 TDIs (VE and PD) 4 May 9th, 2000 03:38
Adding cruise control to Euro VW TDIs, here's how to do it. christi TDI Maintenance 2 May 8th, 2000 14:29
Page generated in 0.19105 seconds with 10 queries
[Output: 140.10 Kb. compressed to 118.46 Kb. by saving 21.65 Kb. (15.45%)]
