Old January 8th, 2011, 10:43   #1
NSTDI
Default 1998 Beetle TDI Temp Sensor
From what I read the 99 up sensor is different than the 98. Is the 98 a 2 pin like this one:
Or is it a 4 pin like this one (or it could be square?):
If the 4 pin, where is it located on a 98 beetle TDI?
Thanks,
Don
1998 Beetle TDI, 325,000 KM, Upsolute (sold), 2003 Passat 1.8T, 340,000KM Upsolute (sold), 62 Bel Air 409, 4 speed, 1963 Parisienne 409 4 speed
2013 Passat 6MT TDI Comfortline with Sport, Sept 18/12 New. Sep 2016 126,000KM. Replaced turbo, sway bar links front and rear, Adblue heater went.
NSTDI is offline   Reply With Quote
Old January 8th, 2011, 11:02   #2
weirdajs
weirdajs's Avatar
Coolant Temp Sensor Green 4pin w/Seal and Clip (A4) this from idparts.com
http://www.idparts.com/catalog/produ...roducts_id=351
no gnis I trap eht s'ereH nognilK sa llew sa tpircSavaJ ni tneulf m'I no gnirb uoy ziuq aivirt yna eca ll'I gnop gnip fo emag a ni ttub ruoy kcik erus nac I gnos emeht etiruovaf ym si "syaD yppaH" nug gniredlos a tog I tub tag a tog t'nia I
weirdajs is offline   Reply With Quote
Old January 8th, 2011, 11:43   #3
NSTDI
Is it this blue one at the back of the block driver side?
The one just to the left of the battery in line in the top rad hose is the 2 pin sensor.
Don
Old January 8th, 2011, 12:02   #4
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Yes, that is it. It's a 99.5 CTS that are blue.
BTW, dude, you seriously need to clean that engine.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old January 8th, 2011, 12:43   #5
NSTDI
Thanks, it looks better with the cover on it and the oil keeps it from rusting.
Don
Old January 9th, 2011, 07:56   #6
touaregv10tdi
touaregv10tdi's Avatar
I hate that sensor. My 2001 New Beetle uses the 4 pin , the green pictured above.
I replaced it in June, bought a new one at Autozone for like $15 or so.
November when the weather got cold , it started to leak, I pulled it out , replaced the O ring with a generic one, and sealed it with ATV High temp black silicone.
I can't believe VW makes a sensor that does not bolt to the block. This one is just pushed in, held in by a plastic clip.
MY FLEET :2005 JETTA TDi /2013 NEW BEETLE TDi/ 2003 BMW X5 AWD /2015 PASSAT TDI DSG TRANS./2000 Beetle TDi Manual/ 2002 Beetle TDi Auto.
touaregv10tdi is offline   Reply With Quote
Old January 9th, 2011, 08:37   #7
turbocharged798
Try buying an OEM sensor. Autozone sells junk.
Old January 9th, 2011, 09:36   #8
NSTDI
I used OEM, $35.00 including the clip and o ring. It fixed my problem.
Thanks for the help.
Don
Old January 9th, 2011, 13:46   #9
touaregv10tdi
What I am discussing here is not the quality of the sensor , but the way it attaches to the block.
It is held in by a simple plastic clip.
Old January 9th, 2011, 18:32   #10
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
The 2 pin sensor that is inserted into the radiator hose is part of the AC system. The AC will only work when the coolant is at a certain temperature.
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is offline   Reply With Quote
Replaced the coolant temp sensor. fixed short GP cycle, now temp gauge is wrong. 2TDIguy VW MKIII-A3/B4 TDIs 3 October 21st, 2010 18:55
New Beetle Ambient Air Temp Sensor Bora-chiara Upgrades (non TDI Engine related) 1 December 11th, 2008 23:58
Temp Sensor Location? - 1998 Beetle mdryan TDI 101 2 April 19th, 2007 13:29
04 Beetle coolant temp. sensor Bio-Beetle TDI 101 4 October 3rd, 2006 15:18
Coolant temp sensor vs. fuel temp sensor Jimwsea TDI 101 0 May 16th, 2006 06:54
Page generated in 0.14531 seconds with 10 queries
[Output: 99.82 Kb. compressed to 84.91 Kb. by saving 14.91 Kb. (14.94%)]
