Old January 7th, 2011, 15:10   #1
heybob
TDI(s): '06 Jetta
Default Heated seat fuse
Our owners manual (or what we have of it) doesn't have a fuse diagram, can someone tell me which column/row or number the fuse for the heated seats is? They stopped working and the vcds site says the code could be a blown fuse, pulled them all and none looked blown though.
GF's car: 2006 Jetta BRM/DSG, Kerma tuned via Q-Loader, turbo back straight, FrostHeater, vagcom
Mine: '03 dmax/alli 527hp, Suncoastgmax5 by FPE, efilive
heybob is offline   Reply With Quote
Old January 7th, 2011, 18:03   #2
2footbraker
2footbraker's Avatar
I can't remember what the fuse is but check your windshield washer jet heater wiring because it is on the same fuse. Often the wiring cracks were it is bent by opening the hood and shorts out.
2006 Jetta TDI - Malone Tuning stage 4, G60/VR6, Vogtland 55mm/Koni Sports, Darkside GTB1749V, EGR delete, Frank's BRM cam, etc.
Several other IDI's and TDI's
2footbraker is offline   Reply With Quote
Old January 7th, 2011, 23:07   #3
dmcchesney
TDI(s): 2005.5 Jetta
Fuel Economy: 41+ mpg
Here ya go. I have the same problem, kinda, only the driver sides doesn't work sometimes.
Depo Projector Headlights, 55w 5000k HID's, Kenwood and Rockford Sound System, Garage Door Opener Mod, FrostHeater, Euro Headlight Switch, and Boost Gauge
dmcchesney is offline   Reply With Quote
Old January 8th, 2011, 09:42   #4
heybob
TDI(s): '06 Jetta
Thank you dmcchesney!!!
Old January 8th, 2011, 10:31   #5
heybob
TDI(s): '06 Jetta
Damn...just went out and checked...that diagram looks nothing like this fuse panel. 2006 brm/dsg
Sent from my DROIDX using Tapatalk
Old January 8th, 2011, 10:37   #6
2footbraker
Check SC37 and SC46. 37 is the heated seat fuse and 46 is the washer jet fuse.
Old January 8th, 2011, 12:22   #7
MyAvocation
MyAvocation's Avatar
I remember there being several fuse box iterations on the 2006.
MyAvocation is offline   Reply With Quote
Old January 11th, 2011, 11:59   #8
heybob
TDI(s): '06 Jetta
Bump, still don't have a diagram.
Old January 11th, 2011, 17:44   #9
2footbraker
You should invest in a Bentley.
Old January 14th, 2011, 18:17   #10
heybob
TDI(s): '06 Jetta
That's it...thanks!
I'll be buying one shortly
Repeatedly blowing fuse/no heated seats 2footbraker VW MKV-A5 Golf/Jettas 15 February 1st, 2012 21:09
Jetta MK4 power heated mirror fuse cdnalpina TDI 101 7 October 4th, 2009 21:36
Heated seats into a non heated seat car wfg97079 Eastern USA 9 January 25th, 2008 22:10
Wtt 03 Leather Heated Power Driver Seat 4 Leather Heated Manual Seat thebigarniedog Private TDI Items for Sale/Wanted 1 October 27th, 2007 05:43
Non heated to heated seat swap? Autoguy VW MKIV-A4 TDIs (VE and PD) 2 November 4th, 2000 06:05
Page generated in 0.13383 seconds with 10 queries
[Output: 94.32 Kb. compressed to 79.69 Kb. by saving 14.63 Kb. (15.51%)]
