Old January 4th, 2011, 14:41   #1
Slowrvr
Slowrvr's Avatar
Default Three beeps - no lights or codes
Twice in the last month my 99 Beetle has beeped three times. No lights on the dash, no codes according to SG2. The first time I was driving on the highway, engine almost up to temp I think. The most recent time was on a city street with a cold engine. Oil level seems ok. Was not making a hard turn in either case (set off oil pressure warning in my old mkIII under hard turn before). Any ideas?
2006 Jetta TDI - Malone Stage 2
Slowrvr is offline   Reply With Quote
Old January 5th, 2011, 11:33   #2
Powder Hound
Powder Hound's Avatar
My suggestion would be to find someone with a VCDS and see if it digs up any codes for you. Scangauge may not get more than OBD-II generic stuff. (Don't know, just conjecture on SG2.)
Old January 5th, 2011, 12:40   #3
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Do all the dash indicators illuminate with the car switched on,not running?
Old January 5th, 2011, 18:11   #4
Slowrvr
Slowrvr's Avatar
As far as I know they all do with the exception of the ABS light. I'm not sure if this car came equipped with that though (it certainly is not functioning). I will double check in the morning though.
Old January 5th, 2011, 21:45   #5
Seatman
Seatman's Avatar
Fuel Economy: No idea
My 2000 plate Seat tdi does that when the coolant or brake fluid is low but I do get a little red warning light too. Maybe worth checking the levels incase you have the same sort of system but the light's not working for some reason.
Seatman is offline   Reply With Quote
Old January 6th, 2011, 10:00   #6
BobnOH
not-a-mechanic
I'm gonna guess the beeps are calling attention to ABS, proceed as suggested in post #2
Old January 6th, 2011, 17:03   #7
Seatman
Seatman's Avatar
I've not had any beeps when my abs wasn't working and I haven't seen it on any of my friends vw's (98 99 and a 2000 model) when they've had abs issues. Only the coolant and brake fluid levels but maybe they're different in the states.
Page generated in 0.15472 seconds with 9 queries
[Output: 75.99 Kb. compressed to 65.32 Kb. by saving 10.67 Kb. (14.05%)]
