Old December 28th, 2010, 18:21   #1
kenoconnell
Fuel Economy: 1025 per tank average
Default 2000 tdi jetta no start?
bought a 2000 tdi jetta 5 speed.330kms.I new it didnt run.when I got it home I put a battery in it and it started so I drove it.it puffed and smoked and sputtered.(black smoke)but when I got it in 3rd gear it took off like a rocket..the timing has been checked and is bang on! any suggestions?I drove it on the highway about 5 kms..took it home and now it only runs when its on ether when its sprayed through breather.???I dont have compression tester to see if injection pump is screwed???any other ideas how to test???????..HELP!
kenoconnell is offline   Reply With Quote
Old December 28th, 2010, 18:50   #2
roadhard1960
Fuel Economy: 48 mpg
When you removed the hose from the intercooler to the intake did you see a clogged up everything? That needs to be cleaned.
You are not supposed to spray ether in an engine that has glow plugs I have read.
Fuel and air filters have been replaced? Fuel filter has been filled with fuel via your MityVac vacuum pump?
2003 Jetta wagon GLS, 5 Speed, Alligator tune, 34 psi tire pressure, 49.1 US mpg first 35k, 50 next 31.5k, 50.4 next 36k miles, cleaned intake twice and polished end runners last time, Mobil Truck & SUV or Delvac. Koni FSDs, VWs since 1977. Sprint 520 Nozzles for Christmas 2007. Ecodes with fogs and Eswitch. 525,000 miles and counting, original turbo. 2004 Dodge 2500 Cummins HO.
roadhard1960 is offline   Reply With Quote
Old December 28th, 2010, 19:03   #3
85_305
Banned
Yes spraying ether in the car w/ the glow plugs in will literally cause your motor to blow up. Baaaaad things can happen, and WILL happen.
85_305 is offline   Reply With Quote
Old December 28th, 2010, 19:59   #4
kenoconnell
how else do you get it to run with out ether..and I agree but I need to know if motor is ok that was a test only and a minor test at that...my main concern is its worth putting another injection pump on it.?maybe try to run a new line to see if the fuel is bad.?who knows whats in the tank?
Old December 28th, 2010, 20:04   #5
fnj2
Why not find out what is wrong before throwing parts at it?
Mutter at idle, growl at full throttle
fnj2 is offline   Reply With Quote
Old December 28th, 2010, 20:05   #6
85_305
Banned
I cant help much further at this point, but all I know is that thing will literally become a bomb detonating spraying ether. Wait for more responses for help. I'm not so sure if it's an ip either.
Old December 28th, 2010, 20:06   #7
fnj2
Well, it's perfectly obvious that's not the problem since it ran "like a rocket" when it got going.
Old December 28th, 2010, 20:15   #8
85_305
Banned
Its better to be positive than to assume
Old December 28th, 2010, 20:35   #9
dalchri
TDI(s): 99 Beetle
Do you have the clear fuel line going from the fuel filter to the IP?
If so, is there fuel in the line or lots of air/bubbles? Some bubbles is normal.
If not, divert the return line from the IP to the fuel filter to a catch can. Attempt to start the car. Does fuel come out?
If you see air in the clear supply line or no fuel comes out of the return line, you need to prime the IP by pulling a vacuum on the return line. Then you need to crack the injection lines and bleed them.
1999 ALH New Beetle 180k miles
dalchri is offline   Reply With Quote
Old December 28th, 2010, 20:54   #10
kenoconnell
Originally Posted by fnj2 View Post
why not find out what is wrong before throwing parts at it?
i dont understand?im trying to find out whats wrong with it..so i dont throw unneccesary parts at it?
Old December 28th, 2010, 20:56   #11
85_305
Banned
Yes. Diagnose it and make certain of your issue before throwing parts at it.
Old December 29th, 2010, 05:23   #12
roadhard1960
When you are working on a car you take car of the basic things like making sure the intake is clean. Making sure the anti-shudder valve is not getting stuck half closed and on down the line. Runs like a rocket could mean it runs better than a 40 hp anti-shudder half stuck and happened to pop open but still restricted intake. Going from 40 to 60 hp could seem like a big deal.
Old December 29th, 2010, 10:46   #13
procupine14
Some people have had better luck using WD40 which is a bit less risky.
I think Injection Pump should be the last thing on the list of stuff to think about. They are expensive and, from my knowledge, rarely go out.
procupine14 is offline   Reply With Quote
Old December 29th, 2010, 12:36   #14
fnj2
Injecting ANYTHING flammable in an uncontrolled manner into the air induction is WRONG, period. It doesn't solve anything; it doesn't help finding the real problem; it isn't necessary; the engine is going to have to be able to start without it anyway; and it is DANGEROUS. Damage caused thereby may not be immediately evident.
Just don't do it.
Old December 29th, 2010, 18:07   #15
kenoconnell
Default my fault codes?help
po380-glow plug heater circuit
p1563-quantity adjuster lower line attained
p1354-modulation piston displ.sensor circuit malfunction
p1144-mass or air flow sensor open or short to ground
p0303-cylinder 3 misfire
any suggestions what this translates to?
Page generated in 0.17050 seconds with 9 queries
[Output: 117.03 Kb. compressed to 96.61 Kb. by saving 20.42 Kb. (17.45%)]
